RE: Gruman Ag-Cat
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: Gruman Ag-Cat
Page: <<   < prev  1 2 [3] 4 5 6 7 8   next >   >>
Login
RE: Gruman Ag-Cat - 11/20/2007 6:06:29 AM
anothercrashpilot
Status: offline
The RIGHT picture posted in the RIGHT Page ! This should help future builders and followers !...........What few pictures I've seen ,I believe they're the same for Both versions........................ It's actually Offset Further than the plans show ! .................But , At least I'll Feel better about mounting it that way knowing it IS correct ! !
(in reply to RedTwilight)
       Post #: 51
RE: Gruman Ag-Cat - 11/20/2007 6:36:53 AM
anothercrashpilot
Status: offline
The plans show the Ailerons to be Top Hinged, .........I have the big Dubro flat hinges , But never tried the HingePoint type ! What type of hinge do Ya'll prefer on the BIG planes, And Dare I ask What is the PROPER way to put the Flat hinges on this type Aileron ? ................AND,,,,,,What kind of Input do you have on the Conceiled SINGLE control arm/joiner for the elevator halves ? ? I'd prefer not to have dual servos if possible and may use controls like RANDY's but with a single servo ? ! ? ! .P.S. I don't have the control rods ETC... or servos YET ! ! ........... But WE HAVE A PAGE 3 ! ! ! ! ! ! ! .........THANKs
(in reply to anothercrashpilot)
       Post #: 52
RE: Gruman Ag-Cat - 11/21/2007 1:19:59 PM
RedTwilight
Status: offline
Here's a couple of more pics. The first shows the aileron push rod on the lower wing. The second is the aileron hinge on the underside of the top wing.
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Parkzone P-51, Hangar 9 P-51 PTS
'96 Mustang Cobra 330hp
       Post #: 53
RE: Gruman Ag-Cat - 11/21/2007 1:28:18 PM
RedTwilight
Status: offline
WHOOOAAAA!!!! Sorry for the huge pics. I thought this thing resized them for you. Just like it did with my previous pics. Man thats huge. But at least you get to see plenty of detail.
       Post #: 54
RE: Gruman Ag-Cat - 11/22/2007 6:05:49 AM
anothercrashpilot
Status: offline
! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ...OH MY GOODNESS ! ! ! ! that IS a Big picture ! ! ! ! ! ! ! ! ! ! ! I've been meaning to get with you about a couple pics.But not sure what they were about right now ? ! ........ It may have been about the specs. / shape of the TURBO front end ,. How much further it extends past the front cabane struts to the prop line ! ? Compared to the Radial version ! ................. Just in case someone where to convert the plans TO Turbo ! It would be nice to know how much further to Extend the front end ! ....................................Ratio/Percent wise ..................................................................THANKs......
       Post #: 55
RE: Gruman Ag-Cat - 11/26/2007 2:51:23 AM
RedTwilight
Status: offline
Well I don't have any specs yet but here is the best side shot of the front of the turbo-Cat.
Click for fullsize
       Post #: 56
RE: Gruman Ag-Cat - 11/26/2007 7:45:15 AM
anothercrashpilot
Status: offline
.....Pretty Good side shot ! .....And this is the Preffered Model ..... There's one kind out there that has a big droop at the front end ! ! ... ! ! ....(A CHIN ! ! ! ).. It looks like the Bottom Keeps the same Taper up to the nose , But the Hood Appears to DROP after the front strut ! ..It Does't seem to keep the same TAPER all the way down from the windshield ? ? ............................... NOW , Do you happen to have a shot of the front showing the OUTLINE under/around the spinner ? ? Or how the FRONT comesTOGETHER ? ? ? ..............................................I'm still messing with the RADIAL version now, But I'm always Thinking of the TURBO ! ! !
       Post #: 57
RE: Gruman Ag-Cat - 11/26/2007 2:14:14 PM
RedTwilight
Status: offline
Still no direct straight on shot. But maybe this will help you out. If needed let me know and I'll go try and get a couple more pics straight on and parallel to the side.
Click for fullsize
Click for fullsize
       Post #: 58
RE: Gruman Ag-Cat - 11/27/2007 8:45:44 AM
anothercrashpilot
Status: offline
HEY, THANKs and I appreciate your time and help ! ! ....I think the Biggest issue will still be to get the Distance from the front of the top front strut ,OR EVEN from the front of the Landing Gear at the bottom corner of the fuse , And out to the Back of the Prop or prop line ,On BOTH the Turbo AND Radial version, For Comparing, so I'll know how far to extend the "Radial" PLANS ! ...................THANKs AGAIN ! ! ! ! ! ! .....................................................................................
       Post #: 59
RE: Gruman Ag-Cat - 12/4/2007 6:56:01 AM
anothercrashpilot
Status: offline
.............. ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ WORMSSSSSS ! ! ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ I guess I hit the Wrong Button ! ? ! ? ! ? ............ .........I don't know How I'll ever get to post Pictures ,,,,, Just getting on THIS Page with the BIG picture just about Shuts down my Computer ! ! ! ....SERIOUSLY ! ! !... ANYHOW,,,,,,,,, I'm just skipping around on my plane, Need to order more Parts but I've hit a Financial WALL ! ! ! ! DDUUUUUHHHHHHHHH................ I have the Tail group Framed and Hinged , But need to finish Pinning the Hinges with Wire nails Before I Sheet them.......... ......... Horizontal group is 44" wide and a 23" tall Rudder ! ! ........... And I will take PICTURES Before and After ! ! ! .......Slowly but Surely................
       Post #: 60
RE: Gruman Ag-Cat - 12/4/2007 7:01:50 AM
outacontrol41
Status: offline
Hey crash....downsize your pictures before you post 'em and only post 2 or three at a time. Wanna see what you're up to....get those pictures up!!!!!
       Post #: 61
RE: Gruman Ag-Cat - 12/14/2007 2:04:47 PM
D.R.BOWERS
Status: offline
Hi to all.
I have found a great book on the ag-cat. It is called the ageless ag-cat. The ISBN is 0-963-0731-1-7. It is full of great detail. Hard back 117 pages long.
Good flying.
Dale
(in reply to outacontrol41)
       Post #: 62
RE: Gruman Ag-Cat - 12/15/2007 12:33:00 PM
RedTwilight
Status: offline
Does not anyone still post here. To long this thread has gone without significant posts. Anyone who is building or working on an AgCat please post. Also anymore info on the Cat from Duane Habets?
(in reply to D.R.BOWERS)
       Post #: 63
RE: Gruman Ag-Cat - 12/22/2007 12:34:24 AM
mac49
Status: offline
Well, I'm working on a 33% scale based on Floyd Fitzgeralds plans from
