RE: Official Rock Crawling Thread
Tower Hobbies
Logged in as Guest
  Printable Version
FS Racing Monster Truck 4WD 1/5 Scale Blue - RTR
Seller:  pmwtrading
Details:   $755.00   |  8/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> RE: Official Rock Crawling Thread
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Official Rock Crawling Thread - 10/2/2003 3:48:27 AM
69 GTO
Status: offline
Dirk just want to say thanks again for the info. I just finished for the night.....i moved the links to the top of the axle...removed the bottom mounts...cut the screws....replaced the susp. links with shocks......cut off the rear servo mount and i think it has about 3/4-1" more travel now....deff has more ground clerance...and is startin to look like a crawler ...i am goin to the shop and get the lowest gears poss. for it tommorow and am going to do something about that stock pipe next! heres how it looks now with the mods you suggested.
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to Dirk Digler)
       Post #: 51
RE: Official Rock Crawling Thread - 10/2/2003 5:33:04 AM
Inv3ctiv3
Status: offline
Nice work Maxx !! I would like to see some vids of those nitros crawling.
(in reply to Inv3ctiv3)
       Post #: 52
RE: Official Rock Crawling Thread - 10/2/2003 5:41:31 AM
lynx the great
Status: offline
my maxx does a good job..... uuuuuu ..... uuuuuu not
pat
but it does fly
_____________________________
http://www.rcuniverse.com/mvp/mvpposts.cfm?memberid=63826
       Post #: 53
RE: Official Rock Crawling Thread - 10/2/2003 4:36:50 PM
Dirk Digler
Status: offline
Maxxoverkill,
Did you make sure to lengthen your upper links to correct caster? I used shock pistons on each end of the link and it worked perfectly. Now it's time for you to get lower gearing, a real rock crawler body and some better tires. You can get 12t clutch bell and combine it with a Savage spur gear to get super low crawlability!!! As for the tires, do the savage axles swap. If you can't right now, you can always get out the side cutters and go to work on the stock tires. If you get rid of about half of the chevron tread, you'd be surprised how flexible your tires become. You can also soak them in acetone for a while to soften the rubber compound. Best think to do is cut them up with your own tread pattern!!! Back to work!!!
       Post #: 54
RE: Official Rock Crawling Thread - 10/2/2003 10:25:12 PM
69 GTO
Status: offline
I havent lengthened the upper links yet.....i do see what you are talkin about though,the axle is angled inward at the top. So i was not sure if i wanted to lengthen the existing links or just make some new ones at work ....You said you used shock pistons to extend yours.....how much did you extend it and did you weld the piston to the link?
I am going to get some new tires for it and also the axle conversion. That way i have a wide choice of tires/rims.
I am lookin at bodys for it....tell ya what i wish i could find but i dont think they make them is a 70-72 blazer body. I had a full size(real) 70'blazer that i used to mud/off road with and it had a 10"lift with 40's on it. That would be cool to find one like that!
I do like the early year bronco body that i saw on the site.......i think it was even in this post if i remember....anyone know who makes that?
       Post #: 55
RE: Official Rock Crawling Thread - 10/3/2003 1:19:46 AM
Isphius
Status: offline
im geting an x-factor sometime soon. i want to rock crawl but also still go at least 20. i almost ordered a clod off of tower but i noticed the x-factor can be a pretty good crawler, now i want one, and i can rock crawl all day. what cylinder head do you use? and also is there a way to put a side mounted pipe on like from a buggy?
< Message edited by Isphius -- 10/3/2003 1:20:13 AM >
(in reply to 69 GTO )
       Post #: 56
RE: Official Rock Crawling Thread - 10/3/2003 1:20:58 AM
Isphius
Status: offline
dirk you should try those jumbokong tires from imex. they will make it an unstopable rock crawler if you can turn after there on.
(in reply to Isphius)
       Post #: 57
RE: Official Rock Crawling Thread - 10/3/2003 1:22:35 AM
69 GTO
Status: offline
I'm gonna be workin on the pipe situation very soon so i'll let ya know what i find that i can use...but if you go back up this thread there a descrip of how dirk i think it was...ran his exahust on his x-factor.
       Post #: 58
RE: Official Rock Crawling Thread - 10/3/2003 3:06:54 AM
lynx the great
Status: offline
can ur crawlers do this tho?
Click for fullsize
       Post #: 59
RE: Official Rock Crawling Thread - 10/3/2003 6:25:59 AM
Inv3ctiv3
Status: offline
Actually a lot of clods can do huge jumps, depends on how you set it up.
       Post #: 60
RE: Official Rock Crawling Thread - 10/3/2003 3:54:57 PM
Dirk Digler
Status: offline
Why in the world would I jump my crawlers off of that!?! I use my Savage for that! That is the point of building a crawler only truck and having multiple trucks for all the other aspects of off roading.
       Post #: 61
RE: Official Rock Crawling Thread - 10/3/2003 4:32:16 PM
Dirk Digler
Status: offline
By the way.....Maxxoverkill......here is my Bronco Body. It is made by HPI!
Click for fullsize
       Post #: 62
RE: Official Rock Crawling Thread - 10/3/2003 6:01:32 PM
minitrucker
Status: offline
Now think about it for a sec, why would something thats called a "crawler" be jumping off such a cruddy homemade jump. They are not called "jumpers", are they??
       Post #: 63
RE: Official Rock Crawling Thread - 10/3/2003 9:40:53 PM
Isphius
Status: offline
my 1989 black foot could do that, nothing special. and dirk, can you really call the black body you have a body?
< Message edited by Isphius -- 10/3/2003 9:43:44 PM >
(in reply to lynx the great)
       Post #: 64
