2 stroke vs 4 stroke Comparison?
Tower Hobbies
Logged in as Guest
  Printable Version
90 Degree Muffler Adapter
Seller:  RC Specialties
Details:   $17.95   |  5/19/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> 2 stroke vs 4 stroke Comparison?
Page: [1]
Login
2 stroke vs 4 stroke Comparison? - 9/22/2003 9:24:31 PM
zorka
Status: offline
Hi,
Can anybody point me to a general chart or knows where I can compare power and trust in general when comparing 2 stoke engines vs 4 stroke engines? Not sure this is available but would help me undertand similar power motors in the 2 stroke and 4 stroke sizes.
< Message edited by zorka -- 9/22/2003 9:25:13 PM >
       Post #: 1
RE: 2 stroke vs 4 stroke Comparison? - 9/22/2003 11:03:59 PM
William Robison
Status: offline
Zork:
The accepted ratio is 1.0 to 0.6 displacement. In other words, a 60 2c is the equivalent of a 100 four stroke.
There are many exceptions. For example, the YS engines are much higher in power than this would suggest.
And one airplane that might fly happily with a 4c 80 might need a 2c the same size to fly.
So, as I said, it's a rule of thumb, don't count on it too heavily.
Bill.
_____________________________
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
(in reply to zorka)
       Post #: 2
RE: 2 stroke vs 4 stroke Comparison? - 9/23/2003 12:58:16 PM
snownskate69
Status: offline
That is pretty much correct. For a powerful .46, a .72 fourstroke is just a slight bit more powerful. For a 60 sized engine, a .91 fourstroke is about equal. These rules do change, and like william said YS engines are more powerful than others, a YS .63 has the same power as a .72 of another brand.
(in reply to zorka)
       Post #: 3
RE: 2 stroke vs 4 stroke Comparison? - 9/23/2003 1:30:35 PM
DarZeelon
Status: offline
SnownSkate,
The now defunct YS.53 FZ was stated, on the recommended 30% nitro heli fuel, in a UK review, to be capable of spinning a 12x6 APC at over 13,000 RPM.
I don't think you can show me too many two-stroke .60s that are equally capable.
The replacement YS.63 FZ is pretty powerful, but may be lack-luster in comparison.
Dar Zeelon - ISRAEL - ddzeelon@gmail.com
MVVS - Jett - Nelson - Bolly - Mejzlik
(in reply to snownskate69)
       Post #: 4
RE: 2 stroke vs 4 stroke Comparison? - 9/23/2003 1:32:32 PM
Sport_Pilot
Status: offline
Though a .60 2 stroke may be equal in power to a .91 four stroke there is a big differance. If you want to go fast the higher revs on small high pitched props give the two stroke the advantage. The higher thrust of a larger low pitched prop gives the advantage for aerobatics that doesn't involve high speeds such as the older fast pattern planes, also good for slower and or heavier planes such as many scale models.
But if you put in a .91 two stroke in place of a .91 four stroke then you can do both better.
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.517RCU1
