Can someone please help me?????    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Can someone please help me?????
Page: [1]
Login
Can someone please help me????? - 2/22/2013 3:47 AM
giddyuperic
Score: 110
Last Login: 6/16/2013
Status: offline
Hello I have a DLE 30cc engine and it was bought from a friend and but it in a yak54 and it died and she went in. So cleaned up the engine and mounted it on a gold wing Extra 300LM now I can't get it to start it has spake and fuel and air but nothing??????? I was told that I should just buy a new ingnition I don't know if that is spelled right but you know what I mean. I am not in the money to go and just replace that because someone said so. You can hear a clicking sound coming from some where when you turn the prop over slowly but I don't know what that is and it gets really wet. I put the hight and low neddles back to factory settings and she still was soaking wet when we pulled the plug. Even cut the factory settings in half and it still get the plug wet not a wet as at the stock settings but still nothing not even a pop when you close the chock. I have a DLE55 that starts like a charm couple of flips of the prop turn her on and chock it and pop and then she fires right help. Any help would be great. Thank you for your time. Eric
_____________________________
F9, hunter hawker,F-22,yak55 30% DLE55,Extra260,300.sabre F86,bae hawk,Cessna 182. GoldWing extra300LM 30CC Velox20cc
Hide Signatures
       Post #: 1
RE: Can someone please help me????? - 2/22/2013 3:55 AM
SOLO_48
Score: 106
Last Login: 6/17/2013
Status: offline
i would try another ignition
Hide Signatures
(in reply to giddyuperic)
       Post #: 2
RE: Can someone please help me????? - 2/22/2013 4:00 AM
giddyuperic
Score: 110
Status: offline
Thanks even with good spark with the plug outside and grounded on the head????
Hide Signatures
(in reply to SOLO_48)
       Post #: 3
RE: Can someone please help me????? - 2/22/2013 4:20 AM
All Day Dan
Score: 156
Last Login: 6/18/2013
Status: offline
You should rebuild the carburetor. It sounds like the metering needle is not seating properly. You should always bring a spare ignition module and sensor to the field when you go flying. You can never tell when they will go bad. I always bring them and it has saved the day every now and then. If you fly at Prado, I can meet you there and see what's happening. I'm usually there at 7:30 on Tuesdays but any day is OK. Dan.
Dan
Hide Signatures
       Post #: 4
RE: Can someone please help me????? - 2/22/2013 5:29 AM
CK1
Score: 150
Status: offline
I would take Dan up on his generous offer to assist you.
"Aint this great !!" - Chris
"Nosen Cessna 310 Club" #8
Hide Signatures
(in reply to All Day Dan)
       Post #: 5
RE: Can someone please help me????? - 2/22/2013 12:02 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: All Day Dan
I've been running C&H Syncrospark on my Saitos for years & have never had a module fail.
I still use the 1st module that I bought in 1997. It has been through 2 severe crashes & outlasted the engine on which it was originally installed.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
       Post #: 6
RE: Can someone please help me????? - 2/22/2013 1:38 PM
ahicks
Score: 669
Status: offline
When an Rcexl spark plug boot meets the dirt, very often there is internal damage that's impossible to see. Often you can hear it though? If you pull the plug and turn the engine over with the plug inserted in the boot, you'll see it sparking, but when it comes to sparking while under compression - it doesn't. It leaks to the boot - making the snapping noise you hear.
Replacement boots are available, not too hard to find, not too difficult to replace. MUCH less money than a new ignition.
Here's one source, 12.00
http://www.rcextremepower.net/ignitions.html
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 7
RE: Can someone please help me????? - 2/22/2013 3:18 PM
superfli
Score: 100
Status: offline
+1 on the spark plug boot. My Giant SS tail came up and the boot hit the ground. Would never run right after that. Hard to start as well. Replaced the ignition. No problems since.
Superfli
Hide Signatures
(in reply to ahicks)
       Post #: 8
RE: Can someone please help me????? - 2/22/2013 4:30 PM
giddyuperic
Score: 110
Status: offline
Thank you guys so much I have places to start now. I have a box on of my DLE55 will that work just to check it? Thanks Eric
Hide Signatures
(in reply to superfli)
       Post #: 9
RE: Can someone please help me????? - 2/22/2013 6:39 PM
ahicks
Score: 669
Status: offline
Plug and play! Great plan if you have a module that's not installed in something.....
Hide Signatures
       Post #: 10
RE: Can someone please help me????? - 2/22/2013 6:46 PM
av8tor1977
Score: 665
Status: offline
You could have an ignition problem, but I think you might have a carb problem too. If the metering/regulator diaphragm in the carb gets stiff, which they often do with today's gasoline, they can get stuck in the "open" position. That will flood the engine. If you change the ignition and the plug is still wet all the time, go for a carb rebuild. The kits are cheap and the carbs are not difficult to rebuild. Just watch carefully where everything is located upon dis-assembly, and put it back together the same way with new parts.
Note: Sometimes a diaphragm will get stuck in the "closed" position too, then the engine won't get any fuel at all. It is just "the luck of the draw" which position they happen to get stuck in when the diaphragm gets stiff.
AV8TOR
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
       Post #: 11
RE: Can someone please help me????? - 2/22/2013 7:46 PM
Indiomike
Score: 115
Status: offline
quote:
ORIGINAL: ahicks
Al is correct. If the engine was involved in a crash, it is likely the plug boot will be damaged since in most cases the engine is installed upside down with the plug at the bottom. If you see any damage whatsoever such as a dent, don't trust the boot. The boot replacement kit is not expensive and not hard to do.
Mike
Hide Signatures
       Post #: 12
RE: Can someone please help me????? - 2/22/2013 8:02 PM
Indiomike
Score: 115
Status: offline
Here is the link with photos on how to replace the boot. Excellent post by JediJody.
http://www.rcuniverse.com/forum/m_9511266/anchors_9513934/mpage_1/key_/anchor/tm.htm#9513934
Hide Signatures
(in reply to Indiomike)
       Post #: 13
RE: Can someone please help me????? - 2/23/2013 12:17 AM
flycatch
Score: 118
Status: offline
quote:
ORIGINAL: giddyuperic
Some friend.
Hide Signatures
       Post #: 14
RE: Can someone please help me????? - 2/23/2013 12:55 AM
giddyuperic
Score: 110
Status: offline
quote:
ORIGINAL: flycatch
Some friend.
Thank you all for your help it was the box I swaped it with one that we knew worked and it lit right up. But now the carb is all out of tune. It is kind of hard to tune all by your self with out loosing you fingers or a hand and yes I had her tied to a poll. So now I just have to get it tuned right and a new box and it should be good to go. What do you guys have you high and low set at? And the gap on the plug it says 18-20 so I went with 19 is that okay? What does some friend mean??? Any way thank you all for your time and input.
Hide Signatures
(in reply to flycatch)
       Post #: 15
RE: Can someone please help me????? - 2/23/2013 1:25 AM
oneaew@msn.com
Score: 132
Status: offline
that happen to me i checked the carb and found the carb screen dirty so jut take it out and clean it ck all the wireing then try it hope it works
Hide Signatures
       Post #: 16
RE: Can someone please help me????? - 2/23/2013 1:30 AM
giddyuperic
Score: 110
Status: offline
Okay I will do that I am going to get the new box that will take up to 8.? volts with out reg on it. $69 bucks can't beat that. Thanks I see what you mean by some friend I don't blame him for any of this Planes crash!!!!!!!!!!!!!!!!!!!!!!!
Hide Signatures
(in reply to oneaew@msn.com)
       Post #: 17
RE: Can someone please help me????? - 2/23/2013 3:53 AM
flycatch
Score: 118
Status: offline
Too many people off load their junk on their buddies and when it doesn't work they always say never had a problem.
Hide Signatures
       Post #: 18
RE: Can someone please help me????? - 2/23/2013 7:39 AM
av8tor1977
Score: 665
Status: offline
Please..... Every carb on every engine, on every airplane, in every locale needs tuned in every case. There are no such things as "factory settings" being correct for anything more than hopefully getting the engine started. Your ideal tuning settings will be different from anyone elses due to fuel, oil, atmospheric, prop, installation, temperature, barometric pressure, altitude, and more factors. Each engine is a bit different, so your ideal setting could even be different from a buddy's airplane that has everything identical to yours.
Start at the factory settings, then tune the engine to the ideal settings for your setup. There are tons of sources for tuning info, so I won't bother re-typing them all here.
Good luck and glad you got it going,
AV8TOR
Hide Signatures
       Post #: 19
RE: Can someone please help me????? - 2/23/2013 1:06 PM
ahicks
Score: 669
Status: offline
In other words, even if somebody gives you a set of settings that are working great for them, do not assume they're going to work well, or even be close to what works best for you!
Hide Signatures
(in reply to av8tor1977)
       Post #: 20
RE: Can someone please help me????? - 2/23/2013 6:28 PM
av8tor1977
Score: 665
Status: offline
Here's just one example. I had thoroughly test run an engine for my newest 50cc Extra on my test stand. I had the carb adjusted perfectly. Then I installed it on the plane and finished the plane up. When I test ran the engine on the airplane with the cowl on, it was far too rich and the high speed needle had to be closed nearly one full turn.
The reason? This particular engine is a side carb, not rear carb like the DLE's, etc. On the test stand, the prop blast was blowing the reversion, or stand-off away from the carb throat and the carb had to be adjusted richer to allow for that and run properly. With the cowl on, the carb is protected from the prop blast, and sucks a good portion of the reversion/stand-off back into the engine, hence needing a leaner needle adjustment to have the correct mixture.
Now if I had just taken someone's word for "X" and "X" needle settings, how do you think my engine would have run? As I said, the various factors causing the need for each engine installation to be properly tuned are many.....
AV8TOR
Hide Signatures
       Post #: 21
RE: Can someone please help me????? - 2/23/2013 7:52 PM
giddyuperic
Score: 110
Status: offline
Okay thank I understand that all the things come together like tuning with out the cowl will be little different then with it on. I will start then at 1 and 1/2 on high and one 1 on the low and go from there. Thanks every body for your help.
Hide Signatures
       Post #: 22
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Can someone please help me?????
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.609RCU1
