Tailpipe Collapse    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Tailpipe Collapse
Page: [1] 2 3   next >   >>
Login
Tailpipe Collapse - 5/9/2013 1:57 PM
alasdair
Last Login: 5/18/2013
Status: offline
Last weekend I saw a lovely scale jet spiral dive into the ground, and the verdict from all the jet fliers present was that the tailpipe collapsed, causing hot gasses to melt the composite rear fuselage.
The tailpipe consisted of a bellmouth, followed by a parallel portion about 6" long with a single thickness, followed by double walled parallel portion about 20-24" long.  It was only the first, single walled, part that had collapsed, behind the bellmouth that was still intact.  It was squashed completely flat, with sharp edged creases.
I am vaguely aware of the cause - reduced pressure of the very high speed gasflow within the duct compared to the ambient pressure outside, within the fuselage.
But
Does anyone know what factors are involved? Why might this particular duct have collapsed while thousands of others do not.?
What can be done to avoid/prevent such an occurrence?
Hide Signatures
       Post #: 1
RE: Tailpipe Collapse - 5/9/2013 2:17 PM
RC Larry-RCU
Status: offline
My first questions would be:
Was he running a by-pass Unit?
What was the spacing between the end of the Turbine Exaust Nozzle and the front of the Pipe itself? (Not the bellmouth.)
What size Turbine?
Were the pipe mounting straps still attached to the pipe?
_____________________________
Team Horizon Team Jet Central
Vess Propellers Jackie Sacks Wing Bags
Hide Signatures
(in reply to alasdair)
       Post #: 2
RE: Tailpipe Collapse - 5/9/2013 2:19 PM
David J Ruskin
Status: offline
Rather depends on what the pipe is made of and who made it. If its Chinese.......well throw them away and get a real one from Grumania or similar. Single walled for any length.........well I think the most generous point is that they are 'old school' for little turbines. All pipes need a good airflow, like a bypass or similar, which takes heat from the inner wall. Thats what the outer wall is for, to focus a cooling airflow over the inner.
So a well ventilated double walled, well made stainless or titanium pipe, from a reputable source, is the best way to prevent such an incident.
David
Hide Signatures
       Post #: 3
RE: Tailpipe Collapse - 5/9/2013 2:27 PM
alasdair
Status: offline
quote:
ORIGINAL: RC Larry-RCU
What size Turbine?
I saw the prepared model, and the takeoff (only his third flight) and I saw some of the spiral dive.
I don't know if the pipe was in a full bypass. What effect would that have?
I don't know the gap either. I am aware it should be around an inch, but I didn't see, or ask. Again why? Is collapse more likely with too small a gap?
The engine was a 160
The pipe mountings were still attached to the pipe. It collapsed in situ, not as a result of moving out of position.
Hide Signatures
(in reply to RC Larry-RCU)
       Post #: 4
RE: Tailpipe Collapse - 5/9/2013 2:35 PM
powerjets
Status: offline
Turbine tailpipe too close or in exhaust pipe with bellmouth will create heat and underpressure in pipe and sometimes collapse (implosion) 160 size needs more than an inch distance to bellmouth
OUfly12
Hide Signatures
       Post #: 5
RE: Tailpipe Collapse - 5/9/2013 2:39 PM
Vincent
Status: offline
It would be helpful if we knew what type of jet and who made the pipe?? I friend of mine just had a chinese pipe collapse (total loss) and we believe it had to do with running a P180rx in a 160 size pipe.
Vin...
Hide Signatures
       Post #: 6
RE: Tailpipe Collapse - 5/9/2013 2:53 PM
tamjets
Status: offline
Had done alot duplicated pipe for customers. Most common pipe I had see is not done strong enough.
When engine running. The inner pipe can reach 200-300C. With lack of airflow can suck the pipe collapse. Many of these case happen.
With any prior wet start. These straight don't have a chance if wasn't done correctly.
Tam Nguyen
Owner TamJets
Hide Signatures
(in reply to Vincent)
       Post #: 7
RE: Tailpipe Collapse - 5/9/2013 3:58 PM
basimpsn
Last Login: 5/17/2013
Status: offline
I experience collapse pipes on two occasion one in-flight and the other on the ground
https://www.youtube.com/watch?v=bPF3hI1wpt8
Click to see fullsize image.
Click for fullsize
It''''''''''''''''''''''''''''''''s a hobby - keep it simple
Hide Signatures
(in reply to tamjets)
       Post #: 8
RE: Tailpipe Collapse - 5/9/2013 5:38 PM
Dave Wilshere
Status: offline
I flew up to test fly this model a while back. It had more than three flights and we had run the turbine when I was in Aberdeen a few times., the installation was fine, researching now it seems a known issue on this pipe. It's quite long and basically too thin a gauge material was used for the set up. Long small inlet too.
Dw
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
(in reply to basimpsn)
       Post #: 9
RE: Tailpipe Collapse - 5/9/2013 6:06 PM
mikedenilin
Status: offline
Hi Vin,
I heard that incident. Basically the airframe was bought used and it's over 3 to 4 years old and had been running flawlessly with a P160SX. The new customer bought it and put a 180RX in a 160 pipe that's over 3 years old. To add fuel to the fire, the 180rx has much higher exhaust temperature, 700C. So basically, the extra heat couple with extra hot air flow are choking and softening the exhaust pipe and causing the collapse.
I have a 190R on the same type of airframe, but I use a custom made single wall pipe and a really big Bell mouth to draw sufficient airflow to keep cooling down. It's been 3 years now and running flawlessly.
Like Tam said, a wet start will weaken the pipe. I had a Germany pipe collapsed on me while doing ground test. I had a wet start before, so it might have been damaged.
By the way, I replace my exhaust pipe every 50 flights or so. As one exception just replace one on my F-15 after 200+ flights. It's a Chinese pipe and holds well because I kept 1" distance, and use a factory specified engine size. It's up to the pilots to use common sense not to over stress these pipes by using oversize engines for an extended period of time.
Mike
Global Jet ARF PRO- Air-C-Race-Germany, CNC-Italy, Feibao, Gryphon/Redwings, Der Jet, Jet Legend, & more - globaljetclub.com
Hide Signatures
       Post #: 10
RE: Tailpipe Collapse - 5/9/2013 7:14 PM
tamjets
Status: offline
If the pipe done correct. It should last as long the airframe.
Just watch out for wet start. Any wet start happen. Pay attention to the color of the pipe. If it turn dark purple.
That must replace right away. That the sign of pipe goes to fail any moment.
Golden brown color is normal.
BTW,
Anyone had my pipe last over 200-300 flights.
Please send me my bounus check.
Tam Nguyen
Owner TamJets
Hide Signatures
(in reply to mikedenilin)
       Post #: 11
RE: Tailpipe Collapse - 5/9/2013 7:25 PM
basimpsn
Status: offline
quote:
BTW,
Hide Signatures
       Post #: 12
RE: Tailpipe Collapse - 5/9/2013 7:32 PM
tamjets
Status: offline
quote:
ORIGINAL: basimpsn
quote:
BTW,
I need money to spend for my vacation.
I know alot of you had my pipes over those number of flights.
Don't make me pick up the phone and call you for my bonus check.
Tam Nguyen
Owner TamJets
Hide Signatures
       Post #: 13
RE: Tailpipe Collapse - 5/9/2013 7:54 PM
Joe C
Status: offline
quote:
ORIGINAL: tamjets
BTW,
Your too funny Tam, send me my bonus check, LOL!!!!!
BEST IN THE WEST JET RALLY
www.bestinthewestjetrally.com Oct. 16th-20th, 2013
Hide Signatures
       Post #: 14
RE: Tailpipe Collapse - 5/9/2013 8:21 PM
tamjets
Status: offline
quote:
ORIGINAL: Joe C
quote:
ORIGINAL: tamjets
BTW,
Joe,
How many jets out there I have save from crashing to the ground with pipe failure.
All I need 1% from everyone is enough for me going vacation. Haha.
Tam Nguyen
Owner TamJets
Hide Signatures
(in reply to Joe C)
       Post #: 15
RE: Tailpipe Collapse - 5/9/2013 9:01 PM
alasdair
Status: offline
quote:
ORIGINAL: Dave Wilshere
Dw
Dave,
Thank you for chipping in with first hand knowledge of the aeroplane.  I didn't know that you did its first flight.
Do you know if he used a bypass, or an exposed engine installation?
I wondered if having the whole pipe double walled would have helped?
We were at Machrihanish for the weekend. I think Graham said it was HIS third flight with the model. What a sad loss.
I assume that you can assure me that my CARF Lightning and Eurosport pipes will not suffer the same fate? That was my concern, that caused me to post the question.  I didn't build either model, both are second hand but used original kit parts, and are powered by Booster 160 engines..
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 16
RE: Tailpipe Collapse - 5/9/2013 9:08 PM
Joe C
Status: offline
quote:
ORIGINAL: tamjets
quote:
ORIGINAL: Joe C
quote:
ORIGINAL: tamjets
BTW,
Joe,
True Tam, and 1% is fair,
Hide Signatures
       Post #: 17
RE: Tailpipe Collapse - 5/9/2013 9:57 PM
HarryC
Status: offline
I lost a model due to the Aviation Design pipe collapsing on just the tenth flight. It was a twin wall pipe properly located and not subjected to a wet start. Most of my other pipes are Wren single wall and the oldest has done over 500 flights so there is no relation between the number of walls and the pipe collapsing. What I did find was that the Aviation Design pipe was about 30% thinner steel than my other pipes from Wren and Grumania
Hide Signatures
(in reply to Joe C)
       Post #: 18
RE: Tailpipe Collapse - 5/9/2013 10:06 PM
ron Sweeney
Status: offline
Alasdair, a timely and constructive topic.
I have an F15 eagle with a single outlet. I use a Wren single wall pipe. The model has over 600 flights logged. It does not have a by-pass or a bell mouth. Just the pipe entry turned out a little. The model has been mainly powered by a Wren ss and also by a Wren 70. I have never experienced the slightest problem..
I also have an ancient JMP Phantom with a bespoke bi-furcated pipe which I have just removed because the '' beak'' had a 'wrap around' folded cover which had become detached. Tam, you quoted for this pipe and I decided to buy a less expensive option which I now regret.
I also experienced some very hot starts recently with a Wren 44 gold due to pump problems which have now been sorted. As soon as I read Tams' post I checked the pipe and it was OK. It is also a Wren pipe with a single wrap of thin mineral sheet provided by Wren. I have no connection with Wren other than their close proximity and good customer service.
It would appear to me that the ever increasing use of larger turbines is exposing several vulnerable areas in the design of our jets. Some manufacturers seem to be ahead of the problems and others are trying to catch up at the expense of the customer.
I am curious to discover more about the subject you have raised, Ron.
Hide Signatures
(in reply to Joe C)
       Post #: 19
RE: Tailpipe Collapse - 5/9/2013 10:48 PM
rcand
Last Login: 5/15/2013
Status: offline
quote:
ORIGINAL: alasdair
The tailpipe consisted of a bellmouth, followed by a parallel portion about 6'' long with a single thickness, followed by double walled parallel portion about 20-24'' long.  It was only the first, single walled, part that had collapsed, behind the bellmouth that was still intact.  It was squashed completely flat, with sharp edged creases.
This can occur if the distance between the end of the turbine exhaust cone and the front of the bell mount is not correct.
But
Hide Signatures
       Post #: 20
RE: Tailpipe Collapse - 5/9/2013 10:55 PM
dubd
Status: online
Tam, I had planes with over 200+ flights with your pipe. Perhaps you should get into the replacement stab business too.
Hide Signatures
(in reply to rcand)
       Post #: 21
RE: Tailpipe Collapse - 5/9/2013 11:21 PM
Dave Wilshere
Status: offline
quote:
ORIGINAL: alasdair
Dw
Dave,
Alistair
I had a couple of flights with it when new at Elgin. The pipe set up was for complete bypass, but from memory we left the top cover off. The PST turbine ran quite hot. It was a long tailpipe and a long inlet track that is not huge in area. Last time it was flown before last weekend, I understand it had a heavy landing, so who knows whether something started there or even if the turbine was still centralised in the tube...I didn't know he was taking it to Machrihanish, maybe I would have talked him out of it
Pipes run at all sorts of temperatures, with and without cool-wall outer tubes. Simple fact is a pipe that is too thin or made from the wrong material will fail with heat. Its amazing people don't centralise turbines and get the turbine at the same angle...and many people will never look at the alignment again after the build and some straps allow turbines to move with "arrivals"
CARF pipes are very unlikely to fail!!! Heaviest chunky (overweight ) pipes out there. My original Flash is something over 500 flights, CARF can't get the quality of thinner material in Thailand, so they went for meat...which is fine by me.
Dw
Hide Signatures
       Post #: 22
RE: Tailpipe Collapse - 5/9/2013 11:32 PM
tamjets
Status: offline
quote:
ORIGINAL: dubd
If I was. You guys can't afford my hours rate.
Tam Nguyen
Owner TamJets
Hide Signatures
(in reply to dubd)
       Post #: 23
RE: Tailpipe Collapse - 5/9/2013 11:36 PM
tamjets
Status: offline
The higher thrust turbine require stronger pipe to be safe.
Some of the pipes send to my shop was made out of paper constructed and the factory included with the kit and kit require 36 lbs engine to fly.
How scary.
There will be more pipe collapes incidents coming.
Tam Nguyen
Owner TamJets
Hide Signatures
       Post #: 24
RE: Tailpipe Collapse - 5/9/2013 11:42 PM
tamjets
Status: offline
Dw
Truth...CARF's is so heavy.
You can done with good material and constructed right to save 1/2 the weight.
Tam Nguyen
Owner TamJets
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.234RCU1
