RE: Photos Of Trailer Interior Layout, Please Post Yours Too!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
DAB-A-GLUE Glue Applicators
Seller:  donnboyd
Details:   $3.95   |  6/3/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Tips & Techniques >> RE: Photos Of Trailer Interior Layout, Please Post Yours Too!!
Page: <<   < prev  40 41 [42] 43 44 45 46 47 48 49   next >   >>
Login
RE: Photos Of Trailer Interior Layout, Please Post Your... - 10/24/2007 12:01 PM
carps
Score: 100
Last Login: 6/19/2013
Status: offline
Pope,
I have just checked the trailer.
Originally this was built for go karts and is all metal chassis, metal floor and then 19 x 19 mm square tubing with sheet metal cladding.
the springs have 3 leaves and I understand you thinking on shaking everything apart.
I have pulled the trailer from canberra to Sydney empty when I bought it but after fitting out I have travelled every weekend around the Sydney clubs. Nothing moves and I have even found a couple of times when I have not put the straps on the wings they have not even moved.
This may be because I have built the model supports from timber 40 x 19 mm with high density foam (Clark Rubber) on top. I find that by using timber supports they continually flex and have no effect on the models. After using this system I had to put another timber support of 40 x 19mm on top of the foam and then use rubber Occy straps to hold the models, wings firmly on the timber.
Due to purchase of the trailer interstate (ACT) I needed to get it completely checked and had to have it officially weighed. This was done with it empty before model fit out. The total weight is 320Kg. I believe that this also helps the very smooth ride.
I only use one occy strap to hold the flight box and it never moves even with all the fuel and batteries.
If you want more information I can probably get more pictures over the weekend
Hope this helps
Carps.
Hide Signatures
(in reply to the pope)
       Post #: 1026
RE: Photos Of Trailer Interior Layout, Please Post Your... - 10/24/2007 12:48 PM
the pope
Score: 101
Status: offline
Hey Carps, thanks for checking things out. Maybe Im being paranoid but when I made my box trailer I think when I bought the springs they were rated at some thing like 750 kg each. There were others there rated at by memory at about 500 kg each but I thought theres nothing like over kill, now when I drive with that trailer empty it just bounces over the bumps and the suspension doesnt even do any work, thats why I need to know which springs are best as the trailer i have rides as rough as guts, Now the spring ratings I have mentioned are just from memory and my memory is shot to pieces, . thanks again cheers the pope
Hide Signatures
(in reply to carps)
       Post #: 1027
RE: Photos Of Trailer Interior Layout, Please Post Your... - 10/24/2007 1:17 PM
the pope
Score: 101
Status: offline
Sheeese I just went and checked my trailer out and looked at the springs and found there are 5 leafs on there. Now if I ever need to shift a house Im all set. Cheeres the pope
Hide Signatures
       Post #: 1028
RE: Photos Of Trailer Interior Layout, Please Post Your... - 10/29/2007 4:19 AM
dg512055
Score: 100
Last Login: 1/11/2012
Status: offline
Here are some photos of a trailer that I built recently. Used plywood for the box.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by dg512055 -- 10/29/2007 4:26 AM >
_____________________________
http://www.ucradiocontrol.zoomshare.com
Hide Signatures
       Post #: 1029
RE: Photos Of Trailer Interior Layout, Please Post Your... - 10/30/2007 12:33 AM
Bratpak
Score: 100
Last Login: 7/11/2009
Status: offline
That is a nice trailer DG.
Just out of curiosity, in the first pic, what is sitting on the 4 wheel stand next to the trailer ????
I know it is an engine of some kind
Mark
Hide Signatures
(in reply to dg512055)
       Post #: 1030
RE: Photos Of Trailer Interior Layout, Please Post Your... - 10/30/2007 5:56 AM
LeeL
Score: 100
Last Login: 3/9/2011
Status: offline
looks like a go devil engine used for powering a boat in marshes.
Lee
www.aeroworldrc.com
Hide Signatures
(in reply to Bratpak)
       Post #: 1031
RE: Photos Of Trailer Interior Layout, Please Post Your... - 10/30/2007 7:15 AM
dg512055
Score: 100
Status: offline
That is a Go-Devil motor. It is a home made version though. I work for Kohler and got one of their 25 hp engines, and a local machine shop guy built the rest for me. It is used to drive a 16 ft aluminum boat through mud, weeds, buck brush etc. Mostly to get to the good duck hunting spots, but I am sitting out this season. I have flying to do!
DG
Hide Signatures
(in reply to LeeL)
       Post #: 1032
RE: Photos Of Trailer Interior Layout, Please Post Your... - 12/1/2007 8:18 PM
jimmyjoe
Score: 100
Last Login: 9/6/2012
Status: offline
propnut I am getting ready to order a MTI 6x12. What size is yours and would you add the e channel?
Hide Signatures
(in reply to Prop Nut)
       Post #: 1033
RE: Photos Of Trailer Interior Layout, Please Post Your... - 12/1/2007 8:26 PM
jimmyjoe
Score: 100
Status: offline
What size is the trailer and how did you glue the carpet down?
Hide Signatures
(in reply to michou41a)
       Post #: 1034
RE: Photos Of Trailer Interior Layout, Please Post You... - 12/1/2007 8:41 PM
jimmyjoe
Score: 100
Status: offline
John I am getting ready to have MTI build me a trailer and was curious as to what you thought of the craftsmanship? I am going with e channel recessed in the walls and 6x12 double door and side door. Also, getting the insulation in the roof as well. Let me know what you think of your MTI.
Hide Signatures
(in reply to John Hanske)
       Post #: 1035
RE: Trailer size - 12/1/2007 10:14 PM
jimmyjoe
Score: 100
Status: offline
Crash and burn how high did you mount the shelf from the floor. I am having a 6x12 built and the e channel is going to be mounted flush in the wall and was curious to the dimension needed. Currently have 30% Yak 54
33% QQ Yak and need to know what height you used with the bigger birds.
Hide Signatures
(in reply to crash and burn)
       Post #: 1036
RE: Trailer size - 12/2/2007 1:49 AM
JAkridge
Score: 100
Last Login: 12/14/2012
Status: offline
I use this.............It's pretty much dedicated for plane trips. Flying at meets, float flys and fun flys around California. If you look back at post 605 we had a different trailer. We hope this one will accommodate us for some longer trips back East next year. I'm getting ready to start building racks for the planes,wings etc. so things will be much more organized.
I've got (4) 6 volt golf cart batteries under the floor wired for 12V. It will power just about any plane charger I throw at it and they also provide juice for my 1800w inverter that gives 110V for the trailer if I'm not hooked to shore power or if I don't have the 5.5KW generator running.
It works for Us..........
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by JuzPlaneKrazy -- 12/2/2007 2:00 AM >
Hide Signatures
(in reply to jimmyjoe)
       Post #: 1037
RE: Trailer size - 12/2/2007 2:59 AM
Forgues Research
Score: 100
Last Login: 10/31/2011
Status: offline
quote:
ORIGINAL: JuzPlaneKrazy
Now that is the way to go, very very nice......
Roger
Hide Signatures
(in reply to JAkridge)
       Post #: 1038
RE: Photos Of Trailer Interior Layout, Please Post Your... - 12/2/2007 7:47 AM
JAkridge
Score: 100
Status: offline
Thanks Roger, It's to big for the day trips, but makes the weekend ones a real joy. So much so I don't want to go home
I hope I can post what my racks look like in a few weeks. I got some great ideas from the 42 pages of killer trailers guy posted.
< Message edited by JuzPlaneKrazy -- 12/2/2007 7:48 AM >
Hide Signatures
(in reply to Forgues Research)
       Post #: 1039
RE: Photos Of Trailer Interior Layout, Please Post Your... - 12/3/2007 6:35 AM
jddrumm
Score: 100
Last Login: 9/26/2012
Status: offline
Who needs a house with living like that. NICE!!!!!!!
claytonrc.com
Hide Signatures
       Post #: 1040
RE: Photos Of Trailer Interior Layout, Please Post Your... - 1/30/2008 8:24 PM
dodgeguy44
Score: 100
Last Login: 12/28/2011
Status: offline
I bought a 6X10 Wells Cargo on Vacation because all the planes and Helis were in our 5th wheel and we had no room to live. It's got the extra 6" of height and suits me great. It's not completely set up yet and there are 2 more planes at home to go in but it ended up with more room than I expected. Not sure I would do the ramp door again but that's all they had with the extra height.
Thanks to all the other posts for ideas.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to jddrumm)
       Post #: 1041
RE: Photos Of Trailer Interior Layout, Please Post Your... - 2/1/2008 1:57 AM
bolar
Score: 105
Last Login: 6/18/2013
Status: offline
Very nice. Those small white baskets in the front, what do you keep in them that doesn't hop out?
72 MHz Forever...............or at least until I buy a new radio.
Hide Signatures
(in reply to dodgeguy44)
       Post #: 1042
RE: Photos Of Trailer Interior Layout, Please Post Your... - 2/1/2008 6:16 AM
dodgeguy44
Score: 100
Status: offline
The small white baskets were an idea that didn't work. I pull this trailer behind my 5th wheel holiday trailer and all of my small parts in these baskets ended up on the floor during the first 400 miles. They stay there when the trailer is behind my truck but I guess the back of the 5th wheel bounces a bunch. I had planned a work bench in the front when I get home but now I need to rethink my layout.
Hide Signatures
(in reply to bolar)
       Post #: 1043
RE: Photos Of Trailer Interior Layout, Please Post Your... - 2/1/2008 12:59 PM
pahtreek
Score: 100
Status: offline
Here is my Horton 6x10 V nose trailer.
I wanted something that was unique and was very usable. All the side racks are on hinges that fold against the wall. If it is cold we have lots of room to sit inside. I did purchase the torsion axle (much smoother ride), and an extra 6" of height. The little "workshop" in the V nose is awesome when a problem happens at fly-ins. I have a marine battery running a power inverter so I can use my dremmel and drill.
I put some pink panther insulation in the ceiling and covered it with thin plywood. The stereo and speakers I bought cheap from a pawn shop, and the cabinets were cheap from target. The saddles were a bit tricky, I took a coat hangar, bent it to the shap of my fuse (once at the front, and again near the tail). I laid the hangar on some 1/2" plywood and traced the cut lines. Just make sure when you set the hinges that when you open them to put the planes in the rack that the bottom top touches the floor. You do not want all the weight of your planes pulling on the hinges. One hard bump and it would probably not hold. I put a door lock pin on each of the bottom and drilled a small hole in the floor to hold them open. I bought some stain from Home depot and stained the inside.
I get a lot of comments about the usability of "my cave", I like being able to walk around inside of it.
Good luck with your new trailer!
Click for fullsize
"Now you listen to me Bobby Bouche... ARF''''s are da devil!" "...but mama, they make me feel good!"
Hide Signatures
       Post #: 1044
RE: Photos Of Trailer Interior Layout, Please Post Your... - 2/1/2008 7:01 PM
narpets
Score: 100
Last Login: 1/16/2011
Status: offline
Anyone using one of those poly tongue boxes? I did some searching and see a bunch, but not sure how good they are. Prices vary from <$100 to the price of an aluminum one. ONt sure if the cheap ones are worth it.
Hide Signatures
(in reply to pahtreek)
       Post #: 1045
RE: Photos Of Trailer Interior Layout, Please Post Your... - 2/6/2008 6:40 AM
telejojo
Score: 130
Last Login: 6/4/2013
Status: offline
Mine is a 14x7.........
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1046
RE: Photos Of Trailer Interior Layout, Please Post Your... - 2/6/2008 12:49 PM
sebo
Score: 111
Status: offline
Where did you get the black levers that hold the door up?
What do they cost?
I like your trailer the best so far because it fits my budget. It looks good too.
What did you paint (cover) it with?
Thanks, Ron
Hide Signatures
       Post #: 1047
RE: Photos Of Trailer Interior Layout, Please Post Your... - 2/13/2008 8:22 PM
jdcool4
Score: 100
Last Login: 4/29/2013
Status: offline
i would like some help on buyin and building a trailer for around 2k
Hide Signatures
       Post #: 1048
RE: Photos Of Trailer Interior Layout, Please Post Your... - 2/15/2008 8:01 AM
Teachu2
Score: 135
Last Login: 1/8/2013
Status: offline
quote:
ORIGINAL: jdcool4
http://cgi.ebay.com/6-X-12-ENCLOSED-CARGO-BIKE-UTILITY-TRAILER-RAMP-DOOR_W0QQitemZ290204205597QQihZ019QQcategoryZ95495QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Trent Combs
Fly 'em until the last piece stops!
Hide Signatures
(in reply to jdcool4)
       Post #: 1049
RE: Photos Of Trailer Interior Layout, Please Post Your... - 2/15/2008 8:41 AM
jdcool4
Score: 100
Status: offline
thanks i finaly found some around here 4 about that price so i will get on in a few weeks
Hide Signatures
(in reply to Teachu2)
       Post #: 1050
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
