Recommended airfoil for new scratch build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Skygate CARF, Viperjet - RTF
Seller:  snobird
Details:   $9,600.00   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Recommended airfoil for new scratch build
Page: [1]
Login
Recommended airfoil for new scratch build - 2/20/2013 7:56 PM
Ravivos
Score: 100
Last Login: 6/10/2013
Status: offline
Hi,
As i'm gathering all the information i need for my next scratch build plane, i came across a few questions -
first let me say that this jet will be a sport jet, balsa buildup, with a standard look like the BVM bandit.
the turbine will be located at approx. middle and will use a pipe for it.
the horizontal stab will have an elevator, not a full flying stabilizer.
i have no problem calculating the needed wing area and tail factor, and calculating the needed CoG with the Tail Volume Coefficient.
my question is: is there any recommended airfoil for the wing? on my previous builds u used Eppler 168 which proved to be very good but i dont thing it will fit a high speed jet.
i am planning on building the horizontal and vertical fins from a symmetrical NACA profile (probably 0010) but dont know what airfoil to use for the wing.
furthermore, since the wing will be tapered and probably use a symmetrical airfoil, i want to build it with a dynamic washout but first i need to decide on the main (root) airfoil.
once this one will be decided, ill calculate the lift coefficient and stall angle and choose a different, higher lift airfoil for the wing tip.
i am using profili, which is a great software to design wings.
so, any thoughts? does someone knows what airfoil is been used in the common sport jets like the flash or bandit?
please share your thoughts, any input is welcomed.
Ravivos.
Hide Signatures
       Post #: 1
RE: Recommended airfoil for new scratch build - 2/20/2013 8:08 PM
AVIOJET
Score: 100
Last Login: 6/20/2013
Status: offline
Hi Ravivos, I have the BVM Bandit airfoils for wings, stab and rudder in dwg file, let me know if you are interested. The powder was invented a lot of years ago.
BR
Jesus A. Serrano
Hide Signatures
(in reply to Ravivos)
       Post #: 2
RE: Recommended airfoil for new scratch build - 2/20/2013 8:15 PM
Ravivos
Score: 100
Status: offline
Hi Jesus,
that will be great, have no intentions to "invent the wheel", just the challenge of a self designed and built plane.
do you happen to know the name of the airfoils? so i would be able to find them on Profili...
anyway - PM with my email.
Any other inputs regarding a recommended airfoil?
Ravivos.
Hide Signatures
(in reply to AVIOJET)
       Post #: 3
RE: Recommended airfoil for new scratch build - 2/21/2013 12:28 AM
AVIOJET
Score: 100
Status: offline
Hi Ravivos, the airfoils have not name, so you can't looking for it in Profili
PM sent.
BR
Jesus A. Serrano
Hide Signatures
       Post #: 4
RE: Recommended airfoil for new scratch build - 3/2/2013 8:19 AM
Ravivos
Score: 100
Status: offline
Hi Jesus, thanks for the files.
Any other information?
Hide Signatures
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
