RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!)
Page: <<   < prev  114 115 [116] 117 118 119 120 121 122 123   next >   >>
Login
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 7/7/2012 4:13 AM
flyboy12
Score: 100
Last Login: 5/12/2013
Status: offline
You ought to come out to WBOTX next year and have some fun with us. Good luck and have some serious fun. Keep us posted on the flying
Hide Signatures
(in reply to Valve floater)
       Post #: 2876
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 7/8/2012 7:03 PM
Valve floater
Score: 105
Last Login: 3/7/2013
Status: offline
Ok. I got the half and full flaps to work on the c switch. I had to take the servo horn and put it in a diff. position on the spline then re-adj. end points. Thanks Richard. Now i`m working on that blasted tail gear doors. Too tight rubber band to close them and tail wheel won`t pop out. Too loose and one door won`t close. Now replacing hinges and remounting doors. I`m thinking about attaching the rubber band or fishing string directly some where to the retract itself so the doors will open and close. Any ideas? Using Robart air retracts.
_____________________________
Always looking towards the sky.
Hide Signatures
(in reply to flyboy12)
       Post #: 2877
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 7/8/2012 7:41 PM
fujiman
Score: 103
Last Login: 5/16/2013
Status: offline
air system and cyl. size could be the problem. not enough power to overcome rubber bands, go electric or servo and those doors will operate just fine.
Hide Signatures
       Post #: 2878
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 7/14/2012 1:27 AM
kochj
Score: 143
Last Login: 5/15/2013
Status: offline
on prev. page I saw the mention of using the servo speed programming to control flap deploy...
That is a great way to control ballooning...
I used the slider switch on my Futaba 9cap to control flap speed deployment.
My Hitec A9 has the capacity to edit the speed of servos, but I still used the slider switch..
My futaba 18mz.. has that and much more....
I have yet to fly with it so not sure what I will use...
I wouldn't say that it is necessary to have, but it is nice to program as it takes out some pilot responsibility
so one can concentrate on the landing.....
The 9c and 10c do not have the servo speed programming from radio...but you do have the option to use the s.bus receiver/servo or a s.bus box that allow servo speed, and endpoints to be adjusted independently...
If you can''''t dazzle em with brilliance,baffle em with BS
Hide Signatures
(in reply to fujiman)
       Post #: 2879
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 7/14/2012 4:54 AM
Leroy Gardner
Score: 116
Last Login: 5/1/2013
From: Coeurd'''''''''''''''''''''''''''''''' ALENE,
Status: offline
quote:
ORIGINAL: Valve floater
The system for those doors used on the ARF works really well and it uses bands but you could also use small springs. I think the proper location is important and the wheel will also help to kick the doors open. Centering springs need to be used to keep wheel centered and not bind up when lowering gear, also don't lower or close except in straight flight.
Couple of pict's. of how mine is coming along, also my finished 4 blade prop Leroy
Click to see fullsize image.
Click for fullsize
Click for fullsize
Leroy Tiger Club # 53, TF 1/5th P-51 mustang
Eagle 2'' bashed Tiger 60
Hide Signatures
       Post #: 2880
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 7/14/2012 5:22 AM
Valve floater
Score: 105
Status: offline
Nice job. Got the doors working now. I used 3m hinge tape for a quick fix now. Trying to epoxy the small hinges was a mess. I also tried to hook the rubber bands from the retract section directly to the doors. Seemed like a good idea but they wouldn`t close all the way. I have seen some tail wheels doors online where they use solid linkage from the retract to the doors. Seems to work good w/o rubber bands.
Hide Signatures
(in reply to Leroy Gardner)
       Post #: 2881
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 7/30/2012 4:28 AM
Valve floater
Score: 105
Status: offline
My Mustang is weighed in at 25lbs without fuel. What is the average Mustang weight of fellow flyers here?? Is mine too heavy? Looks like i am on the upper end of the spec`s.
Hide Signatures
       Post #: 2882
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 7/30/2012 9:06 AM
Thunderbolt47
Score: 111
Last Login: 5/18/2013
Status: offline
Mine is 25lbs on purpose. That is the weight I like to fly mine at.
Yes it will fly fine.
Greg Norman said, "Happiness is a long walk with a putter." Obviously he never flew a P-51 Mustang. :)
Hide Signatures
       Post #: 2883
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 7/30/2012 1:09 PM
CRJDriver
Score: 100
Last Login: 5/17/2013
Status: offline
Agreed. 25 pounds is very typical for this model and flies extremely well at this weight.
Hide Signatures
(in reply to Thunderbolt47)
       Post #: 2884
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 7/30/2012 11:22 PM
Valve floater
Score: 105
Status: offline
Thanks for the input. I always thought lighter is better. But 25lbs is within spec`s/
Hide Signatures
(in reply to CRJDriver)
       Post #: 2885
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 7/31/2012 12:30 AM
flyboy12
Score: 100
Status: offline
The weight is always good when it is windy, espicially if you live in the Texas or Oklahoma panhandle.
Hide Signatures
       Post #: 2886
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 7/31/2012 3:19 AM
Mikecam
Score: 120
Status: offline
Weight is the enemy. 25 lbs sounds about right for a glassed bird. Mine is 19 lbs 15 oz. Flies better then all the others because it is light. Does enormous loops just like the real ones and almost stops in flight to land. No elevator at all with flaps down for me. The DLE 55 with a xoar 21x10 pulls it unlimited straight up. I'll live with the covering with how well it flies.
http://www.youtube.com/watch?v=oAvSLOlIkG8&list=UUSeX7ol_mWbPk4_hkTQ-OqQ&index=2&feature=plcp
Click for fullsize
Hide Signatures
       Post #: 2887
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 7/31/2012 3:48 AM
Valve floater
Score: 105
Status: offline
Where did you get the 21-10 prop? Maker. thanks. I`m will try a Zoar 22-8 prop. 50cc. 22-10 may overheat my engine in our southern hot temp.`s here lately. 21-10 sounds worth a try.
Hide Signatures
(in reply to Mikecam)
       Post #: 2888
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 8/2/2012 1:07 AM
bucho
Score: 100
Last Login: 4/21/2013
Status: offline
22x10 reheat my DLE 55, I try a 20X10 MASTER CLASIC ( wich is out of the DLE 55 grafics ) saunds and flys great my p51, what do ya think ?
Hide Signatures
       Post #: 2889
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 8/8/2012 10:33 AM
fireynz
Score: 100
Last Login: 5/11/2013
Status: offline
Has anyone had a problem with the torque link assemblies on there robart air retracts splitting where they contact the metal block on the strut?
I brought my retracts from Tower approx 2 years ago and have just recently finished my Topflite 1/5 giant mustang arf running a dle 55.
After 3 flights i noticed the wheel had extended further into the wheel well when the wheels were retracted and noticed the torque link had cracked where it meets the metal block on strut allowing the wheel to extend out and nearly jam in the wheel well.I then checked the other and a crack was starting to appear.
I have ordered 2 more from robart and contacted their tech people but have not received a reply yet as to whether this a common problem or if they have modified the link assembly.
I too have soft mounted my engine to lesson vibration and are very happy with the plane and are grateful for all the modifications supplied
Any help on this problem would be appreciated.
Hide Signatures
(in reply to bucho)
       Post #: 2890
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 8/8/2012 11:06 AM
fireynz
Score: 100
Status: offline
I had the same problem with mine when the retract came out too fast and the cylinder parted.
The ring is pressed in from factory so when it popped out it would not stay in
I put the cylinder together and put 5 or 6 centre punch marks around end where the ring fits in.
Hope this helps.
Hide Signatures
(in reply to RoysterDW)
       Post #: 2891
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 8/8/2012 12:19 PM
CRJDriver
Score: 100
Status: offline
It is unusual for this to happen after such a short time.  I have nearly 500 flights on my P-51 and have only had to replace one set of torque links. Very reliable gear.
Hide Signatures
(in reply to fireynz)
       Post #: 2892
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 8/9/2012 6:27 PM
spitfire66
Score: 105
Status: offline
I was getting ready to order my aerotech models drop tanks last night, when I discovered the company has sold. I was not able to order anything and I called the phone number posted on the website. I talked to previous owner and everything is gone, and he is not sure if the new owners will be offering parts, accessories, or new airplanes. I was really wanting the drop tanks and pylons, and I am kicking myself for not ordering them sooner. Does anybody know where to find these or have any for sale? I was also wanting there wheels, but there are plenty of places to get wheels. I would think the new owners would offer these parts, or else why would you buy a business. If you know any information about this I would sure like to hear it. I thought they made outstanding products.
Hide Signatures
(in reply to splais)
       Post #: 2893
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 8/9/2012 6:31 PM
v6goose
Score: 105
Status: offline
That is terrible news...
"Oh yeah, Kiwi''s can fly..."
http://www.goosesworld.com
Hide Signatures
(in reply to spitfire66)
       Post #: 2894
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 8/9/2012 6:41 PM
spitfire66
Score: 105
Status: offline
Yep, makes me wonder what I was waiting for??? Lesson learned, in the rc world order what you want when you can. It may not be there when you ready to order it. I would sure think the new owner would continue making these and revamp the business, or why else would you buy it? Time will tell...
Hide Signatures
(in reply to v6goose)
       Post #: 2895
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 8/10/2012 5:23 PM
Bdsbob
Score: 100
Last Login: 5/14/2013
Status: offline
Anyone have a picture of the ARF with Sierra retracts including the scale door arms and the doors supplied with the ARF?
Hide Signatures
       Post #: 2896
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 8/12/2012 1:18 AM
fireynz
Score: 100
Status: offline
I finally received reply from Robart re-cracked and broken torque links on my mustang retracts and was given no possible explanation.
There answer was to send back retracts to them and they will look at them.
I do not want to wait a month for the return of them
I have ordered 2 replacements but are still sceptical that that issue will not happen again
I showed them to an experienced builder at our club and we both agreed that it looks like a weak point however if this happens again I will weld a saddle on the torque link where it contacts the block on the strut.
Hide Signatures
(in reply to Bdsbob)
       Post #: 2897
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 8/12/2012 1:35 AM
aghost
Score: 100
Status: offline
Bdsbob: Got the Sierra retracts, ARF gear doors, but just bent wire for the door arms. Seems to be working OK.
Brian
Hide Signatures
       Post #: 2898
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 8/12/2012 1:55 AM
fireynz
Score: 100
Status: offline
Here is a picture of my cracked torque link on my robart retract.
Has anyone seen this happen before?
Click for fullsize
Hide Signatures
(in reply to aghost)
       Post #: 2899
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 8/12/2012 4:17 AM
fireynz
Score: 100
Status: offline
Has anyone got a picture for the set up of their choke mechanism for a DLE55 engine on a topflite mustang 1/5 giant arf?
I do not want to add another servo so after a manual linkage system.
At the moment I have a small hole in cowl and insert a thin screw driver to activate choke but this is sometimes difficult to locate hole in choke lever.
Hide Signatures
       Post #: 2900
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
