Albatros Dva    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> Albatros Dva
Page: [1] 2 3 4   next >   >>
Login
Albatros Dva - 3/14/2013 4:52 PM
wildbills21
Score: 100
Last Login: 5/23/2013
Status: offline
I am looking for some help finishing the fuselage of an Albatros Dva. I have been trying some different color stains trying to get the correct color. Once stained I was going to finish it off with urathane varnish. I can not seem to get the right color. I know the color of the stained(varnished) fuselage varried from one to another. The fuselage is balsa. Any and all help would be greatly appreciated.
Wild Bill
Hide Signatures
       Post #: 1
RE: Albatros Dva - 3/14/2013 5:12 PM
BobH
Score: 116
Status: offline
Bill tell us what wrong color you have. That'll help. Many of the Albis just had natural varnished wood. Spruce was the most common wood used during construction. The varnish would of course color the wood somewhat. To what degree would depend on what varnish was being used.
So look at some raw spruce OR a Martin Guitar top! Typically Martin uses Spruce for its tops. Pretty much the same look as on the Albi.
The guitar tops age over time to a more yellowish look. I doubt the Albi survived that long!
The Martin Guitars I'm referring to are the D18, D28, D45 dreadnaught models. I know these use spruce.
_____________________________
BobH.
Hide Signatures
(in reply to wildbills21)
       Post #: 2
RE: Albatros Dva - 3/14/2013 5:20 PM
JohnF
Score: 100
Last Login: 5/22/2013
Status: offline
Depending on weathering the ply fuselage would take on some slightly different hues but they were "straw yellow" according to the late great Dan San Abbott. Varnish on birch ply would give that color but you have to experiment with different varnish or stain on balsa. Dave Johnson has a good solution but I forget what he used. I think he mixed Golden Oak with something.
Hide Signatures
       Post #: 3
RE: Albatros Dva - 3/14/2013 5:23 PM
wildbills21
Score: 100
Status: offline
I have tried ipswich and puritan pine, they come out kind of with an orangish tint.
Wild Bill
Hide Signatures
(in reply to JohnF)
       Post #: 4
RE: Albatros Dva - 3/14/2013 5:30 PM
JohnF
Score: 100
Status: offline
Obviously not what you want. Stay tuned and I'll post a photo. If you have access to The Aerodrome you should check out Koloman Mayerhofer's Albatros reproductions.
Hide Signatures
       Post #: 5
RE: Albatros Dva - 3/14/2013 5:43 PM
JohnF
Score: 100
Status: offline
Here ya go. You'll like this. AlbatrosErstflug.mp4 video by kolomay - Photobucket
Hide Signatures
(in reply to JohnF)
       Post #: 6
RE: Albatros Dva - 3/14/2013 5:48 PM
JohnF
Score: 100
Status: offline
Oop's, sorry I thought that would open as a link. Try this http://www.theaerodrome.com/forum/replica-aircraft/35610-albatros-d-ii-d-iii-news-57.html Guess you'll have to paste it in your browser.
Hide Signatures
(in reply to JohnF)
       Post #: 7
RE: Albatros Dva - 3/14/2013 5:57 PM
wildbills21
Score: 100
Status: offline
Thanks for the info John,
I found some info from Mr. Johnsons post a few years ago, he used golden oak from minwax.
Wild Bill
Hide Signatures
(in reply to JohnF)
       Post #: 8
RE: Albatros Dva - 3/14/2013 6:12 PM
JohnF
Score: 100
Status: offline
Okay, That's what I thought.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 9
RE: Albatros Dva - 3/15/2013 2:18 AM
BobH
Score: 116
Status: offline
I repeat.. guitar top! And I'm not kidding lol. I can see the Albi Stroppe a the Air and Space in DC any time, I live close.. I also have the long, out of print, book of the reconstruction. I'm sure you can use a substitute stain just make it light in color. You can call Proctor Enterprise and ask him for a suggestion.. He knows his stuff!
BobH.
Hide Signatures
(in reply to JohnF)
       Post #: 10
RE: Albatros Dva - 3/15/2013 2:22 AM
abufletcher
Score: 1576
Status: offline
Balsa just isn't the same as hardwood or ply. A stain that works well for ply probably won't look at all the same on balsa. You might also find that, in the end, a lacquer or colored varnish or even a stain+polyurethane/polycrylic combination will give you the look you want.
Hide Signatures
(in reply to BobH)
       Post #: 11
RE: Albatros Dva - 3/15/2013 1:48 PM
ZoomZoom-RCU
Score: 105
Status: offline
Abu is right, you will kinda need to do some experimentation with different types because you will get varied results. One item of note is the fact that many Allied observers of the Albatros, often unable to get a real close look in the heat of battle, often described them as "Yellow". This was due to the fact that they were seing the natural stained wood from a distance and believed it to be some coloration. A good poly stain on natural (light colored) wood will provide this outcome. Depending on how "white" the color of your wood is intially.
ZZ.
PAY NO ATTENTION TO THE MAN BEHIND THE CURTAIN!
Hide Signatures
(in reply to abufletcher)
       Post #: 12
RE: Albatros Dva - 3/15/2013 2:11 PM
abufletcher
Score: 1576
Status: offline
To further complicate things, the oil-based stains can have a completely different color from a water-based stain with the same name from the same company.
Hide Signatures
(in reply to ZoomZoom-RCU)
       Post #: 13
RE: Albatros Dva - 3/15/2013 3:03 PM
TFF
Score: 148
Status: offline
Wildbills21 probably knows better than anyone that balsa acts different than spruce or birch. Birch seems to oxidize to a yellow, spruce goes red/brown, and balsa kind of goes grey. Then on top of that a varnish that either yellows or darkens some other way when it oxidizes. With balsa you really should stableize it with some kind of sealer and then top coat varnish. It just soaks in too much, with balsa.
Hide Signatures
       Post #: 14
RE: Albatros Dva - 3/15/2013 3:20 PM
ARUP
Score: 134
Status: offline
Balsa grain is too open. Seal the balsa then paint. There are great tutorials on the IPMA website. Another option is to replicate an aircraft with painted fuse. Otherwise just stain it as close as possible and let us enjoy your results... pics please!
Hide Signatures
(in reply to TFF)
       Post #: 15
RE: Albatros Dva - 3/15/2013 11:38 PM
JohnF
Score: 100
Status: offline
Hey Bob, I have seen those guitars and they do seem to be very close to the correct color but the bottom line is as many people have said here, it will be very difficult to get balsa to look the same as varnished ply. If he does what Dave Johnson did he will get very good results.
Hide Signatures
(in reply to BobH)
       Post #: 16
RE: Albatros Dva - 3/16/2013 12:23 AM
WacoNut
Score: 175
Status: offline
I remember seeing an Albi years ago that was entered at Top Gun I believe and the wood grain finish was all painted with latex paint. A light tan color applied and each panel painted with a slightly different shade then darker brown streaks added for the wood grain and dry brushed. Looked very good and you could not tell it wasn't a true plywood finish.
I think you will find trying to stain/varnish balsa a very tall task. A test panel could be done very cheap using samples from Home Depot.
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
(in reply to JohnF)
       Post #: 17
RE: Albatros Dva - 3/16/2013 1:05 AM
wildbills21
Score: 100
Status: offline
ARUP,
The first Balsa USA Alby was painted, as you can see. The second is going to be Walter Bonings, natural color front painted blu and white diamonds on the back. Plane is completely built and covered. Waiting for warmer weather to paint it. I have never did a wood finish on a model before so I am to say the least experimenting.
Wild Bill
Click for fullsize
Hide Signatures
(in reply to WacoNut)
       Post #: 18
RE: Albatros Dva - 3/16/2013 2:39 AM
hammerd
Score: 100
Last Login: 4/24/2013
Status: offline
I did a faux woodgrain on my 1/6 scale Alby.
An enamel base, latex glazes, and a polyurethane topcoat.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 19
RE: Albatros Dva - 3/16/2013 3:22 AM
foodstick
Score: 177
Status: offline
With that wood grain painting skill you could be using fiberglass fuses hammerd !
Hide Signatures
(in reply to hammerd)
       Post #: 20
RE: Albatros Dva - 3/16/2013 8:36 AM
jeffo
Score: 105
Status: offline
Hammered-You have to give a more info how you finished your model.The finish on your model is stunning.How did you accomplish such a beautiful wood grain finish?-Jeffo
Hide Signatures
(in reply to foodstick)
       Post #: 21
RE: Albatros Dva - 3/16/2013 1:35 PM
WacoNut
Score: 175
Status: offline
quote:
ORIGINAL: hammerd
Now that is excellent work with paint. If I build the 1/3 Albi I will definetly give that a shot.
Anthony
Hide Signatures
       Post #: 22
RE: Albatros Dva - 3/16/2013 7:06 PM
BobH
Score: 116
Status: offline
Beautiful paint work on the Albi but.. *there's always a but* Can you imagine the size of the trees that that wood would need to come from?
Spruce just isnt that pronounced in its grain pattern. A few pictures of the full sized planes. One belongs to Kermit Weeks. Its nearly new being built in New Zeland a year ago or so..
Click for fullsize
Click for fullsize
BobH.
Hide Signatures
       Post #: 23
RE: Albatros Dva - 3/17/2013 12:01 AM
ARUP
Score: 134
Status: offline
quote:
ORIGINAL: ARUP
'Balsa grain too open. Seal the balsa then paint faux wood grain'. There are great tutorials...'.
Hide Signatures
(in reply to ARUP)
       Post #: 24
RE: Albatros Dva - 3/17/2013 12:30 AM
wildbills21
Score: 100
Status: offline
Hammerd,
Where did you get the guide for the nail markings
Wild Bill
Hide Signatures
(in reply to ARUP)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.469RCU1
