Matt Kirsch
Joined: 7/5/2002 From: Rochester, NY, USA Status: offline
Gave the Astro a whirl last evening. It couldn't be simpler to use. Start with the current dial at 0, plug in the pack, and dial the desired current. It had absolutely no trouble identifying the almost-charged 3-cell packs I attached to it. Watching the display is pretty neat, as once the charger reaches a certain point, it starts pulse-charging the cell. It'll give the cell a quick blip of juice, the voltage will spool up on the display, then it will spool back down. If the cell doesn't hold its full voltage, another quick blip of juice. It will continue pulse charging until the battery holds its full voltage for some predetermined length of time. I can see where the aggressive cooling fan may annoy some people, but the beeper is pleasant and the only times the charger makes noise is when the battery finishes charging, or you do something stupid like disconnecting the pack... So far, I like it.
