Carb won't turn easily    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Carb won't turn easily
Page: [1]
Login
Carb won't turn easily - 2/20/2013 12:23 AM
dakotanut
Score: 100
Last Login: 3/7/2013
Status: offline
Hello. It's been awhile since I've been on here. I have been real busy with life and work and not working and not living. LOL. Anyways, I'm trying to get my Redcat Racing Nitro truck running again. The carb will not turn. I took it apart and it all looks clean inside and on the piece that goes inside the carb. Not sure what to do. I need a new body also. Something lower so I can start it without having to remove the body and put it back on every time. Thanks for any and all help.
Hide Signatures
       Post #: 1
RE: Carb won't turn easily - 2/20/2013 12:31 AM
nitrosportsandrunner
Score: 296
Last Login: 6/19/2013
Status: online
quote:
ORIGINAL: dakotanut
is the idle set screw not seated in the slot on the carb slide? If its not in that slot then it pinches the part of the carb that should rotate.
Which truck to you have?
_____________________________
SC10 brushless, Thunder Tiger Phoenix XB Brushless, 1/5 custom rock crawler, Slash 4x4, Atomik Barbwire
Hide Signatures
(in reply to dakotanut)
       Post #: 2
RE: Carb won't turn easily - 2/20/2013 4:37 AM
dakotanut
Score: 100
Status: offline
Volcano SV. It's in the groove correctly. I took the carb apart and put a little after run oil on the 2 surfaces. Put it back together and seems to be ok. It's been so long I forgot how to set everything. Got it close I think. The tank looks nasty on the bottom. Like the nitro got hard or something? I don't know? Also noticed that it won't start now. I checked the glow plug and it glows.
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 3
RE: Carb won't turn easily - 3/1/2013 6:08 AM
bleufox6
Score: 100
Last Login: 3/15/2013
Status: offline
Hello, I am new to the Nitro RC world. I purchased a RTR EVO 3+ road car.  The carb is not in a fixed postion.  It slightly rotates in the connection to the engine which doesnt seem normal.  Should it not sit in a single fixed postion?
 Help?
Hide Signatures
       Post #: 4
RE: Carb won't turn easily - 3/1/2013 1:52 PM
JohnP2
Score: 268
Status: offline
quote:
ORIGINAL: bleufox6
 Help?
It should definitely be fixed. It's just the bolt pin on it probably loose. I tried attaching a pic but RCU having upload problems now. Just google your engine's exploded view...to see what I'm referencing. It's a bolt that is on the neck of the carb, which fixes it to the engine.
Mugen MBX6R, HB D8T, Losi 8 2.0, Savage X 4.6, Losi 810, Hyper 7, Exceed Forza
http://www.youtube.com/user/NitroRCNerds
Hide Signatures
(in reply to bleufox6)
       Post #: 5
RE: Carb won't turn easily - 3/1/2013 6:54 PM
bleufox6
Score: 100
Status: offline
Will do John. Thanks for the explanation.  If you could also help answer this question, My steering servo will not respond to inputs on the radio. The throttle servo is working just fine. I I checked and recheceked connections as well as pulled the servo out and but I still have no response? The HPI servo is brand new. Maybe defective? Thanks in advance for your time John.
Hide Signatures
(in reply to JohnP2)
       Post #: 6
RE: Carb won't turn easily - 3/3/2013 12:45 AM
silverman1
Score: 105
Last Login: 6/18/2013
Status: offline
Try pluging it in to the plug on the reciever that the throttle servo is plugged into when you pull the throttle it should work, if it doesnt its probably a bum servo. Also make sure that the connecter on the servo will work with your reciever.
Hide Signatures
       Post #: 7
RE: Carb won't turn easily - 3/3/2013 4:26 AM
bleufox6
Score: 100
Status: offline
I ended up changing out the servo with a self correcting digital.  No problems after the switch.  The Carb is secure now but the freaking motor wont crank.  It is solidly stuck in place.  One thing after another.  I had high hopes for the RTR by HPI...starting to think differently.  I went to the manual but found no answer except to pull the motor and break it down entirely in order to diagnose the issue.  Thanks for everyones replies. It is really helpful.
Hide Signatures
(in reply to silverman1)
       Post #: 8
RE: Carb won't turn easily - 3/3/2013 3:04 PM
JohnP2
Score: 268
Status: offline
Take the glow-plug out and see if you can turn it over. If you can turn the car upside down and pull and pull on the cord. Essentially it sounds like the engine is hyrdo-locked due to being flooded. This will fix it. Either that or you broke your connecting rod (but that is very rare and does not 'just happen').
Hide Signatures
       Post #: 9
RE: Carb won't turn easily - 3/3/2013 7:22 PM
dakotanut
Score: 100
Status: offline
Can anyone say hijack?
Hide Signatures
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.328RCU1
