Kiwi
Joined: 3/7/2003 From: The Alamo City, TX, USA Status: offline
quote:
ORIGINAL: ajcoholic I also fly 1/2A, and they are fun, but not too much building. At least with the Flite Streak Jr. you have a wing with ribs and sheeting, enough building to keep it going for a while, not a 1 evening project. You also get her started in covering. Actually, if you check out the kits they have lots for 09-15 size. A Ringmaster would also be sweet, makes a good trainer too. SIG produces two "09-15" size Goodyear kits with plank wings that should work well as trainers with a modern 10-size engine, such as the LA. I have added the quote marks around the engine suggested size because MODERN 15's are enough heavier & more powerful that they are a less-useful choice on older designs that were fine when powered by the much lighter weight baffle 15's. The Ringmaster Jr, on the other hand, was always stretching its own claim when it said 09-15 on the box, since it was more suitable for 074-09 engines. Now that Estes is referring to the same plane as a "Ringmaster 19" the situation is much worse for it! Brodak sells a repro kit of the Streak Trainer design that TF once kitted. It is larger than the two SIG kits mentioned, and worked fine with the older baffle 19's, so it's still going to balance well enough with a modern 15. Over the last year or so, something on the order of half the LHS's across the country have finally gotten around to getting web sites up. Go to the library and check the yellow pages for the cities in your state. The ads will include the URL's.
_____________________________
The K.
