RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!)
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!)
Page: <<   < prev  56 57 [58] 59 60 61 62 63 64 65   next >   >>
Login
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHA... - 2/24/2008 9:01:17 PM
Pylon2
Status: offline
My plane is the ARF version which was weathered and then sprayed with a satin fuel proofer to preserve the finish by a friend of mine.
My is powered by a Zenoah 38cc and is adequately powered. I use this in flying competitions in the UK. Cheers Richard.
Click to see fullsize image.
Click for fullsize
(in reply to Doomking)
       Post #: 1426
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISH... - 2/25/2008 12:44:01 AM
AirWizard
Status: online
What size prop are you using on the revolution 52?
_____________________________
David
____I'm having a Yak Attack_____
(in reply to Pylon2)
       Post #: 1427
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISH... - 2/25/2008 1:21:09 AM
n9331v
Status: offline
On my Revolution I run a 20X10
Mooney N9331V
(in reply to AirWizard)
       Post #: 1428
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISH... - 2/25/2008 4:08:34 AM
nicjul01
Status: offline
Great thread guys. Just looking for a little advise on what the opinion is out there on firewall for this plane. I have the RTC version and planning to go with a 50 - 60cc gasser. When I look on the inside of the firewall I see some plywood on the two sides but all around it is bala. Just wondering if I should beef it up some perhaps tie it into the airframe a bit stronger with glass or additional plywood. Any suggestions would be great. Thx
(in reply to n9331v)
       Post #: 1429
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISH... - 2/25/2008 5:24:07 AM
Flyfast1
Status: offline
I have the ARF version with a Taurus 52cc engine and thought that some additional support would be good. I added reinforcement using heavy weight fiberglass cloth with epoxy. I used several layers of cloth overlapped in different directions. But remember that this particular bird usually comes out nose heavy, so whatever is added will have to be counterbalanced with weight in the tail. I put one of my receiver batteries in the tail behind the tail wheel and the other one in the air scoop behind the wing.
-Ed B.
(in reply to nicjul01)
       Post #: 1430
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISH... - 2/25/2008 1:02:16 PM
dasintex
Status: offline
n9331v;
How has your Revo been working out? I will be putting one in mine, any tips!
       Post #: 1431
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISH... - 2/25/2008 2:13:39 PM
n9331v
Status: offline
I had to do a lot for cooling, unlike a DA 50 or the like. With these engines the cylinder portion is not what overheats, it's the crankcase. I installed the fan and shroud and also had to make cowl flaps to keep mine from overheating. I also found it helps to set the mixture quite a bit richer than usual.
Mooney N9331V
(in reply to dasintex)
       Post #: 1432
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHA... - 2/25/2008 3:50:01 PM
Novato
Status: offline
thanks a lot for the info.
Mauricio
       Post #: 1433
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHA... - 2/26/2008 5:28:08 PM
bblizzard
Status: offline
hi guys, great thread
i have the arc version and i'am battleing with myself on two schemes.
i don't want to glass and paint no very good at it, so i have narrowed it down to the OLD CROW ORIGINAL OLIVE DRAB PAINT SCHEME that i would do with solartex/worldtex fabric with clear over it, or the RED DOG SCHEME that would be done in crome ultracote and brushed with 0 stell wool. wich one would look more realistic? i like both, opinions are welcome!
THANK, BRAD
Click for fullsize
Click for fullsize
(in reply to Novato)
       Post #: 1434
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHA... - 2/26/2008 8:31:58 PM
eugene
Status: offline
I've done the Red Dog XII scheme.....If you'd like to see it, I need your Email address.......
(in reply to bblizzard)
       Post #: 1435
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHA... - 2/26/2008 8:58:15 PM
bblizzard
Status: offline
hi eugene,
its kentuckianatruck@yahoo.com. is the crome ultracote the best way to go on that scheme, if im not painting?
brad
(in reply to eugene)
       Post #: 1436
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISH... - 2/26/2008 10:53:14 PM
nicjul01
Status: offline
Thanks Ed for the response I will do the same.
(in reply to Flyfast1)
       Post #: 1437
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHA... - 2/27/2008 12:50:27 AM
Novato
Status: offline
quote:
ORIGINAL: bblizzard
THANK, BRAD
Brad, this is exactly the same issue I'm battling with, but I'm planning Flite Metal for mine, if I decide to go that way.
Mauricio
       Post #: 1438
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHA... - 2/27/2008 1:50:42 AM
nchrome
Status: offline
Brad this is the colors that I'm going with. This is about the fourth time that I've had to repaint the nose cause just about every time some of the tape pulls off a little here or there. I'm going to try one more time then I just don't know what I'm going to do maybe vinal tape. Or maybe I should go with the colors of the third photo?
