BACKEMF
Joined: 9/25/2003 From: Milton, ON, CANADA Status: offline
Now for motors and electronics, Since I am a beginner with motorcycles I will start with a "Mild" Motor, Name brands don't mean alot but the spec's do. I will try some stock motors first even a cheapy sealed can 540 will do. The reason to start off slow is to get used to turning and also the faster you go the quicker you need to stop. start with a cheesy 27 turn motor down to a 17 turn motor, and if you can get them try for a Quad wound motor, that means they use 4 wires for every turn on the inside. A quad motor will give a much smoother power band and not so radical and abrupt acceleration. You have to be smooth with a Bike. The speed control is a decision you need to make on your own. It should be a car speed control preferrably with no reverse, but with adjustable braking. Something from Novaks line or Tekin, or whatever as long as you get one that can handle mild to wild motors like a 10 or 12 turn Quad, and as long as it isn't a boat anchor or the size of a house! For future upgrades as your driving progresses. Also the faster you go, then you have to think about putting on a front brake upgrade, very worth while! From CNR. When it comes to servos and recievers, just start with what you might have for a car. They mention all over that no special servo is needed for the steering and a regular sized reciever is fine to start out with. Once you have the hang of things then you could go to a smaller RX and maybe even a smaller servo to save weight. I am used to driving with a wheel on the TX but I still have my old "Stick" TX radios, which I will dig up and use instead of a wheel type for starters. Uh Oh she is waking up! time to put on the Honeymoon Charm!! see ya Zeek Speed out!
< Message edited by ray schrauwen -- 10/12/2003 1:35:54 PM >
