Reload this Page >
Painting and weathering Comp-ARF Mig 29
Old 03-16-2013, 01:36 AM
Pinnacle Aviation
Pinnacle Aviation's Avatar
Default Painting and weathering Comp-ARF Mig 29
After building the model I am now painting the mig.
This is the first of eleven colours - Light grey
Enjoy
Old 03-16-2013, 01:40 AM
Pinnacle Aviation
Default RE: Painting and weathering Comp-ARF Mig 29
Second colour - base white
Old 03-16-2013, 01:44 AM
Pinnacle Aviation
Now the third colour - Yellow
Old 03-16-2013, 01:53 AM
Pinnacle Aviation
Four colour -Red
Old 03-16-2013, 01:57 AM
Pinnacle Aviation
Number five - Black
Old 03-16-2013, 02:00 AM
Pinnacle Aviation
Sixth colour - tan
Old 03-16-2013, 02:15 AM
Pinnacle Aviation
Seventh colour - chocolate
Old 03-16-2013, 02:19 AM
Pinnacle Aviation
Eighth colour - dark green
Old 03-16-2013, 02:20 AM
Pinnacle Aviation
Forgot to take photos of the ninth colour - Black green
Old 03-16-2013, 02:23 AM
Pinnacle Aviation
Tenth colour - Dark grey
Old 03-16-2013, 02:25 AM
Pinnacle Aviation
Forgot to take photos of the eleventh colour - silver
Old 03-16-2013, 02:26 AM
Pinnacle Aviation
Back to the third colour - yellow
Old 03-16-2013, 02:28 AM
Pinnacle Aviation
And finally some small numbers
Old 03-16-2013, 02:31 AM
Pinnacle Aviation
Now the final uncovering
Old 03-16-2013, 04:53 AM
ZivBit
ZivBit's Avatar
Mad mad skills. Thanks for sharing.
Ziv
Old 03-16-2013, 06:46 AM
pippip
My Feedback: (10)
Nice!!!!!!!
Old 03-16-2013, 06:55 AM
LGM Graphix
My Feedback: (22)
LGM Graphix's Avatar
Phil, just curious, did you fit the nose gear with the wheels on? If you just cut out the nose gear opening where the doors are, the nose gear won't go in. The doors need to be extended about 3/4" . Comp arf shows cutting two half rounds behind the doors to let the wheels clear, I cut the doors out longer, you can't see them between the inlets and it doesn't have any other extra holes that way.
Old 03-16-2013, 07:01 AM
LGM Graphix
My Feedback: (22)
I also see you haven't overcut the main gear openings to clear the wheels. If using the glennis wheels they will not fit through the retract cycle without having the overcut opening. Thisis mentioned the manuals well. I tried really hard to make them fit without doing this but they wouldn't. I believe the full size has the same cuts ln the main gear openings anyway.
Looks great, definitely the worst kit I have ever built but it sure turns into a magnificent airplane when done.
Old 03-16-2013, 07:08 AM
Pinnacle Aviation
I have pre fitted the landing gear, nose leg clears, mains have been opened up as per the manual, no I am not fitting glennis wheels.
I agree with you it is by far the worst kit I have ever built, I am not going to go into details, it's all in the past and I really do not want to be reminded about it that's why this is only the painting and weathering thread.
Old 03-16-2013, 11:56 AM
Bloory
I know there a nightmare to build but BY far the best Mig 29 and make the rest i.e skymasters mig 29 just look abit naff and unscale
TOP JOB PHIL
Old 03-16-2013, 12:52 PM
Levi Wags
Levi Wags's Avatar
Awesome job Phil. I am at the same stage with my Comp ARF Mig. Im just starting to apply decals then some weathering. Your colour scheme looks outstanding.
Levi
Old 03-16-2013, 01:30 PM
i3dm
My Feedback: (51)
Magnificant work Phil !
Old 03-16-2013, 01:32 PM
Pinnacle Aviation
Now to the weathering. I always do the weathering before the decals as the weather highlights and cut edge around the decals.
Old 03-16-2013, 01:40 PM
luv2flyrc
luv2flyrc's Avatar
It looks spectacular Phil! Can you share your weathering tecnique with us? Appears you are using a "wash", what is it comprised of? etc.
Mike
Old 03-16-2013, 02:00 PM
Pinnacle Aviation
Hi mike, I hope these threads and the YouTube video helps
http://www.rcuniverse.com/forum/m_11..._3/key_/tm.htm
http://www.rcuniverse.com/forum/m_11360291/tm.htm
http://www.rcuniverse.com/forum/m_11174879/tm.htm
http://m.youtube.com/watch?v=uxEOsRdKjt0
