elimsprint
Joined: 9/19/2003 From: Winfield, BC, CANADA Status: offline
quote:
ORIGINAL: new_helo_flyer Well I finally starting flying my Aerohawk a bit and just broke a main rotor blade. Are there any recommended mods I should buy for this thing to make it more durable and more stable or easier to fly? Thanks for the help! mike Mike, I am just starting to fly mine also. To just get it off the ground and obtain a couple of 4-6 second hovers I needed to completely disassemble the rotor head and drive system. The ball joints were all binding, there was little to no movement between parts 25 &29 and these must be completely free, just swiveling on the bearings. Also the part 03 control rod was 1/8" to long so I made a new one, yeah I know they say to just bend them but I couldn't see a way to do it without changing the way the ball joint then went together. It seems to be getting a little smoother now but is still almost impossible to control. I think that it still needs a lot of fine tuning! I can fly the electric heli in my real flight G2 pretty well but so far no luck with this little sucker! If you are flying or hovering how tight are your main rotor bolts? Did yours fly right out of the box? Does it hover smoothly or like mine does it start to shake and oscilate? I need help!!!!!!! Thanks, Kim
< Message edited by elimsprint -- 9/26/2003 12:14:27 AM >
_____________________________
as if golf isn't enough frustration
