branded
IL, USA Status: offline
quote:
ORIGINAL: FLYBOY Branded, I have also seen that particular system at clubs, but it has lots of room for error, and should be brought up at a meeting. If the club has only 1 set of pins, (clips, clothes pins or what ever) on the board and you walk up and take that pin and put in your ama card, and the rule states you do not turn on unless you have said pin, then chances of a shoot down are greatly reduced. Like you said, with your system, if you place a clip over your freq, and the wind blows it off, or someone sticking one on the freq next to it nocks it off, or a multitude of other things happen, and someone else walks up and puts their pin on the now empty slot and turns on, your plane is toast. The system is flawed, and if it were my club, I would be for pushing very hard to get it changed to a system like I first described so someone couldn't inadvertanly shoot me down if my clip were to dissapear. Not everyone flys huge dollar planes, but even the little planes take time and effort to build and fix. Why use a system that could lead to the destruction of a plane because of so many different causes nocking the clip off the board. The system is flawed and should be changed so you don't have to worry about shoot downs. Maybe that is why it is so cut and dry for the rest of us. Our systems have a lot less chance of a mistake happening. Agreed, the system is less than perfect, but unfortunately the only one that's reasonably simple to manage, particularly at club fields that use public lands. At these fields anyone with an AMA card can show up and use the field. It's not easily controlled. Pins disappear too often. Like it or not, this is the system that's most managable under our circumstances.
