WHAT DO YOU CALL THIS PIECE/PART?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> WHAT DO YOU CALL THIS PIECE/PART?
Page: [1]
Login
WHAT DO YOU CALL THIS PIECE/PART? - 2/23/2013 3:34 AM
carrera mike
Score: 100
Last Login: 6/19/2013
Status: offline
Help, what do you call this linkage connector that links 2 elevator pushrod to 1 pushrod and onto the servo? I've seen them but dont know what they're called(proper nomenclature) to order or search for the piece.
Thanks!
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: WHAT DO YOU CALL THIS PIECE/PART? - 2/23/2013 4:12 AM
Gray Beard
Score: 314
Status: online
It's called a dual coupler and there are a couple types. I have one in a pattern plane like your showing and I have the ball bearing dual coupler in an Extra I assembled for a student in his ARF. Wish I could remember what the Chinese instructions called it but it was really funny!! Central Hobbies stocks the ball bearing types.
_____________________________
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to carrera mike)
       Post #: 2
RE: WHAT DO YOU CALL THIS PIECE/PART? - 2/23/2013 4:32 AM
invertmast
Score: 193
Status: online
Its called copper wire and silver solder
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
(in reply to Gray Beard)
       Post #: 3
RE: WHAT DO YOU CALL THIS PIECE/PART? - 2/23/2013 4:39 AM
jester_s1
Score: 233
Status: offline
invertmast beat me to it!
For me, an ARF is an airplane that someone else just crashed.
Hide Signatures
(in reply to invertmast)
       Post #: 4
RE: WHAT DO YOU CALL THIS PIECE/PART? - 2/23/2013 1:46 PM
JohnBuckner
Score: 352
Status: offline
I would also call it as noted by GB a dual coupler. It is becoming more common on some arfs these days primarily the lite 3D types and mostly for two peice elevator although sometimes it can be handy for duel pushrod or rudder/tailwheel.
The common method is a slight bend where the two rods come together for an inch or so and two wheel collors used to lock them together. This provides good adjustablity and its easy to do. It is my preferred method sometimes when doing separate pushrods for a tailwheel.
Here is one of my warbirds that uses dual pushrods for both the rudder and the elevator with 2/56 rod ends in carbon fibre pushrods.
Just added another picture of a typical arf (Magic Extra) that I have not flown in recent years but it is a nice ship and uses the two dual rod coupled with wheel collor technique. It has always been reliable and just one effective method.
John
Click for fullsize
Click for fullsize
Click for fullsize
"Keep your controllines tight"
Hide Signatures
(in reply to jester_s1)
       Post #: 5
RE: WHAT DO YOU CALL THIS PIECE/PART? - 2/23/2013 5:26 PM
DavidAgar
Score: 146
Status: offline
I have to agree, copper wire and silver solder. I have discovered over the years that the more screw fittings that you have, the better the chance for a screw to come loose. Good Luck, Dave
If the screw ain't loose then things ain't normal.
Dave Agar
AMA#97144
Hide Signatures
(in reply to JohnBuckner)
       Post #: 6
RE: WHAT DO YOU CALL THIS PIECE/PART? - 2/23/2013 10:28 PM
carrera mike
Score: 100
Status: offline
Wow!  thanks gents!  Appreciate all the great tips.  I sure have more ideas from you guys now.
I did find the part from my local hobbyshop.  Heres a pix.  i guess its called "Tripple Rod Connector" at least this one...
Click for fullsize
Hide Signatures
(in reply to DavidAgar)
       Post #: 7
RE: WHAT DO YOU CALL THIS PIECE/PART? - 2/24/2013 1:21 PM
tazzzz
Score: 100
Last Login: 6/9/2013
Status: offline
J B, where did you get that dual rod connector,,cant seem to find it anywhere,,,I sure could use those. TAZZZZ
Hide Signatures
       Post #: 8
RE: WHAT DO YOU CALL THIS PIECE/PART? - 2/24/2013 9:36 PM
JohnBuckner
Score: 352
Status: offline
Hi tazzzz I think you have it confussed it was Carrera Mike that found the Graupner product which in nice maybe a bit heavy. As for me I don,t use anthing except a bit or 2/56 rod end wire and a couple of large wheel collors.
Here is shot of another installation I have and in this case its for the tailwheel of a Moskito:
Click for fullsize
Hide Signatures
(in reply to tazzzz)
       Post #: 9
RE: WHAT DO YOU CALL THIS PIECE/PART? - 2/24/2013 11:43 PM
carrera mike
Score: 100
Status: offline
quote:
ORIGINAL: JohnBuckner
Hi tazzzz I think you have it confussed it was Carrera Mike that found the Graupner product which in nice maybe a bit heavy. ...
 you got me curious John, so I weighed it, merely 2grams/0.05oz.
Hide Signatures
       Post #: 10
RE: WHAT DO YOU CALL THIS PIECE/PART? - 2/25/2013 12:05 AM
JohnBuckner
Score: 352
Status: offline
Ya you right but but those gram things sure do got a way of adding up
But betcha the "mearly' is better applied to the cost thing since I,ve hundreds of old collors laying around. And doing it my way cost nothing. Actually its not my way as more and more arfs are using it and its been a flawless method for me.
John
Hide Signatures
       Post #: 11
RE: WHAT DO YOU CALL THIS PIECE/PART? - 2/25/2013 12:11 AM
carrera mike
Score: 100
Status: offline
John
your way  is better no need to buy anything.
< Message edited by carrera mike -- 2/25/2013 11:56 AM >
Hide Signatures
       Post #: 12
RE: WHAT DO YOU CALL THIS PIECE/PART? - 3/3/2013 3:18 PM
carrera mike
Score: 100
Status: offline
  Thanks for all the help gents!
Here's what i did.  BTW, the 1st reason I did this was i didnt like the factory /oem elevator configuration of my Zero aircraft.  It was causing uneven elevator throws.  Rolling the aircraft a little on full elevators.
Hide Signatures
       Post #: 13
RE: WHAT DO YOU CALL THIS PIECE/PART? - 3/3/2013 3:46 PM
acerc
Score: 221
Status: offline
I am adding one to the list of brass wire and real silver solder.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
