maloney engine???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> maloney engine???
Page: [1] 2   next >   >>
Login
maloney engine??? - 9/25/2003 2:51 PM
eyalu540
Score: 100
Last Login: 4/28/2013
Status: offline
hi
has anybody heard about this company (maloney),
and give me details of 35 cc engine??
Hide Signatures
       Post #: 1
RE: maloney engine??? - 9/25/2003 4:12 PM
Hobbsy
Score: 650
Last Login: 5/26/2013
Status: offline
If you're talking about the Maloney 125, I have one, it turns a 15x8 at around 7,200. It is fairly heavy and needs to be started with a starter unless you put an electronic ignition on it, which I did. It will however run a really long time on a 16 oz tank. They also made a 100 which was one cubic inch and the 125 is one and a quarter cubic inch disp.
< Message edited by hobbsy -- 9/25/2003 1:14:35 PM >
_____________________________
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to eyalu540)
       Post #: 2
RE: maloney engine??? - 9/25/2003 6:05 PM
Antique
Score: 557
Last Login: 3/21/2012
Status: offline
The plastic block under the carb tends to leak..If you have trouble drawing fuel take the block off and sand both sides on a flat surface..Be careful, the material is soft and will strip easily...
Unless they made a larger one, the Maloney 125 is about 20 cc.....
< Message edited by RCIGN1 -- 9/25/2003 4:07:22 PM >
Hide Signatures
(in reply to Hobbsy)
       Post #: 3
RE: maloney engine??? - 9/26/2003 6:55 AM
Hobbsy
Score: 650
Status: offline
Ralph, so far mine has not leaked and I lucked out as it came with a round piston ring. It has great compression, some came with oval shaped rings that took forever to seat.
Hide Signatures
(in reply to Antique)
       Post #: 4
RE: maloney engine??? - 9/26/2003 8:39 AM
Antique
Score: 557
Status: offline
The few I had here had out of round cylinders...A few passes on the Sunnen hone fixed it, round and straight within .0001
Hide Signatures
       Post #: 5
RE: maloney engine??? - 9/26/2003 3:59 PM
Hobbsy
Score: 650
Status: offline
I guess if you tried to wear in an oval shaped cylinder it would then be wore out. I have thought a lot about puting a Davis Diesel head on mine and running it with out the flywheel but some say the flywheel partly balances the crank. Mine came with the key in the flywheel being too tall and making the flywheel wobble.
< Message edited by hobbsy -- 9/26/2003 1:03:46 PM >
Hide Signatures
       Post #: 6
RE: maloney engine??? - 11/6/2003 9:27 PM
Frank C. Bowman
Score: 140
Last Login: 11/1/2012
Status: offline
I have new piston rings for this engine + over 200 more model engine rings. Email for details. Thanks Frank Bowman
frankbowman@mylifeline.net
Hide Signatures
       Post #: 7
RE: maloney engine??? - 7/4/2004 3:17 PM
gadix
Score: 100
Last Login: 5/22/2013
Status: offline
eyal shalom
please call me regarding the maloney engine.
thx
gadi.
054-5952320
GADI,
ISRAEL
Hide Signatures
       Post #: 8
RE: maloney engine??? - 7/4/2004 3:18 PM
gadix
Score: 100
Status: offline
hi and shalom from israel.
do u know the manufacturer, maloney, web site address, if any?
thx
GADI,
ISRAEL
Hide Signatures
       Post #: 9
RE: maloney engine??? - 7/4/2004 7:16 PM
Antique
Score: 557
Status: offline
Made by a company in Taiwan or Korea No web site...Imported by Jim Goad when he owned ISC International..Haven't been available (or even made) for many years....Same company made the Horner twin, also extinct....
RC Ignition
Hide Signatures
(in reply to gadix)
       Post #: 10
RE: maloney engine??? - 7/5/2004 8:35 AM
Hobbsy
Score: 650
Status: offline
They were made in Korea and imported by John Maloney of World Engines.
Hide Signatures
       Post #: 11
RE: maloney engine??? - 7/5/2004 1:09 PM
Texastbird
Score: 150
Status: offline
I picked up a 125 at a swap meet and it starts right up. But it surges when I try to lean out the mixture. Any guesses on what I could try. Running a 15X6 MA on it. Thanks.
Hide Signatures
       Post #: 12
RE: maloney engine??? - 7/5/2004 5:07 PM
Hobbsy
Score: 650
Status: offline
John Maloney only used a 15x8 for all his developement work on the 125, it is a 7,000 rpm engine, you may be turning it too fast.
Hide Signatures
(in reply to Texastbird)
       Post #: 13
RE: maloney engine??? - 11/14/2008 2:00 AM
thamby0612
Score: 100
Last Login: 12/18/2008
Status: offline
Hi, i have a meloney 100 that is nib there is none on ebay what would it be worth to someone on here? make offers thanks, i dont post here much so if you could email me thamby0612@gmail.com if you wish i will sell it to you on ebay so you will know iam not trying you or any thing.
Hide Signatures
       Post #: 14
RE: maloney engine??? - 9/11/2010 5:33 AM
flyoz
Score: 104
Last Login: 5/18/2013
Status: offline
Cant believe it.
I recently converted my Maloney 125 to Electronic ign (Thanks Hobbsy for some advice) yesterday I pulled an old RCM mag out and found an engine report from Clarence Lee re the Maloney 125.
Just in case any one seeks some literature I have posted it here
Click to see the file in new window.Attachment.pdf
New Fly Species-Helicoptera
Hide Signatures
(in reply to thamby0612)
       Post #: 15
RE: maloney engine??? - 9/11/2010 8:03 PM
Texastbird
Score: 150
Status: offline
Could you give me an idea of what you did to convert to elctronic igniton?
Hide Signatures
(in reply to flyoz)
       Post #: 16
RE: maloney engine??? - 9/12/2010 9:32 AM
flyoz
Score: 104
Status: offline
Yep. I removed the rear flywheel it Prizes off ie straight out and has a small semicirle key in shaft.
Then I rempurchased this http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6292 Plus a sensor pickup elsewhere same site a Lipo Battery and Voltage reg to keep it at the required 6V max and a tiny rare earth magnet
I drilled an 1/8th hole in the prop waher/base aluminium boss on the shaft and epoxied the magnet in flush.
The sensor can be flipped over in its plastic holder to get the right Mahgnetic pole.
The sensor is mounted so it is just over the magnet. When the shaft and magnet rotate the sensor is activated and initiates the spark.
You need to figure 26 Degrees BTC (I yhink) to find wher to mount the sensor an magnet. see http://www.rcextremepower.net/ignitions.html
The sensor can be adj a s bit each way with the 2 mounting screws
To Set up the spark angle see http://www.youtube.com/watch?v=GBXFpxWg7vY
All done
Hide Signatures
       Post #: 17
RE: maloney engine??? - 9/12/2010 6:43 PM
93octane
Score: 105
Last Login: 4/14/2013
Status: offline
quote:
ORIGINAL: flyoz
All done
I have 9 of these engines! I like them, yes they are a bit heavy..but with a few internal mods and some lightening they run excellent!! with stock ignition or aftermarket cdi...can you post some pics of your conversion? thanks
Hide Signatures
(in reply to flyoz)
       Post #: 18
RE: maloney engine??? - 9/12/2010 8:34 PM
Texastbird
Score: 150
Status: offline
So it runs ok with the flywheel removed? That is probably a lot of weight gone with the coil too. I already have an ignition module I think will work, I just need to find some of the little magnets.
Hide Signatures
(in reply to 93octane)
       Post #: 19
RE: maloney engine??? - 9/12/2010 11:32 PM
93octane
Score: 105
Status: offline
quote:
ORIGINAL: Texastbird
Yes sir runs just fine..spools up alittle quicker saves abunch of weight..radio shack has the rare earth magnets 1/8 in diameter...they work fine...
Hide Signatures
       Post #: 20
RE: maloney engine??? - 11/17/2010 8:05 PM
appy2day
Score: 100
Last Login: 6/18/2011
Status: offline
Nice to find this thread on the Maloney engines. I have a few of these and some spare parts. The weight has kept them off my planes, but the CDI conversion looks
like the answer. I'll have to order some ignition parts and give it a try. Any pictures of the converted engines?
Happy Flying,
appy
Hide Signatures
       Post #: 21
RE: maloney engine??? - 1/5/2011 4:14 AM
Duayne P
Score: 100
Last Login: 5/24/2013
Status: offline
I have one of these engines and I will post pics as soon as I can get my camera back. I bought the ignition from syssa and I also bought a new and better piston ring. It has awsone compresion and runnns like a champ. I payed under $200 for the engine and all the mods. WELL WORTH THE MONEY. I would love to get more of them.
Hide Signatures
(in reply to appy2day)
       Post #: 22
RE: maloney engine??? - 1/10/2011 8:30 PM
rcnats
Score: 105
Last Login: 5/25/2013
Status: offline
I had a Maloney 125 that I converted to diesel (Bob Davis, Davis Diesel) and the engine became lighter (no magneto) and it turned an 18x6 prop. Sold it...should have kept it .
rcnats
Spitfire Brotherhood #109
Hide Signatures
(in reply to Duayne P)
       Post #: 23
RE: maloney engine??? - 1/10/2011 9:31 PM
STUKA BARRY
Score: 130
Status: offline
I purchased one way back in 1985 along with the first shipment of Model Tech Dragon Ladies. The engine is heavy, but ran like a sewing machine. It never let me down. It did require an electric starter, but once it started, it did'nt stop. Very fuel efficeint too just not a powerful engine. Its been along time, but I think I got the whole package from Jim Goad for $200. The Dragon Lady was an awesome flying plane. I'd luv to have that one back.
KEEP UM FLYIN
Hide Signatures
(in reply to rcnats)
       Post #: 24
RE: maloney engine??? - 2/1/2012 4:54 AM
rightname
Score: 100
Last Login: 8/26/2012
Status: offline
I have a Maloney 100 that my father bought new many years ago.  It has only been run for a while on a test stand.  Any offers?
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> maloney engine???
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.234RCU1
