EPP flying wings - which is easier 2 fly?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Gliders, Sailplanes and Slope Soaring >> EPP flying wings - which is easier 2 fly?
Page: [1]
Login
EPP flying wings - which is easier 2 fly? - 4/29/2002 8:31:42 AM
AirHead256
Status: offline
A bud and I are trying to find the easiest combat wing to start out with.
We need tough, since we both have serious crashes on a regular basis w/ our existing gliders. We'd gladly trade agressive abilities in combat for ease of keeping up with the flight characteristics of our wings.
Does anyone have experiences to compare the zagi to the XR or other wings?
DerCheeseHead, eh?
Click to see fullsize image.
Click for fullsize
       Post #: 1
Starting Out - 4/30/2002 1:18:50 AM
Ollie
Status: offline
Either one is relatively easy to fly when properly adjusted but a Highlander is easier yet to properly adjust and fly. One little mistake like not having the holes in a control horn line up with the hinge line is all it takes to result in frustration. The opportunities for such mistakes are numerous.
The catch 22 is that: Until you can fly you probably can't dependably adjust the plane for easy learning and until the plane is properly adjusted, it will be difficult to learn to fly. The solution is to find a competent pilot to trim the plane before you try to fly it. You can learn to adjust and fly on your own but it usually takes about ten times longer than with a competent instructor. It also takes an attention to detail and a desire to "do things right" that is lacking in many people.
Think of it this way. If you didn't know how to shoot a rifle or adjust the sights but bought a rifle. Then, expected the factory to have sighted it in and not have the sights upset during shipment. Then went out to hit a small target at a distance, what would be your chances?
_____________________________
Regards, Ollie
(in reply to AirHead256)
       Post #: 2
EPP flying wings - which is easier 2 fly? - 4/30/2002 10:56:04 PM
Delta-RCU
Status: offline
I learned to fly with a wingwarrior Raider.
[url]www.wingwarrior.com[/url]
It has a longer cord and is very stable.
I was able to learn to fly inverted last weekend.
Marty at wingwarrior was very helpful on the phone walking me through the building process. Took me a while it was my first build.
This wing is all EPP.
Delta for ever
       Post #: 3
XR - 5/1/2002 10:13:47 AM
rhino
Status: offline
I'm a huge fan of the XR combat wing. I've flown against a few other models... Zagi, Boomerang, and 2 others (don't remember the name). I like it so much I wrote a testimonial that they ended up using on the XR site. It says it all.
Hank
       Post #: 4
XR - 5/1/2002 6:56:44 PM
AirHead256
Status: offline
Thanks for the info everyone. Keep it coming.
So Hank, to what would you attribute the better flight characteristics of your choice?
Seems like the basic materials are identical w/ EPP & balsa controls.
I see wingwarrior site above has models w/ 12" & 15" wide wings. I'd think that would provide a wider / more stable platform.
Same for other recommendations, why do you think your model of slab-o-foam flies better?
       Post #: 5
EPP flying wings - which is easier 2 fly? - 5/1/2002 10:02:00 PM
rhino
Status: offline
I'm not knowledgible when it comes to flight characteristics, Ollie understands these things much better.
I noticed the plane was lighter, more symetrical and with a longer chord than the Zagi's, hence the greater lift and inverted flight stability. The boomerang is very close, but the XR has a greater sweep as well as some extra wing area.
Althogh there are differences between the planes, I don't think thay are that great when it comes to learning to fly. I am very excited to see how my plane performs, but it didn't take any shorter amount of time to get the hang of my plane then any of the other wings. The flight characteristics are similar enough that you could move from one to the other without issue.
If you were really into combat, then picking the plane that matches what you want in characteristics would be important, but just haveing an indestructable plane, you could go with any of them and be happy. I do beleive the XR and boomerang stay aloft in lighter wind than the zagi's do, but you could probably build a zagi light enough where it wouldn't be a big issue. There are also many EPP made "standard" planes. The wings certainly fly different than a tradition plane (Fuse, wing, tail), so if you just want to get stick time without lots of repair time and aren't planning on a lot of combat, you might look at the EPP cousins of the standards.
Check out some of these sites:
http://www.aerofoam.com/
http://www.bowmanshobbies.com/
http://www.davesaircraftworks.com/
http://www.djaerotech.com/dj_product/
http://www.madaircraft.com/
And many others... A huge list of links can be found here: http://www.fatlion.com/sailplanes/links.html
And most of all, have fun... I know I do.
Hank
       Post #: 6
Zagi can't fly inverted??? - 5/4/2002 11:48:53 AM
KeithB
Status: offline
Hank,
I read your testimonial on the XR. It sounds interesting and I would like to compare it against the Zagi myself. The price is certainly a lot better
But I do have to question a comment you made in your quote. You said, "The Zagi's couldn't really fly inverted...".
I'm not sure why you think this is the case, I just purchased a Zagi last week and I've flown it inverted with no problem.
What did you mean by that statement? Were you unable to fly a Zagi inverted?
Keith
       Post #: 7
I think I get it now! - 5/4/2002 11:57:22 AM
KeithB
Status: offline
Hank,
After further studying the XR I realized that it has no motor. My Zagi is the 400X which has a 400 electric motor.
If you were talking about a plain Zagi with no motor then that explains why I can fly mine inverted and you had trouble .
Keith
       Post #: 8
Flying silent - 5/4/2002 9:23:43 PM
rhino
Status: offline
Yep, just the plain ole glider, no motor. The Zagi "could" fly inverted, however it was sinking and required a lot of stick control to keep it, it wasn't something the other pilots wanted to keep doing. The Boomerang held its own, but needed a lot of stick input. The XR really was flying as well upside down as it was right side up. The bommerang pilot literally combatted while inverted to the chagrin of the other pilots.
I'm really not trying to start a religous war, I bought my XR for these reason, and I'm happy that it turned out as good as the marketing materials.
Hank
       Post #: 9
EPP flying wings - which is easier 2 fly? - 5/6/2002 2:48:57 AM
AirHead256
Status: offline
So is anyone flying those wide wing models?
I see the Zagi LE and XL combat wing seem to have a bit more wing area, and I'd be interested in if that slows / eases the flying for us low-visioned senior dinizens.
       Post #: 10
wing warrior raider - 12/30/2002 4:06:15 AM
FunXtra
Status: offline
the best wing around is the raider, its the best wing i ever tried.
and the guys that make the wings (Tom, Paul, Marty, an Lee Roy) are the best to deal with, if u live around surf city you'll probably see their marketed wings, and even prototypes.
Best of all, they can teach you how to fly and u may even borrow the wings for a test fly (that helps a lot choosing a wing, maybe not all of them fly great).
[URL=http://www.wingwarrior.com]click here to get in their site[/URL] u wont be disappointed once u fly one of these.
PD: forget about zagis boomerangs and XR's these guys are the best
nobody but you can touch your plane without your permission and supervision.
       Post #: 11
EPP flying wings - which is easier 2 fly? - 12/30/2002 4:23:00 AM
StormGald
Status: offline
Hi is that big orange for sale I love it is it a highlander? Name a price I may take it if its resonable.
       Post #: 12
XR vs Zagi - 12/30/2002 11:55:47 AM
CactusJackSlade
Status: offline
Well, I have owned and flown:
Zagi 3C
Zagi THL
Zagi 400X (400 electric and as glider)
XR Combat wing.
I can tell you this:
If you build up your Zagi (like a THL with a spar in it) it will fly better (ok, not "better" - but easier) than the XR because it will float better and weigh 2 oz less... but if you build the 3C which is more comparable weight wise than I'd say go the XR.
In general I think the XR is less suseptable to tip stalls and the ol' death spiral. Don't know why, maybe the slightly larger cord at the tip???
If you are interested go here to see some mod's I did with my XR:
http://hobiehawk.com/ZEXR.html
Some might disagree with me but i have many hours on all the above planes...
Thanks my 2 cents worth..
CJS
CactusJackSlade
       Post #: 13
Wing Warriors - 12/30/2002 8:56:33 PM
FunXtra
Status: offline
I still think Wing Warriors are the best.
The Raider (the one i have) has a 15 inch central wing chord (3 in longer then the usual 48" wing) and a beefy wing surface, which allows the pilot to be free to put heavier stanard gear without sacrificing slow stall speeds, etc. my wing with standard gear floats as well, if not better then a Zagi 3C, or LE with mini gear.
Besides all of that the winglets made by WW are the best looking ones ive ever seen
       Post #: 14
EPP flying wings - which is easier 2 fly? - 12/30/2002 11:43:55 PM
