Unruely
Joined: 8/28/2003 From: Sandyville, WV, USA Status: offline
For a crawler, I like the Gecko chassis better. It seems to be more adjustable, by moving the lower shock mount locations. The Gecko can get more articulation than the Z4, it can get more than 90 degrees. For practical purposes the usable amount of articulation between the 2 is about the same, too much is not good. A tuber can make a good crawler, it just depends on the design. Brake line tubing makes a good tuber you can weld, solid music wire also works good. You can also silver solder brass tubing to make the frame. Martin
