gcb
NY, USA Status: offline
quote:
ORIGINAL: DoubleUgly ...but there is a lot of end play in the prop shaft so I may go with a OS LA .15... D. Do you mean front to back play or up and down? If it's front to back it may have been caused by using an electric starter. I would suggest bench-running the engine and see if it leaks badly out the front of the shaft. It may be OK. quote:
...I will have to make a pillgamage up to the AMA headquarters in Muncie, IN and see if I can't get some more 1/2A pearls of wisdom... D. It's been so long since I moved from Lexington that I don't remember where Erlanger is located...just remember the name. There are CL flyers in Lexington, Louisville, and Bardstown that I know of. Probably lots of others. Perhaps your nearest hobby shop could put you in touch. Another source would be to search the AMA (Academy of Model Aeronautics) web site for the club nearest you. Another possibility would be a book titled, "Building and Flying Control Line Model Aircraft" by Dick Sarpolus. Also there are a couple of Videos on building and flying 1/2 A (.049) models. Keep us posted with your progress. George
