Garthwood
ON, CANADA Status: offline
Roadrunner......................most guys are putting the Saito 100 in the Hangar 9 Corsair, this warbird was designed with the Saito 100 in mind. There are others that are putting the G20 gasser. The 100 will get you out of trouble, plus reducing stress from vibrations. I fly the Ultimate 10-300 BlueHawk with the Saito 120 and this bi-plane is close to 11 lbs. and flying most times just over half throttle. If you have to put in the 120 you need to reinforce that firewall, this engine creates quite a bit of torque, be prepared to use that rudder on take offs. Very exciting. This engine has power to spare, love it. The Saito 120 in my opinion is a bit too much for the Corsair, but that's my opinion. I was thinking of doing that myself too but I'm waiting it out. I don't have an engine just yet for the Corsair. With the 120 you might have to add more lead to balance out. The Saito 120 is not in production anymore as I understand, the newer version is the Saito 125. This size of an engine is more suitable for the CMP120 Corsair or the G26 gas engine. I like to put in the G20 gas, but I hate the smell of gasoline that stays inside my truck. Plus I store my planes inside the house. The G20 gas Zenoah is a bit heavy, and I heard it is power hungry. Some guys were replacing the electronic ignition that comes with. Again I'm not an expert and I don't have one of these engines, I just read about it. I researched it. Fuji will be the next engine to look in to if one is considering a gas engine. Charles.
