russellk
Joined: 7/15/2003 From: Canberra, AUSTRALIA Status: offline
I'm not sure what is in Mobil 1's 5w-40, but I doubt it will mix with methanol - few oils designed for petrol engines do. Seeing as you're in Syd, give John a call on 9607 9989 - he's an agent for AT Racing in Liverpool - he sells Coogee methanol 20L for $35, Klotz KL200 synthetic oil $14.30/litre and nitro for $15/litre. His castor oil is a bit expensive - $19 for 500ml. You're better off going to a Castrol dealer and getting "Castrol M" - about $60 for 4L. Another option for methanol is Shell "Racing A" which has about 3% acetone, but at $52 for 20L it's more expensive than Coogee methanol, which has no additives (that I know of). As for mixes, you can try 15% syn + 3% castor which works OK, the castor is meant to protect your engine if you ever have a lean (=hot) run - the castor will hang around at high temperatures after the synthetic has broken down. Then again, a lot of people run full synthetic and have no problems. I've seen total oil percentages from 15% to 25% - you're probably safest choosing somewhere in the middle of that - maybe 18-20% total oil. Hope that helps! Russell.
