RE: post some pictures of your pattern plane!!
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> RE: post some pictures of your pattern plane!!
Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: post some pictures of your pattern plane!! - 12/15/2005 1:40 PM
Vyciukas3045
Score: 100
Last Login: 11/18/2009
Status: offline
Hello,
Here is my "Diablo Top FG" by JR Models (www.jr-models.com). I slighty improoved its color scheme and changed genuine name into more optimistic "Allegro". It is powered by Thunder Tiger 120 PRO with Perry pump, turning 16x8 APC prop. It flies quite well, but not the way I really like. So I am looking for a 2x2 plane for the next year...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to flyjohn)
       Post #: 226
RE: post some pictures of your pattern plane!! - 12/19/2005 3:43 AM
balsabuster2003
Score: 105
Last Login: 11/21/2009
Status: offline
subscribing.
_____________________________
non impediti ratione cogitationis
Hide Signatures
(in reply to Vyciukas3045)
       Post #: 227
RE: post some pictures of your pattern plane!! - 12/20/2005 1:34 AM
rptrsn
Score: 100
Last Login: 6/19/2009
Status: offline
MK joker
Click for fullsize
Hide Signatures
(in reply to balsabuster2003)
       Post #: 228
RE: post some pictures of your pattern plane!! - 12/20/2005 2:38 AM
PatternPilot
Score: 100
Status: offline
How about a pattern foamy.... Great for practice for the 2M ship !!!
Scott Anderson
Team PMA
Team Tanicpacks.com
Click for fullsize
Click for fullsize
Check out www.classic-patternrc.com
Hide Signatures
(in reply to rptrsn)
       Post #: 229
RE: post some pictures of your pattern plane!! - 12/20/2005 11:39 AM
flht99b
Score: 100
Last Login: 9/3/2009
Status: offline
Modified EMC2. OS140RX, ES pipe, Futaba, PPG/Monokote, weighs 10lbs 7ounces. Second one in progress. Ed.
Click for fullsize
Hide Signatures
(in reply to iflyrctoo)
       Post #: 230
RE: post some pictures of your pattern plane!! - 12/21/2005 4:42 PM
waltervh
Score: 100
Status: offline
What prop are you using os the OS.Does it work ?
Hide Signatures
(in reply to flht99b)
       Post #: 231
RE: post some pictures of your pattern plane!! - 12/22/2005 1:07 AM
Chris-B-chips
Score: 100
Last Login: 12/31/2007
Status: offline
I dont know about flht99b but i use an APC 17x12 narrow blade. it stops the motor from bogging up in the verticals so it is always producing the same amount of thrust. if your looking for dowline braking go the 17x12 normal blade. the only issue i find is that it really loads up in the verticals, especialy after a vertical snap.
regards Chris
Hide Signatures
(in reply to waltervh)
       Post #: 232
RE: post some pictures of your pattern plane!! - 12/22/2005 6:35 PM
flht99b
Score: 100
Status: offline
I use an APC 15.75 x 11 APC 3 blade prop. It starts life as an APC 15.75 x 13 prop that Dave Lockhart re-pitches to an 11 pitch. On 20/18 S&W I typically see 7700 to 7800 rpm at take off. Unlimited vertical with my 10lb 7ounce EMC2, very, very slow down lines and nice relaxed flying pace. Pipe is an ESD2C140S9 from Central Hobbies. Header is Macs 2 1/4" rise run at full length and about 3/8" between the end of the header and the neck of the pipe.
Ed M.
Hide Signatures
       Post #: 233
RE: post some pictures of your pattern plane!! - 12/23/2005 7:57 PM
KrisG
Score: 100
Last Login: 11/19/2009
Status: offline
Aerostar 62 ( Dave Smith models) - not a fully blown pattern ship, but great for practice. MVVS 49 ( inverted) and Hanno pipe
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 234
RE: post some pictures of your pattern plane!! - 12/27/2005 9:52 PM
xcead
Score: 100
Status: online
hi: I just couldnt wait, this is my own desing called "voltige" , based of course on many of today F3A models
OPINIONS WELCOME !!!!!!
wingspan: 55"
length:57"
I hope you like it
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to KrisG)
       Post #: 235
RE: post some pictures of your pattern plane!! - 12/31/2005 10:06 PM
Ryan Smith
Score: 100
Status: offline
My PLProd Partner and Piedmont Hydeout. The guy in the picture with the Hydeout is my buddy Joey Hayes. I got both airplanes from him and he has helped me tremendously in the hobby.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ryansmith -- 12/31/2005 10:07 PM >
Team Horizon, Evil-R/C Products, YS
Hide Signatures
(in reply to xcead)
       Post #: 236
RE: post some pictures of your pattern plane!! - 1/7/2006 3:05 AM
Zeneith
Score: 100
Last Login: 11/10/2007
Status: offline
quote:
ORIGINAL: Dominique ACM
hello Zeneith,
Could you please give us more informations about this Model (Beam) ?
DG
Hi Dominique ACM,
Here are the specifications of the Mega Model's Beam as per the manufacturer information
Fusalage Length: 1990 mm.
Wing Span: 1883 mm.
Wing Area 62.5 Sq. Dm.
Engine 1.40-1.60
Weight: 4.5-4.8 Kg.
My Beam installed
Motor : HACKER C50 14 XL Gear 6.7 :1
Batt : Li poly 5S4p x 2 packs = 37 Volts.
Weight: 5 Kg (Inc. Batt)
They have 2 versions F-3A and 3D, here are some pics of their 3D version...It is pretty cool airplane!!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Dominique ACM)
       Post #: 237
RE: post some pictures of your pattern plane!! - 1/7/2006 9:49 AM
troyhm
Score: 100
Last Login: 10/2/2009
Status: offline
Hi
Does Mega Models have a website at all ???
Troy
Hide Signatures
(in reply to Zeneith)
       Post #: 238
RE: post some pictures of your pattern plane!! - 1/9/2006 2:02 AM
Zeneith
Score: 100
Status: offline
Hello Troy,
They have the website as below
http://www.mega-rcmodel.com
By the way they have not yet update the Beam to their sever.
Hide Signatures
(in reply to troyhm)
       Post #: 239
RE: post some pictures of your pattern plane!! - 1/9/2006 4:38 PM
Farshid
Score: 100
Last Login: 9/22/2006
Status: offline
Hi: Beautiful pattern models, but pattern models are more beautiful when they are in action. Why not having archive of video clips of them. Pattern acrobats with description of how to perform it.
Thankx
Farshid
Hide Signatures
(in reply to mups53)
       Post #: 240
RE: post some pictures of your pattern plane!! - 1/9/2006 5:17 PM
Farshid
Score: 100
Status: offline
Here is some of my models. Venus 40 with tuned pipe, PC 9 with OS 46 Fx & Patriot 40 slightly modified with OS 46FX
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Chris-B-chips)
       Post #: 241
RE: post some pictures of your pattern plane!! - 1/10/2006 8:23 AM
perttime
Score: 100
Last Login: 11/16/2009
Status: offline
quote:
ORIGINAL: Zeneith
Mega Model's Beam
I cannot help it: the Beam reminds me of the Kelly F-1d racer
http://www.usrainfo.org/images/Parker2005/slides/DSCN0822.html
Hide Signatures
       Post #: 242
RE: post some pictures of your pattern plane!! - 1/10/2006 9:49 AM
Zeneith
Score: 100
Status: offline
quote:
ORIGINAL: perttime
quote:
ORIGINAL: Zeneith
Mega Model's Beam
perttime: Great link you have convinced me to belive that I just bough the pylon racer...No it fly far smoother.
Troy: I just found that this morning...take a tour
http://www.mega-rcmodel.com/index.php?lay=show&ac=photo_view&event_id=1141
Hide Signatures
(in reply to perttime)
       Post #: 243
RE: post some pictures of your pattern plane!! - 1/10/2006 12:59 PM
kennyandannie
Score: 100
Last Login: 8/9/2009
Status: offline
Well here are both of mine,
LA-2 with a YS 91ac and my new El Nino with a YS 140L
Ken
Click for fullsize
Click for fullsize
Ken Thompson - Team Black Magic - Team DragonFire
Fellowship of Christian Modelers
Hide Signatures
       Post #: 244
RE: post some pictures of your pattern plane!! - 1/10/2006 1:00 PM
kennyandannie
Score: 100
Status: offline
quote:
ORIGINAL: Farshid
Thankx
Farshid
I agree!!
Hide Signatures
(in reply to Farshid)
       Post #: 245
RE: post some pictures of your pattern plane!! - 1/10/2006 8:49 PM
xcead
Score: 100
Status: online
great idea, try this material
http://www.rcuniverse.com/university/showtopic.cfm?topicid=13&level1=1&classid=25
and here you have a video, not FAI, but advanced or masters, in Spain, its a training day with a Lazulite
http://www.acro3d.com/articulos/lazulite/lazulite.htm
Hide Signatures
(in reply to kennyandannie)
       Post #: 246
RE: post some pictures of your pattern plane!! - 1/11/2006 12:46 PM
Jeff-RCU
Score: 100
Status: offline
Here's my Elite
Click for fullsize
Jeff
Hide Signatures
(in reply to xcead)
       Post #: 247
RE: post some pictures of your pattern plane!! - 1/11/2006 3:31 PM
xcead
Score: 100
Status: online
and this is my Kwik Fly MK III
Click for fullsize
Hide Signatures
(in reply to Jeff-RCU)
       Post #: 248
RE: post some pictures of your pattern plane!! - 1/11/2006 3:58 PM
guille2006
Score: 100
Status: offline
Hello; this is my first appearence in this forum... and my Panther with a GMS 120!!!!!!!
Cheers from Argentina!!
Click for fullsize
Whatever you think you can or you can''t, you''re rigth!!!
Hide Signatures
(in reply to xcead)
       Post #: 249
RE: post some pictures of your pattern plane!! - 1/16/2006 4:54 AM
McFlyboy
Score: 100
Last Login: 4/30/2009
Status: offline
Dave smith Excelsior 150 with piped MDS 48,
And crescent bullet(sports more than pattern) with MDS 40
Click for fullsize
Click for fullsize
true scotsmen fly free under their kilt
Hide Signatures
(in reply to guille2006)
       Post #: 250
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.719RCU1
