anyone used automotive clear over tamiya?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> anyone used automotive clear over tamiya?
Page: [1]
Login
anyone used automotive clear over tamiya? - 10/1/2003 5:05:57 PM
zoltan
Status: offline
i have a project i've paint with tamiya acrylics. i'd like to have it clear coated with automotive clear to give it the best protection. has anyone done this before? did it hurt the tamiya paint at all?
       Post #: 1
RE: anyone used automotive clear over tamiya? - 10/2/2003 3:59:28 PM
LesUyeda
Status: offline
I have not used automotive clear over Tamiya, but I have been successful using clear waterbased polyeurathane. Comes in gloss and satin, and is fuel proof to 15% at least.
Les
(in reply to zoltan)
       Post #: 2
RE: anyone used automotive clear over tamiya? - 10/2/2003 4:45:40 PM
zoltan
Status: offline
like minwax polyrylic? how long does it take to fully cure?
(in reply to LesUyeda)
       Post #: 3
RE: anyone used automotive clear over tamiya? - 10/2/2003 6:15:50 PM
Steve Collins
Status: online
In my experience, polyurethane always yellows with exposure to sunlight.
I have not used automotive clear over the Tamiya acrylic but I have used it over the Humbrol flat enamel and Testors ModelMaster enamels with no problem. Light mist coats at first. In the following photo, the red, white, and blue on the tail are Testors gloss enamels and the black on the wingtip tanks is Testors flat black enamel. The dark gray inside surface of the flaps is Humbrol flat enamel. I also have a very large F-86 that is painted almost entirely with Testors ModelMaster enamel. The clearcoat on the T-33 is DuPont Nason with a 2 to 1 mix of clearcoat and flattener. The clearcoat used on the F-86 is PPG "Flexed-N-Flat" clear:
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Steve Collins
       Post #: 4
RE: anyone used automotive clear over tamiya? - 10/2/2003 6:19:31 PM
Steve Collins
Status: online
Sorry, I don't know what happened here. Apparently the auto-resizer built into the new RCU didn't work this time and the photos came across full size.
Steve Collins
       Post #: 5
RE: anyone used automotive clear over tamiya? - 10/2/2003 9:10:26 PM
Rubbie
Status: offline
I don't know if this helps but I have used Lustercote without any problems at all over the Tamiya. I have heard and someone may want to chime in to confirm if Lustercote has the same properties as automotive clear.
(in reply to Steve Collins)
       Post #: 6
RE: anyone used automotive clear over tamiya? - 10/3/2003 1:21:51 PM
JeffH
Status: offline
I have done exactly what you are asking. I painted a whiplash with the Tamiya paints and cleared it with Dupont Chroma-Clear. The only problem is, that if you get ever the tiniest hole in the clear, from a scratch, drilled hole, etc, and glow fuel, raw or burnt, hit the hole, poof, the tamiya paint wrinkles instantly. The bubbles under the clear and will acutally run under the clear attacking the paint. It is not pretty when that happens. If you are using Glow, I would find another paint.
       Post #: 7
RE: anyone used automotive clear over tamiya? - 10/3/2003 3:54:29 PM
LesUyeda
Status: offline
Exactly like minwax. I cannot give you exact drying times. Depends too much on how thick you put it on, what the weather is like, etc.,etc.,etc. Several hours will probably be plenty.
Steve: Beautiful bird. Since REAL airplanes have round engines and two wings, that one satisfys at least one of the criteria, and so is acceptable. The solvent based polyeurathanes where slightly yellow out of the can and turned more so with age, but the water based ones are water clear, and stay that way.
Les
       Post #: 8
RE: anyone used automotive clear over tamiya? - 10/3/2003 10:27:03 PM
Steve Collins
Status: online
Well, the engine is round, you just can't see it. And there is a left wing and a right wing; works for me.
Steve Collins
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.844RCU1
