RE: Castor or Synthetic?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> RE: Castor or Synthetic?
Page: <<   < prev  1 [2]
Login
RE: Castor or Synthetic? - 9/30/2003 11:17:28 PM
Super.R/C.Freak
Status: offline
Hey just to let you guys know me and petocar are useing cars not planes,so is the mixtures the same?...and we asked the LHS if the cars can run no nitro and they said no,is there any harm not running it? and we are having hard times finding nitro in brisbane.
thnx for ur help
Teemu
(in reply to Sport_Pilot)
       Post #: 26
RE: Castor or Synthetic? - 10/1/2003 7:47:53 AM
downunder
Status: online
Any engine will run just fine with no nitro so I see no reason why this won't apply to a car engine as well. If you want to go with no nitro then I'm guessing you're doing it for fun and not after all out power anyway. The major difference you're likely to find by not using nitro is that your engines will last longer (so long as you have a decent amount of oil) and they'll run for longer on the same size tank. You'll need to use a hotter plug though. Long ago I used to run one of the early OS 21 car engines just for fun and it was run on 80/20 all castor with no idle or any other problems.
(in reply to Da R/Cer)
       Post #: 27
RE: Castor or Synthetic? - 10/1/2003 1:19:57 PM
Sport_Pilot
Status: offline
I don't think there is any real differance as long as the nitro is kept to 20% or under. Actually if the engine as a low enough compression, and you never have a lean run the high nitro engines last as long or longer. If you run the mixture rich enough it will actually run cooler and still have more power.
(in reply to downunder)
       Post #: 28
RE: Castor or Synthetic? - 10/5/2003 11:22:27 AM
Da R/Cer
Status: offline
Ok Im Back!
Sorry for me not replying,i was busy with the pc it just got stuffed up some how.
Right Back to the subject.
Should i use Nitro?
Whats In this Penrite TS40C?
       Post #: 29
RE: Castor or Synthetic? - 10/6/2003 3:00:38 PM
eddiemans
Status: offline
Forget the Penrite TS40C as it won't mix with methanol....
According to a different Tech guy who used to race nitro cars, the good oil is
Penrite's Ten Tenths Castor Race 40, a castor/synthetic blend as used in professional go-kart engines at speeds up to 18000 rpm's at 16 to 1 ratio
I tried this on the weekend in a K&B 61 and a ST75. both planes were a lot cleaner than usual and the K&B seemed to have more compression, probably not so gummed up in the ring as it was! I have 23 more litres to burn so I will get back to you then, although the less mess & easier cleanup has won me over allready.
       Post #: 30
RE: Castor or Synthetic? - 10/6/2003 3:10:28 PM
eddiemans
Status: offline
Hey Da R/Cer
This link may help you out.
www.penrite.com.au/pispdf/CSR40.pdf
< Message edited by eddiemans -- 10/6/2003 3:17:42 PM >
       Post #: 31
RE: Castor or Synthetic? - 10/7/2003 4:37:27 AM
russellk
Status: offline
I spoke to a guy at Penrite regarding their Castor Race 40 - he first stated categorically that it was fully synthetic. I pointed out that the PDF on their site mentioned "vegetable oil", and he said there might be a small amount of castor in it. I asked if he could give an indication of the percentage, he said he didn't know as he wasn't a scientist and couldn't find out because it was commercially sensitive information.
What a load of crap. Worse still, Penrite is an Australian company. All the major oil companies have a fuels technician who you can call and speak to, and have so far been happy to give me oil percentages.
Is the stuff particularly cheap? Unless there is some considerable saving, I'm reluctant to reward their poor attitude.
       Post #: 32
RE: Castor or Synthetic? - 10/7/2003 4:42:41 AM
Da R/Cer
Status: offline
Thanks everyone!
Maybe a bit more info will help me.
Where do i get this Castrol M stuff i have never seen it.
Whats in it?
< Message edited by Da R/Cer -- 10/8/2003 10:25:58 AM >
(in reply to eddiemans)
       Post #: 33
RE: Castor or Synthetic? - 10/11/2003 3:11:33 AM
blue62
Status: offline
if you are really serious try this site.... they make alot of stuff. probably the best castor on the market too. http://www.klotzlube.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=KS&Category_Code=RC_PRODUCTS
john
_____________________________
I don't have it, do you have it? crash! nope musta been shot down!
       Post #: 34
RE: Castor or Synthetic? - 10/11/2003 4:52:13 AM
Da R/Cer
Status: offline
cool! site
       Post #: 35
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.578RCU1
