Thrust-weight ratios    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Glow to Electric Conversions >> Thrust-weight ratios Page: [1]
Login
Thrust-weight ratios - 9/21/2003 8:32 AM
toy264
Score: 100
Last Login: 5/12/2008
Status: offline
Has anyone studied the thrust to weight ratio curves of various e power systems compared to glow? There are a lot of reasons to convert to electric, and I'm wondering if there is some point at which a lighter equivilent power is one of them.
John
Hide Signatures
       Post #: 1
RE: Thrust-weight ratios - 9/22/2003 4:44 PM
Matt Kirsch
Score: 105
Last Login: 4/12/2013
Status: offline
I think that traditionally, electric has always been heavier based on sheer power to weight, but it makes up for it somewhat in efficiency. Bigger prop spinning slower in cleaner, less turbulent air allows you to get away with about half as much sheer horsepower in an electric system. Comparitively speaking, glow is like driving a tuner Honda Civic down the road with the emergency brake set. Lotsa wheel spinning, lotsa noise, lotsa smoke, lotsa wasted energy.
LiPolys have screwed it all up Now you have a battery that can produce the horsepower, but doesn't weigh much. With a lightened airplane, a super-efficient geared brushless motor, and lightweight lipolys, you can have power-to-weight ratios that glow can only dream of...
Hide Signatures
(in reply to toy264)
       Post #: 2
RE: Thrust-weight ratios - 9/25/2003 9:58 AM
toy264
Score: 100
Status: offline
So assuming equal weight airframes, a Li powered electric system could be put together that would afford the same performance (say 5 min. of scale manuvers for a 15 lb, 71" P-51) as a typical .91 with 16 oz of fuel, at a lower all-up weight?
Hide Signatures
(in reply to Matt Kirsch)
       Post #: 3
RE: Thrust-weight ratios - 9/25/2003 11:38 AM
gwright
Score: 100
Last Login: 1/17/2013
Status: offline
not exactly, but you could get the same or better performance for 15 to 20 minute flight times
For a "warbird" example, Kyle Mashima is flying an 80" span world models ARF Zero. He's using a 10S4P thunder power lithium setup. It's 17.5 lbs, and has superior performance to glow. Flights can go well over 20 minutes with proper throttle usage.
Another example is my 2 meter funtana, which, with lithium polymers is now under 10 lbs, can fly for 15+ minutes of full 3D, and is spinning a 22X12 at just under 6000 revs (not quite the power of a G62 zenoah, but more than a G45, and on a less than 10 lb plane ). thrust to weight is over 2 to 1
Hide Signatures
       Post #: 4
RE: Thrust-weight ratios - 9/25/2003 5:34 PM
Sprink
Score: 100
Last Login: 6/6/2008
Status: offline
I'm surprised that the top scale flyers haven't yet leapt on to the electrics yet as it can mean running scale props.
I once worked out that the scale prop for the Top Flight Spitfire (a 60 size plane) is a whopping 18" diameter 4 blade prop! Not possible with glow without destroying the plane (nearest you can get is an RCV 120, which can give you an 18" 2 blade or 15" 4 blade). With electrics it is not a problem.
_____________________________
"If it doesn't break, it is probably too heavy"
Hide Signatures
       Post #: 5
RE: Thrust-weight ratios - 9/25/2003 7:35 PM
toy264
Score: 100
Status: offline
Could one of the problems be that without the weight of a G45 and fuel up front, you end up with a tail-heavy model? Having to add lead defeats the idea of gaining an improved wing loading. Nevertheless, not having the hassles of endless mixture tweaking, and the concerns over big engine starting safety issues (search the site on "stitches"), and even a break-even scenario on weight has an e-system looking attractive!
My only electric experience is with a little GWS Moth, but it sure is easy to grab and fly without a 5 lb box of fuel, battery, and starting paraphernalia! Humm, looks like I'd better start getting cozy with ElectriCalc...
Hide Signatures
(in reply to Sprink)
       Post #: 6
RE: Thrust-weight ratios - 9/27/2003 10:36 PM
Henke Torphammar
Score: 100
Last Login: 6/18/2013
Status: offline
toy264,
you can adjust the CG very easy by moveing the battery pack. makes it possible to ballance the plane diffrent depending on if you want to fly perfect pattern or wild 3D.
/Henke
www.youtube.com/henke2
Swist F5D, Lambert Kolibri T25 - 310mph 2012
Hide Signatures
       Post #: 7
RE: Thrust-weight ratios - 9/28/2003 3:07 AM
toy264
Score: 100
Status: offline
Your point is well taken; however, if I have to add heavy batteries to make up for the substitution of, say, a B50 for a OS 91, I haven't gained anything as far as reducing the weight of the powerplant and fuel. Do you suppose mounting the batteries directly under the motor is an option (I've got a huge cowl)? I am really liking the idea of swinging a big prop (21" is the scale size for my project), and not spending as much time tuning as flying!
Hide Signatures
(in reply to Henke Torphammar)
       Post #: 8
RE: Thrust-weight ratios - 9/28/2003 3:13 AM
Henke Torphammar
Score: 100
Status: offline
http://www.rcuniverse.com/forum/upfiles/36728/94538_16077.jpg
yeah, I put them up under the cowl. as the motor is much lighter then a simmular performing engine you need the battery pack pretty far forward.
/Henke
Hide Signatures
       Post #: 9
RE: Thrust-weight ratios - 10/2/2003 3:02 AM
Shawn-Palmer
Score: 100
Last Login: 3/1/2006
Status: offline
Many years ago, I built a CG Superchipmunk for a club friend w/a .60 in it. I flew the holy crap out of that plane before giving it to him ("testing"), and it remained my favorite flying model until I completed my own CG Superchipmunk a while back. Mine is 80oz RTF, and 2:1 thrust to weight, and of course - electric. Ten times the model I built back then, and It's everything I've ever wanted in an R/C plane and more.
Aveox 27/39/2 4.4:1
6S5P LiPo's
19X6 APC
Shawn Palmer
www.CastleCreations.com
shawnp@castlecreations.com
Hide Signatures
       Post #: 10
RE: Thrust-weight ratios - 10/2/2003 6:05 PM
Greg Covey
Score: 136
Last Login: 4/11/2013
Status: offline
Sprink,
Some of them have discovered electric power and won!
Electrics Win Team Scale at 2003 Masters Competition
Visit my Web Hangar at www.gregcovey.com/rc.htm
Hide Signatures
       Post #: 11
RE: Thrust-weight ratios - 10/3/2003 2:27 AM
Hannu Vuorinen
Score: 100
Last Login: 7/23/2008
Status: offline
Yeap, Greg,
Took 1st place in Stand of scale cup in Finland, 3rd in F4C, 4th in Scandinavian
Opens at Stockholm. My fleet was Piper J3 ant FW44 Stieglitz bipe, both outrunner and lipo powered. So, competing in same class with glow/gasoline pilots, they are not unbeatable..
Hide Signatures
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.688RCU1
