RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!)
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!)
Page: <<   < prev  58 59 60 61 62 63 [64] 65 66 67   next >   >>
Login
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 6/24/2008 10:16:52 PM
Q8Nitro
Status: offline
quote:
ORIGINAL: nickvenezia
Here is the link to the prop... http://www.zingerpropeller.com/4_bladed_propeller.htm
hi guys, i'm interested in a 4 bladed prop, if i'm going with a 3MM 53 engine, what prop size will be good?? same as Nickevenzia's 20*8 ?? and if yes, i need a tractor one right??
thanks
Ali
(in reply to nickvenezia)
       Post #: 1576
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 6/25/2008 12:20:27 PM
michel gravelle
Status: offline
Hi
I have been working on the cock-pit . I know that you true scale guys will have a lot to comment on here . This is my first attemp at a cock-pit . I can admite one thing and that is , work on one thing at a time and take it from there . There is still a lot to do as to say switchs , levers . a few more dials , the pilots harness , the center stick , I am even thought of putting some wires at the rear were I think are batterys .
Michel
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Q8Nitro)
       Post #: 1577
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 6/25/2008 2:20:56 PM
Airnondas
Status: offline
Hi Mike.
Here is a small clip to go with your picutre, that shows the demise of my Top Flite Mustang.
After the low pass, I started to go vertical and that is when I found myself under the P-40.
My rudder fin took off the P-40's left wing.
Both planes back in kit form.
http://www.youtube.com/watch?v=2hHT7CyYivk
__________________________
Airnondas
Click for fullsize
< Message edited by Airnondas -- 6/25/2008 2:30:27 PM >
(in reply to michel gravelle)
       Post #: 1578
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 6/25/2008 2:32:49 PM
v6goose
Status: offline
_____________________________
"It''s a fine line between Hobby and mental illness..."
http://www.goosesworld.com
(in reply to Airnondas)
       Post #: 1579
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 6/25/2008 7:41:40 PM
spitfire mk.xiv
Status: offline
Hi, Mustang fans. The TF GS Mustang is a great flyer. Is there someone who has some experiens the flying chartics between the TF 1/5 and Compositt Arf 1/4?
My next Mustang have to be the big one......
Here is some pics from a geat formation flight we have at the Gathering of WW2007 at Trondheim in Norway. The pilots are the local Scalewarbirds of Norway and Fighteraces from England.
Feel free to look at www.scalewarbird.org
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by spitfire mk.xiv -- 6/25/2008 7:57:37 PM >
John Arne Sagøy
Scale Warbirds of Norway
(in reply to v6goose)
       Post #: 1580
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 6/25/2008 7:55:08 PM
v6goose
Status: offline
You're on the exact same path as me John...
Good pix!
Goose
(in reply to spitfire mk.xiv)
       Post #: 1581
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 6/25/2008 8:14:57 PM
Art G.
Status: offline
Balanced my P51 3/8 inch forward than the manual said. This is the best flying warbird I have ever flown. It grooves.
(in reply to Fighterpilot)
       Post #: 1582
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 6/26/2008 2:23:40 AM
michel gravelle
Status: offline
Hi
I was wonderig if some of you guys could give me some info here . I installed my control rods for the elevetors and found them very stiff . I know that there was a post on this and I have tried to find it , but was unsuccesful . Have any of you guys experienced this and , if so , what is the best solution . I must admit , this truely does bother me . Should I leave it , as is , or should I work on a modification .
Michel
< Message edited by michel gravelle -- 6/26/2008 2:25:15 AM >
(in reply to Art G.)
       Post #: 1583
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 6/26/2008 2:30:51 AM
gary9648
Status: offline
I have both, TF Mustang and the Fiberclassics Mustang. Not to mention a Nosen Mustang. Just remember this. The BIGGER they are the easier they are to fly!
Gary
       Post #: 1584
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 6/26/2008 2:40:45 AM
Fighterpilot
Status: offline
Michel, you have two sources of stiffness in your elevator movement.. the first thing to check is the elevator hinges themselves. If you used the CA hinges they can sometimes be very stiff if excessive CA gets in the joint or if the joint is tight and there is not enough relief on the leading edge of the elevator to allow for the up and down movement.
The other source of stiffness would be if your control rods are not straight and have an excessive bend in them. This bending of the outer rod will cause the inner rod to rub on the sides of the outer rod with the friction causing you the stiff feeling in your elevator movement. I usually cross my elevator control rods inside the fuselage in order to make the line from the servo contol arm to the elevator control horn as straight as possible. You really have to plan out your elevator servo locations in your servo tray to have as straight a line as possible from servo control arm to elevator control horn.
One thing you do not want to do is secure your outer control rod too closely to your servo. The swing motion of your servo arm will bind at full deflection either up or down if you don't allow room between the servo arm and the secured outer control rod for this lateral movement. I usually leave a minimum of about 3.5 tp 4 inches.
I hope this helps..
       Post #: 1585
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 6/26/2008 2:51:50 AM
eugene
Status: offline
Another place for binding, is in the preinstalled outer tubes....a small kink where it passes thru the formers will cause the inner rod to bind and rub....I have used a small piece of sandpaper on the end of the inner rod and chucked it in my portable drill, passing it thru the binding area... When kit building, crossing the rods works out much better...
       Post #: 1586
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 6/26/2008 2:53:43 AM
michel gravelle
Status: offline
Hi Fighter Pilot
Thank You for youre reply.... This is an ARF and I have only put the rods in the tubes , I have not installed the elevators as of yet . And yes the tubes are bent inside the fuselage . They are very poorly installed .My simple question have any other kit been recieved in this condition > and what is the solution ? will I have to rebuild ? I do know that if I leave it like this , its not a good idea .
Michel
       Post #: 1587
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!) - 6/26/2008 3:10:27 AM
