RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!)
Tower Hobbies
Logged in as Guest
Users viewing this topic: Warbird Alley
  Printable Version
Hangar 9 P-47 D Thunderbolt - 150
Seller:  ace123jim
Details:   $1,475.00   |  7/8/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!)
Page: <<   < prev  56 57 58 59 [60] 61 62 63 64 65   next >   >>
Login
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 3/14/2008 2:49:16 PM
fancman
Status: offline
Anyone seen these Graphics packages? Looks pretty good.
http://stores.wildmanngraphics.com/Categories.bok?category=WW+2+Airplane+packages
(in reply to Novato)
       Post #: 1476
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 3/14/2008 3:13:59 PM
v6goose
Status: offline
Cool...
Another supplier to add to the list for future projects...
Cheers
Goose
_____________________________
"It''s a fine line between Hobby and mental illness..."
http://www.goosesworld.com
(in reply to fancman)
       Post #: 1477
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 3/15/2008 3:42:26 AM
gunny11
Status: offline
Yeah, Thats where I got mine from. Go ahead and click on p-51 package 3 OLD CROW and see what comes up.
Gunny
HOME OF THE MILLENIUM FLIGHT STATION 2000
(in reply to v6goose)
       Post #: 1478
RE: Scale cockpit - Wow - 3/20/2008 1:13:37 AM
nickvenezia
Status: offline
Can anyone suggest another set of exhaust stacks other than what comes in the kit. Or if not can anyone give some location and mounting advice. With the ARF the stacks extend over the back of the cowling and does not seem to want to lay down on the fuse...with pulling the cowling on and off this may be an issue...please help...
(in reply to skyscreamer)
       Post #: 1479
RE: Scale cockpit - Wow - 3/20/2008 1:36:38 AM
eugene
Status: offline
Check Tony-Howard at the top of this page....With a little patience, this makes a pretty scale looking setup
(in reply to nickvenezia)
       Post #: 1480
RE: Scale cockpit - Wow - 3/20/2008 3:58:39 PM
tony-howard
Status: online
For additional installation photos in addition to those in my RCU ad, take a look at the Gallery section of my website.
Tony
pacific-scaled-aircraft.com
(in reply to eugene)
       Post #: 1481
RE: Scale cockpit - Wow - 3/23/2008 9:34:57 PM
Doomking
Status: offline
Hi..
I need some help ...
I am trying to install my ignition module for a ZDZ 40 RE.
If I try to install it on the firewall the only place that I have room is behind the muffler. Is it ok there or been so close to the muffler it's going to be too hot ? I have about half to 3/4 inch clearance.
If I go behind the firewall, I have room but I need to drill a very large hole to allow the spark plug cap to go through, therefore I think I'll compromise a little the strenght of the firewall. Is this a suitable place for it ?
How did you guys deal with this issue ?
I am stuck and I need some help ...Thanks !
(in reply to tony-howard)
       Post #: 1482
RE: Scale cockpit - Wow - 3/24/2008 3:41:35 AM
crashproof
Status: offline
Hey Doom, I mounted mine behind the firewall on the plate for the tank. I simply enlarged the hole they already had in the firewall until the plug wire would fit through. My tank is mounted in the Fuse on the center of gravity. My firewall is rock solid enlarging the hole caused me no problem, but I did FG my firewall as I would always do anyway. Good Luck, Kevin.
(in reply to Doomking)
       Post #: 1483
RE: Scale cockpit - Wow - 3/24/2008 1:03:06 PM
dasintex
Status: offline
I havn't got as far as you guys in regards to mounting the Ignition Module, I was always under the impression you always mount ignition stuff in the engine Compartment in front of the Firewall to place it further away from the RX to reduce interference, is this not the case, or concern?
(in reply to crashproof)
       Post #: 1484
RE: Scale cockpit - Wow - 3/24/2008 8:43:17 PM
gary9648
Status: offline
Yes sir that is the norm, however sometimes it can not be help to put it behind the fire wall. Normally I place it above the engine on the fire wall. build a little podium or just strap it to the fire wall using wire ties and screws. I also use natural foam to isolate it form vibration.
Gary
(in reply to dasintex)
       Post #: 1485
RE: TF 1/5 Scale P-51 ARF Assembly Thread - 3/26/2008 4:13:54 PM
C.ops
Status: offline
Ready to buy TopFlites GS P51 Mustang / Fuji 63.1 combo. Hopefully with as little cutting as posible on the cowl! Has anyone put this engine in? The engine Topflite reccomends has no guts. Is there a better choice? Without spending a lot of $. Also would like to convert to P51 B, Using Great Planes conversion kit. I have been out of this hobby over 25 yrs. Anyone on these 2 ? Covert RC
C.ops
(in reply to BobH)
       Post #: 1486
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 3/26/2008 4:19:18 PM
C.ops
Status: offline
PS, That TopFlite P51 is a RTC, and I know converting it to a B would require major surgery,but? Covert RC
C.ops
(in reply to C.ops)
       Post #: 1487
RE: TF 1/5 Scale P-51 ARF Assembly Thread - 3/26/2008 5:44:16 PM
eugene
Status: offline
I have built this conversion from the ARC, glassed and painted... Parts are available from TF, makes a nice model...
I dont have a seperate picture , but if you'll go to our website. converseeagles.org open videos and pictures, scroll down to Howards P-51, you'll find pictures of Shoo Shoo Baby... I used a Brillelli 46, flys it very well.......Cowl is very narrow, a DL50 with a wraparound muffler would be a good fit, and plenty of power....
(in reply to C.ops)
       Post #: 1488
RE: TF 1/5 Scale P-51 ARF Assembly Thread - 3/26/2008 6:52:58 PM
dan4466
Status: offline
I used the Wildmann " Big Dick" graphics. They are very nice. I paid around $35 for them about a 1 1/2 ago. You wont be dissapointed.
Click to see fullsize image.
Click for fullsize
< Message edited by dan4466 -- 3/26/2008 6:55:50 PM >
       Post #: 1489
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 4/2/2008 10:15:42 PM
BOLD PILOT
Status: offline
Hi guys,
I received a replacement set of wings today and it appears they have fixed the shear web wrong way problem. Has anybody else noticed this ? I really don't want to open the wing unless I have to. I checked it with a flashlight and it looks like the web is vertical I am just not positive. Can I please get some feedback.
Cheers
Bold Pilot
(in reply to dan4466)
