AdrianM
Joined: 10/8/2002 From: Palm Harbor, FL, USA Status: offline
Usually an engine manual will tell you if it needs to run FAI or low nitro fuel. Most commonly available engines (OS, Thunder Tiger, Super Tigre, Tower, GMS, MDS, Evolution) are designed to run on 10-15% nitro as that is what is most commonly used in the US. Certain euro engines run better on low nitro (Moki, MVVS) 0-5%. If you try to run too little nitro you will have problems getting a good low idle, transition will be ragged or slow and top end rpm will be lower than normal. I run all my engines on 15% nitro. I won a jug of 10% at a fly in and I didn'y like it. I could see a diffrence in performance in flight. I do have an MVVS .49 that is a monster on 5%. It was designed to run on it though. Engineds that run on loe nitro have a different combustion chamber shape and diffrent needle tapers on the carb.
_____________________________
Adrian Martinez
