Servo on the way out?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Servo on the way out?
Page: [1]
Login
Servo on the way out? - 2/20/2013 1:32 AM
grosbeak
Score: 140
Last Login: 5/16/2013
Status: offline
My 50cc SBach has one aileron servo in each wing - Hitec HS-5625s. The one in the port wing sings at while idling at center; I suspected the linkage at first but I've had it off and apart and it appears to move smoothly. In addition, the port wing servo will not hold the aileron up when the Rx is off. That is, if I deflect the starboard aileron up (as in, towards the sky) with the rx off, the servo holds it there. On the port side the aileron sags to just below neutral.
Is this servo on the verge of failure?
_____________________________
MAAC 83386
Stetson Flyers, Ottawa
Hide Signatures
       Post #: 1
RE: Servo on the way out? - 2/20/2013 3:20 AM
nitro wing
Score: 125
Last Login: 5/19/2013
Status: offline
those symptoms are somewhat normal, the singing/ buzzing/whining when powered up and sagging when power is off.
This servo is on the weak side for this application and size aircraft though.
130OZ @ 6 volts is enough for sport scale but well below what most are using for 50cc aerobats, never mind 3D
Hide Signatures
(in reply to grosbeak)
       Post #: 2
RE: Servo on the way out? - 2/20/2013 3:21 AM
nonstoprc
Score: 110
Last Login: 5/20/2013
Status: offline
It is normal for hitec digital servos to buzz around the center position. The sagging of one servo implies the gear set is little bit loose. As long as the servo can hold the control surface in place (without play) when power on, it is in good shape.
What is the torque requirement for the aileron servos for SBach 50cc? 5625s are rated at 131oz-in @ 6v which probably is a little bit of low for 50cc.
Where facts are few, experts are many.
Perfection is God''''s business.
Hide Signatures
       Post #: 3
RE: Servo on the way out? - 2/20/2013 1:08 PM
BarracudaHockey
Score: 280
Last Login: 5/17/2013
Status: offline
The controls sag on most digital servos when power removes, no problems with the gears.
I agree, I wouldn't run those servos on an SBach 50cc unless you're going to take it easy flying it.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to nonstoprc)
       Post #: 4
RE: Servo on the way out? - 2/20/2013 1:51 PM
scale only 4 me
Score: 314
Status: offline
I've run 5625s on Ailerons of 50cc birds many times and fly nothing close to easy. I've never had a problem.
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 5
RE: Servo on the way out? - 2/20/2013 3:15 PM
grosbeak
Score: 140
Status: offline
I respect the talent it takes to fly 3D well, but I'm not the least bit interested in doing in myself. This is an IMAC plane.
As for the servo specs, I have no idea - this plane is discontinued by the manufacturer. It has flown with the current servos for at least two years.
MAAC 83386
Hide Signatures
(in reply to scale only 4 me)
       Post #: 6
RE: Servo on the way out? - 2/20/2013 3:50 PM
ahicks
Score: 669
Status: offline
If you aren't going to be pushing the plane, I'd run it. Worst case is it dies, but the plane should still be controllable enough to get it on the ground?
Hide Signatures
       Post #: 7
RE: Servo on the way out? - 2/20/2013 5:37 PM
ameyam
Score: 130
Last Login: 5/18/2013
Status: offline
What RX are you using? Some of the Futaba HS Rx do not support digital high speed mode on all servo channels. For example the 6008HS supports the high speed mode only on the first four channels. The buzzing occurs only on the high speed channels if high speed mode is selected. Typically ailerons will be connected on 1 & 7. In this case, if high speed mode is enabled, channel 1 will buzz but channel 7 will not. Racked my brains as well till if figured out this. If thats the case, look at going to normal mode (see the manual for how to set this) and all servos will be ok.
If the servo allows the control surface to drop when the TX is switched off, it just means some play in the gears. It varies from servo to servo. The 3010s on my airplanes do not allow the surface to move when the RX is off but the 5625s do.
Ameyam
Preflight check is optional , picking up the pieces is consequential
Hide Signatures
(in reply to ahicks)
       Post #: 8
RE: Servo on the way out? - 2/20/2013 7:51 PM
grosbeak
Score: 140
Status: offline
quote:
ORIGINAL: ameyam
Ameyam
Hey Ameyam,
It is a Futaba R6008. I burnt out a couple of throttle servos during setup and learned that HS mode was the cause, so it's on normal mode now. Good catch!
MAAC 83386
Hide Signatures
(in reply to ameyam)
       Post #: 9
RE: Servo on the way out? - 2/20/2013 8:44 PM
countilaw
Score: 219
Status: offline
Servos   scare me the most in my planes.    I  will use one for a year, maybe two,   then  move them from  elevator/ ailerons  to    throttle, rudder or retracts.      I can stand to lose one of those in flight, but not   elevator or ailerons.   On a new  servo,  I also like to  work it for an hour before using it in a plane.    If a new servo goes out when new,  it will usually  stop working within  that  hour.     After that, I feel good about it in my plane.
I haven't used any   digital servos yet  so I don't know about the  buzzing.   But on a   analog servo, if  it's buzzing,  it's drawing amps from the battery.   It is also looking for center or is binding.   So it's best,  if you have one that is buzzing,  to look for the reason and fix it.
Frank
It''s a hobby, not a job.
Hide Signatures
       Post #: 10
RE: Servo on the way out? - 2/20/2013 9:17 PM
BarracudaHockey
Score: 280
Status: offline
Digital servos buzz, they are constantly finding center. It's normal, there's nothing to fix.
Just the weight of the control surface will make them buzz a little. They do it a little less when they get some time on them.
www.JaxRC.com
Hide Signatures
(in reply to countilaw)
       Post #: 11
RE: Servo on the way out? - 3/17/2013 3:02 AM
snuts
Score: 100
Status: offline
quote:
ORIGINAL: grosbeak
John, when apart you should be checking that the pivot holes in the case are not becoming oblonged. I bought a 50cc airframe that had been flown with 5625 servo's on aileron duty. It worked for the previous owner, but I would not trust them on a 50cc aileron (single servo/side) application. I beleive you have been handed some good advice, with genuine concerns about operating at the top end of this servo's spec's. My advice would be to upgrade these two servo's in a timely manner. Let's call it an investment. These (5625's) might be better suited as elevator servo's on your next 30cc build. A saved Sbach, surely justifies a new 30cc airframe.
Hope this helps, enjoy your season ahead.
-Snuts-
P.S.
Your Sbach recommends a minimum of 180oz/in servo's on the ailerons.
Hide Signatures
       Post #: 12
RE: Servo on the way out? - 3/18/2013 5:29 PM
grosbeak
Score: 140
Status: offline
quote:
ORIGINAL: snuts
quote:
ORIGINAL: grosbeak
-Snuts-
P.S.
Snuts, thanks for the tip. The pivot holes are not elongated, but I will be replacing the servos. I have a pair of Savox 251MGs on order - they're rated to 222 oz/in.
MAAC 83386
Hide Signatures
(in reply to snuts)
       Post #: 13
RE: Servo on the way out? - 3/20/2013 2:13 AM
snuts
Score: 100
Status: offline
Pat yourself on the back, smile and say what a smart fella you are for the upgrade. Beats the guilty feeling you would have had, should you have lost it. Now start looking for another airframe for your 5625's.
Ha-ha.
-Snuts-
Hide Signatures
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
