Saboteur?
Tower Hobbies
Logged in as Guest
  Printable Version
ZN Line twister
Seller:  danno-RCU
Details:   $1,100.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> The Clubhouse >> Saboteur?
Page: [1] 2   next >   >>
Login
Saboteur? - 10/12/2003 2:08:04 PM
Zpat
Status: offline
The guys in the club have been upset with me lately and I believe I may have been sabotaged.
My favorite airplane seemed to have structural failure. The spar broke.
This is a 5/8" pine dowel for a 5lb airplane.
I wouldn't think the forces of a 5lb airplane could do this.
What do you guys think?
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: Saboteur? - 10/12/2003 2:22:56 PM
DavidAgar
Status: offline
What were you doing when this spar broke? It could be a suspicious thing, however I have seen breaks like this caused by over stressing a plane in flight. How old is the plane and how many flights are on it? Could it have been damaged in the hangor and not noticed? If one of your club members did do this prior to a flight, I would think that it would have been noticed prior to flight. Good Luck, Dave
_____________________________
If the screw ain't loose then things ain't normal.
Dave Agar
AMA#97144
(in reply to Zpat)
       Post #: 2
RE: Saboteur? - 10/12/2003 2:29:53 PM
Zpat
Status: offline
When the spar broke I was practicing blenders.
The spar itself has 10 or 15 flights on it because it was recently replaced.
(in reply to Zpat)
       Post #: 3
RE: Saboteur? - 10/12/2003 3:48:54 PM
FOD MAN
Status: offline
Why was the first one replaced?
(in reply to Zpat)
       Post #: 4
RE: Saboteur? - 10/12/2003 3:55:26 PM
Zpat
Status: offline
I was in a hover and engine leaned.
It fell on its nose causing the aluminum wing bolts to bend in a "u" shape. The part in the dowel bent. Removal resulted in trashing the dowel.
(in reply to Zpat)
       Post #: 5
RE: Saboteur? - 10/12/2003 4:11:32 PM
blue62
Status: offline
how come they don't like you ion the first place?
I don't have it, do you have it? crash! nope musta been shot down!
(in reply to Zpat)
       Post #: 6
RE: Saboteur? - 10/12/2003 4:20:41 PM
Zpat
Status: offline
They think I'm an a**hole.
(in reply to Zpat)
       Post #: 7
RE: Saboteur? - 10/12/2003 4:43:35 PM
BasinBum
Status: offline
So are you saying someone snuck into your workshop and somehow weakend the dowel so you couldn't tell after it broke? Maybe a more reasonable explanation is that you put it in with the grain in the wrong position and when you did a manuver that will rip the wings off many planes it came apart.
I find it hard to believe that just because you are paranoid and accusing people of doing something to your plane that they would think your an A-hole.
(in reply to Zpat)
       Post #: 8
RE: Saboteur? - 10/12/2003 5:34:49 PM
TLH101
Status: offline
If you really believe that they sabatoged you airplane, they could be right .
Terry
"Old Fart" in training. (not to be an R/Cer, but to be an "Old Fart")
(in reply to Zpat)
       Post #: 9
RE: Saboteur? - 10/12/2003 6:05:03 PM
Zpat
Status: offline
BasinBum,
I think you are correct.
Grain orientation was not taken into account.
Thank you!
I knew I'd find the answer here.
Maybe they didn't sabotage it.
Oh well.....
< Message edited by Zpat -- 10/12/2003 6:29:53 PM >
(in reply to Zpat)
       Post #: 10
RE: Saboteur? - 10/12/2003 6:53:57 PM
ballgunner
Status: offline
Check your own background. Do they really think you are an A--hole or are you just paranoid. ( so much for amateur psychiatry ) Look back and try to find what you did to irritate someone enough to even consider sabotage.
(in reply to Zpat)
       Post #: 11
RE: Saboteur? - 10/12/2003 7:08:42 PM
Geistware
Status: offline
From the picture, the grain looks in the right direction but I still would expect pine to break if you didn't saturate it with C/A. I would have coated it with C/A then sanded it smooth.
quote:
ORIGINAL: Zpat
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
(in reply to Zpat)
       Post #: 12
RE: Saboteur? - 10/12/2003 9:12:41 PM
Zpat
Status: offline
I just mentioned sabotage to get a rise out of the guys.
All in fun.
(in reply to Zpat)
       Post #: 13
RE: Saboteur? - 10/13/2003 12:07:00 AM
cabanestrut2002
Status: offline
i think this is a joke- lighten up guys.
troll troll troll your boat
(in reply to Zpat)
       Post #: 14
RE: Saboteur? - 10/13/2003 12:09:12 AM
augiep38
Status: offline
quote:
ORIGINAL: cabanestrut2002
I think it was sabotage.
< Message edited by augiep38 -- 10/12/2003 7:28:41 PM >
(in reply to cabanestrut2002)
       Post #: 15
RE: Saboteur? - 10/13/2003 8:42:51 AM
Grampaw
Status: offline
Wonder what the other guys in the club would have to say about this?
(in reply to augiep38)
       Post #: 16
RE: Saboteur? - 10/13/2003 1:31:50 PM
rcman58-RCU
