P38 ziroli Twinsync problem or...    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> P38 ziroli Twinsync problem or...
Page: [1]
Login
P38 ziroli Twinsync problem or... - 3/13/2013 7:26 PM
ronald@kunenborg.nl
Score: 100
Last Login: 3/26/2013
Status: offline
Hello
I have a question.
I have scratch build a ziroli p38j with to dle55 engines of witch a have reversed one engine. I bought 20x10x3 props,one left en one right turning. Now it seems that these wooden props are a little bit different one prop is turning 6800rpm and the other about 6500 rpm on the ground. I have individually tuned each engine before setting up the twinsync. What is see are the following problems:
1. Twinsync is syncing both engines but is not doing this fast enough. When flying and giving more throttle one engine revs up faster than the other. You can here this in the video below. Shouldn the twinsync prevent this? When keeping the throttle at the same position the engines will sync fine.
2. Using mpx tiger karbonite servos for the throttle. Sometimes when thottling on the ground the twinsync seems to over/undershoot and the engines begin to mis each others sync point and begin to oscillate. Imhave tried different timing settings with the twinsync switch on pos. 4 but no luck.
I am about to dump this twinsync in the trashbin...
Can somebody help me?
Here are the video's
http://www.youtube.com/watch?v=vq9l-mGdG1I
http://www.youtube.com/watch?v=yTKR4O4OA_A
Greeting Ronald from The Netherlands.
Hide Signatures
       Post #: 1
RE: P38 ziroli Twinsync problem or... - 3/15/2013 10:33 AM
Otter Guy
Score: 100
Last Login: 5/11/2013
Status: offline
try being smoother on the throttle.
Hide Signatures
(in reply to ronald@kunenborg.nl)
       Post #: 2
RE: P38 ziroli Twinsync problem or... - 3/15/2013 11:13 AM
kork
Score: 100
Last Login: 5/25/2013
Status: offline
who is the manufature of the sync?
Hide Signatures
(in reply to Otter Guy)
       Post #: 3
RE: P38 ziroli Twinsync problem or... - 3/21/2013 7:06 PM
Edwin
Score: 156
Last Login: 5/24/2013
Status: offline
Are the servos true karbonite gears? It is said that karbonite gears should not be used in a gas engine environment. The gears are known to break. Another consideration may be that the servos dont track evenly. A few hundred rpm off is not really a big problem and is pretty normal. My twins rarely track perfect. I've never used a twin sync.
Edwin
Hide Signatures
(in reply to kork)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.171RCU1
