Big_Bird
Joined: 12/18/2001 From: Arlington, TX, USA Status: offline
Blackie, I don't know if you have ever used 1x6 red oak for anything but you can't bend that stuff. I painted it with oil based paint before installation and used aluminum paint for looks. I'll keep a close watch on it. The cross flow vents in the sides provide good flow to the roof vent when the trailer is closed up. We have had a lot of hot weather here in texas recently which has provided good testing for a closed up trailer. When I open the door at noon after a morning of sunshine, the temperature inside is very near the ambient air temperature. Temperature in the summer is not going to be a problem. Kregg, I bought the insulation at Home Depot. It has thin aluminum on one side and clear plastic bonded to the other. About $6 a 4x8 sheet. It took a little less than 2 1/2 sheets. To attach it I used paneling glue. The reason that the panels between the bows were done in 3 pieces was for ease of installation and because there was a ridge joint where the curved roof piece met the center flat piece. To put the foam up you measure for the curved section between the bows (about 26" and cut it out. Then on the back side, I used a single edged razor to cut lines nearly through the back side. Then I broke the scores to form the curve. After test fitting and adjusting, I applied the paneling glue per the instructions on the tube and pressed the foam to the roof. I immediately pulled it back down (per instructions) for a couple of minutes then pressed it back in place. The above proceedure causes the glue to act like contact glue. I have not had any problem with the glue debonding in the heat. Aluminum tape was used on the joints more for looks than anything else. Stomper, you are sure right about making life easier and Blackie I'll have it at the Hill Country flyin in October. Ken
< Message edited by Big_Bird -- Aug 29 2002 4:21PM >
