Goldberg Chipmunk Engine mounting    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> Goldberg Chipmunk Engine mounting
Page: [1]
Login
Goldberg Chipmunk Engine mounting - 2/24/2013 10:44 PM
acdii
Score: 155
Last Login: 5/20/2013
Status: offline
I am at the point in my kit where I mount the engine and ran into a slight problem. I am putting a Magnum 91 4S on it, and the mount I am using appears to be a wee bit too big.  It extends past the firewall on the top when I have the engine centered.
Question, will the smaller mount that comes in the kit work for the 91, or is it too small?
_____________________________
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
       Post #: 1
RE: Goldberg Chipmunk Engine mounting - 2/24/2013 11:47 PM
karolh
Score: 310
Last Login: 5/21/2013
Status: offline
Quite likely the mount supplied with the kit was for a .60 size engine, but as long as the engine sits okay on the mount bearers and there is enough meat for the mounting bolts it should be okay. Several glow engine manufacturers make their .60 and .90 size engines very close in physical size.
When inverted always remember that down is up and visa versa
Hide Signatures
(in reply to acdii)
       Post #: 2
RE: Goldberg Chipmunk Engine mounting - 2/25/2013 2:31 AM
acdii
Score: 155
Status: offline
I gave it a try and it looks OK. I will need to shave a little bit off one corner, but looks like it will work. Thanks
Hide Signatures
(in reply to karolh)
       Post #: 3
RE: Goldberg Chipmunk Engine mounting - 2/25/2013 3:29 PM  1 votes
LesUyeda
Score: 151
Status: offline
I used a round mount on mine, and rotated the engine so that the cylinder was slightly down from horizontal.
Les
Hide Signatures
(in reply to acdii)
       Post #: 4
RE: Goldberg Chipmunk Engine mounting - 2/25/2013 6:17 PM
TonyBuilder
Score: 143
Status: offline
 I have mounted a Saito 100 and a DLE 20 both inverted with no problems. Use the round engine mount and it fits perfectly.
TB
Fly, fly, fly!!!!
Hide Signatures
(in reply to LesUyeda)
       Post #: 5
RE: Goldberg Chipmunk Engine mounting - 2/25/2013 7:16 PM
acdii
Score: 155
Status: offline
The round one doesn't work with the Magnum, cant get the engine to fit squarely to it for some reason.
I cant see putting a DLE20 on the Chipmunk though, seems like a wee bit too much power for it.
Hide Signatures
(in reply to TonyBuilder)
       Post #: 6
RE: Goldberg Chipmunk Engine mounting - 2/26/2013 3:34 AM
TonyBuilder
Score: 143
Status: offline
quote:
ORIGINAL: acdii
Fly’s great, even better then with the Saito 100. The 90 will fly it very scale.
TB
Click to see fullsize image.
Click for fullsize
Click for fullsize
Fly, fly, fly!!!!
Hide Signatures
(in reply to acdii)
       Post #: 7
RE: Goldberg Chipmunk Engine mounting - 2/26/2013 12:49 PM
jimamosn8cah
Score: 100
Last Login: 4/9/2013
Status: offline
Here's my Chipmunk with a Saito 100.  I don't remember if I used the stock engine mount or not.   However, I do remember using the general hole alignment that came with the kit.
One change that I made was to replace the fireweall with 2 layers of 5 ply birch plywood.   Something I didn't do which I wish I would have was to add hard points for the cowel mounting.    My only real negative comment on the entire arrangement of this cowel is that I have to take a lot apart to get to the engine, which seemed to be an issue with the Saito 100 until it was broken in.
Click for fullsize
Hide Signatures
       Post #: 8
RE: Goldberg Chipmunk Engine mounting - 2/26/2013 1:46 PM
acdii
Score: 155
Status: offline
Inverted looks good. I mounted mine sideways so I can get to the GP, but I see you used a remote.  I am not sure yet what I will do for the cowl, use the one it comes with, or mold one from glass.
If I mount the Magnum inverted then the large mount may work, I will check again before I put the bottom sheeting on.
Hide Signatures
(in reply to jimamosn8cah)
       Post #: 9
RE: Goldberg Chipmunk Engine mounting - 2/27/2013 2:48 PM
TBonez
Score: 100
Status: offline
Dont't forget about the thick sheeting for the fuse top. I have an OS 70 FS inverted on mine with the mount sticking a little above the firewall thinking I would have to shave it down. Last night I sheeted the top and to my surprise I will not have to trim a thing.
Also I suggest Fiberglass Specailties for the cowl, looks really good. I will still make the ABS cowl as a template only.
Good luck
Hide Signatures
(in reply to acdii)
       Post #: 10
RE: Goldberg Chipmunk Engine mounting - 2/27/2013 6:05 PM
acdii
Score: 155
Status: offline
Oh thats right, forgot about the sheeting!  Should be fine then.  Since I can still get to the back of the firewall I will just get 4 more locknuts and add the inverted mount points to. I can just plug the ones I dont use for fuel proofing.
Hide Signatures
(in reply to TBonez)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
