RE: Gruman Ag-Cat
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: Gruman Ag-Cat
Page: <<   < prev  1 2 3 4 5 [6] 7   next >   >>
Login
RE: Gruman Ag-Cat - 4/6/2008 3:40:48 PM
Agpilot25
Status: offline
I am building the 90'' agcat from Floyds plans. I am trying to figure out what engine to use. I wanted to put a Saito 325 radial but my funds just doesnt allow that I was wondering what 4 stroke I could use? A saito 170 radial or 200 single cylinder? What would you guys recomend I am going to put a hopper and spreader on it to simulate dust.
(in reply to corcguy)
       Post #: 126
RE: Gruman Ag-Cat - 4/6/2008 4:16:05 PM
gjmjoe017
Status: online
I am sure some other guys will jump in on this,but the Saito 220 is only 36cc displacement and this plane will probably come in at 25lbs or more.One of the guys is using a 3w 75 I think and I would think it would take at least that to give it good power.Just my two cents.
(in reply to Agpilot25)
       Post #: 127
RE: Gruman Ag-Cat - 4/6/2008 4:41:27 PM
outacontrol41
Status: offline
I'll jump in. You might consider getting this bad boy....a lightweight 50 cc. This will haul the AgCat around with ease. I don't know of any 4 stroke that will haul a 25 lb. plane. On the other hand, if you try to build light and your plane ends up at about 20 lb. AUW you may be okay with that Saito.
BTW, check out the price of the XYZ 50, read A-F-F-O-R-D-A-B-L-E !
http://www.southeastengines.com/see_002.htm
(in reply to gjmjoe017)
       Post #: 128
RE: Gruman Ag-Cat - 4/6/2008 5:27:08 PM
gjmjoe017
Status: online
The other 50cc to look at is the DL 50.It's a knock off of the DA 50 and there are some really good reports on how well it runs.
www.dlusa.net
< Message edited by gjmjoe017 -- 4/6/2008 7:13:56 PM >
(in reply to outacontrol41)
       Post #: 129
RE: Gruman Ag-Cat - 4/6/2008 6:28:18 PM
outacontrol41
Status: offline
r u sure that's the correct URL address?
       Post #: 130
RE: Gruman Ag-Cat - 4/6/2008 6:30:52 PM
gjmjoe017
Status: online
Sorry about that,it's
www.dlusa.net
Those .net will get ya every time!!!
       Post #: 131
RE: Gruman Ag-Cat - 4/13/2008 12:12:40 AM
Agpilot25
Status: offline
I appreciate the help on engine choices I finally decided to save up and get the saito 325 radial it just sounds so good. I am a cropduster and fly an agcat myself so I just got to get the radial for it. Also what are you all using for flying wires?
       Post #: 132
RE: Gruman Ag-Cat - 4/16/2008 12:24:53 AM
mac49
Status: offline
Ok here''s the gear. I tried to follow Floyd''s plan but my over-engineering got the best of me. The LG is made by TNT from 5/16" 6061, wheels are 8.5" from a mountain skate board. They come with 10mm bearings and I''ve inserted bushing I made at home from stock bought from Aricraft Spruce. The fuselage where the LG attaches is not quite 1/4inch ply with a 1/8 door skin doubler. I used a 2 inch wide by 3/4 inch fir backer for the LG. There are a couple of 3/4 inch plywood clamps on the end to help spread dynamic loads to the doublers. Its all glued and screwed together. It''s attached with six 10-24 cap screws with nylock nuts. The tailwheel needs more work. I manufactured it from 1 1/2in x 1/4 in 6061 bar stock. I didn''t get it bent as nicely as TNT. The caster frame is cut from 3/32 in 3003 and also needs some correction. Thats a 4" Dubro wheel but it wan''t ment for a tail wheel. I''m probably going to need to drill it out an put in a brass tube insert.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by mac49 -- 4/16/2008 12:28:23 AM >
(in reply to anothercrashpilot)
       Post #: 133
RE: Gruman Ag-Cat - 4/16/2008 1:48:38 AM
outacontrol41
Status: offline
Nice work so far. Looks really huge.
(in reply to mac49)
       Post #: 134
RE: Gruman Ag-Cat - 4/16/2008 3:53:13 AM
mac49
Status: offline
I''m actually working in the living room of an old cottage my wife and I own. Gives me a 13 X 15 foot work area. (I also have the rest of the house but the rooms are pretty small. You get use to the pink interior after awhile.) I don''t have the 4 X 8 foot work bench situated where I can assemble it. ( I have a row of book cases taking up the wall opposite the window in front. I clamped it together a few weeks ago to get the feel for how it is going to go together. Looked pretty good to me. It took up most of my side of our two car garage. My wife''s Pathfinder sat on the other side in the photo. It will certainly look nice parked on the runway the first time after I get it done. It''s going to be a while though.
       Post #: 135
RE: Gruman Ag-Cat - 5/9/2008 5:59:22 AM
outacontrol41
Status: offline
Keith....
What's the latest on the DH Ag Cat ARF development? Been quiet here for a while....
(in reply to mac49)
       Post #: 136
RE: Gruman Ag-Cat - 5/15/2008 5:15:59 PM
RedTwilight
Status: offline
quote:
ORIGINAL: outacontrol41
Keith....
+1 How's the build coming?
_____________________________
Parkzone P-51, Hangar 9 P-51 PTS
'96 Mustang Cobra 330hp
       Post #: 137
RE: Gruman Ag-Cat - 5/17/2008 2:56:52 PM
wiz310
Status: offline
are you familiar with the Saito FG36?. a big four stroke gasser. will haul that bad boy around with ease and sound good, as well as giving you a nice slow idle and fly on tiny amounts of fuel.
thread is here. http://www.rcuniverse.com/forum/m_5041020/tm.htm
< Message edited by wiz310 -- 5/17/2008 3:18:50 PM >
(in reply to RedTwilight)
       Post #: 138
RE: Gruman Ag-Cat - 5/17/2008 6:31:24 PM
51-D GUY
Status: offline
Hey Keith,
What's going on with the Ag-Cat ARF ?
Send us some pics, Any info on when the kit's will be available ?
Give us a Update !
51-D GUY.
(in reply to wiz310)
