FEJ BAe Hawk 1:4,5 -CG    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> FEJ BAe Hawk 1:4,5 -CG
Page: [1]
Login
FEJ BAe Hawk 1:4,5 -CG - 5/22/2013 3:06 PM
Jet-Michi
Score: 100
Last Login: 5/23/2013
Status: offline
...here are some pictures of our new fej hawk cockpit - lot of work but looks good - can anybody tell us the best CG for flying? -thanks a lot. best regards from germany
Hide Signatures
       Post #: 1
RE: FEJ BAe Hawk 1:4,5 -CG - 5/22/2013 3:22 PM
DiscoWings
Score: 102
Status: offline
wow that cockpit looks nice where did you get it and how much?
_____________________________
"Hi,You are 100% correct but are also 100% wrong... "
- rcflip
Hide Signatures
(in reply to Jet-Michi)
       Post #: 2
RE: FEJ BAe Hawk 1:4,5 -CG - 5/22/2013 3:43 PM
Ali
Score: 135
Status: offline
Stunning work on that Cockpit.
My centre of gravity test for the hawk is to have it assembled with no fuel but hopper full. Tilt it so the nose wheel is off the floor and the rear ventral fins are just touching the ground. Release the rudder and the nose should drop down to the ground nice and gently. This is a safe setting, you can fine tune from there. I have flown with Hawks where when I do this test the back stays on the ground but I found it too sensitive on the elevator. If the nose falls to the ground hard, I found it a little nose heavy, which was not too much of a problem with the Hawk, it just means a slightly faster landing speed. I hope this helps?
Regards Al
Al''''s Hobbies. Airworld. BVM, Tams, Jet Cat, AMT, Skymaster, FEJ, pull over, Tomahawk, Skygate, C-ARF, Jet-Teng,Kingtech
Hide Signatures
       Post #: 3
RE: FEJ BAe Hawk 1:4,5 -CG - 5/22/2013 6:34 PM
FenderBean
Score: 119
Last Login: 5/22/2013
Status: offline
nice work
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
(in reply to Ali)
       Post #: 4
RE: FEJ BAe Hawk 1:4,5 -CG - 5/22/2013 6:56 PM
rbxbear44
Score: 100
Status: offline
quote:
ORIGINAL: Ali
Regards Al
If you are looking for an actual point to start with Ali's great way of doing this....look at about 230mm from the front tip of the wing root, NOT the fuse farings. If you do use a CG structure, be certain to take the vertical stands out the end of the main outer gear door since there is some good structure there to settle the weight of the plane on.
What Ali is saying is a great way but this might give you a starting point if you are wanting a measurement.
Rex
Hide Signatures
(in reply to Ali)
       Post #: 5
RE: FEJ BAe Hawk 1:4,5 -CG - 5/23/2013 7:14 AM
Jet-Michi
Score: 100
Status: offline
thank you guys - this will help me.
@discoWing - the cockpit is all selfmade. Pilot is from Skymasterjet.
Hide Signatures
(in reply to rbxbear44)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.297RCU1
