New Era Choppers: Nitro Drag Motorcycle
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Motorcycles >> New Era Choppers: Nitro Drag Motorcycle Page: [1]
Login
New Era Choppers: Nitro Drag Motorcycle - 10/12/2003 9:04:19 PM
Tucson01
Status: offline
For those of you that can think outside the box!
http://www.neweramodels.com/cgi-bin/item.cgi?session_id=uyiociqwkqlehjakarqgssqhsdjlxmep&part_id=1826
Sweet nitro drag bike!!
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: New Era Choppers: Nitro Drag Motorcycle - 10/13/2003 12:54:36 AM
Tucson01
Status: offline
On RCZ a poster talked to the New Era reps ...
"they are working on a street version of the bike to go along with the drag version"
More Pics.........
Click for fullsize
Click for fullsize
(in reply to Tucson01)
       Post #: 2
RE: New Era Choppers: Nitro Drag Motorcycle - 10/14/2003 12:28:43 AM
NitroWolf
Status: offline
At $500 w/o motor or electrics, it is still a sweet bike...for looking at only. Can you imagine the damage if you had a spill? Drag bikes need to be a little tougher. Don't get me wrong, I would buy one in a heartbeat, but not to put on the strips.
       Post #: 3
RE: New Era Choppers: Nitro Drag Motorcycle - 10/14/2003 1:21:56 AM
Tucson01
Status: offline
Hate to say it but i have seen guys do $400+ damage to a R/C car. Have you ever watched a R/C plane take a dirt nap... if its a nice one your lucky to get away with
$400 in damage. I saw a SuperNitro Rs4 clocked at 100mph go for a bit of road rash..
it didn't look like a cheap fix.
Heh.. my wifes car was parked and a crazed lady backed into it BAM! $1200 damage.
My cousin jumped over his dog and broke his leg BAM!!! $30k in medical bills, spiral
fracture of the lower leg. Now he has a $30k 12 " titanium rod in his leg.
The bike looks well built.... Take a look at that rear tire.... its Built for speed!!!
The Pumilio Tiempo is $695 EUROs + shipping + (taxes & customs duties) find a Euro to Dollar converter. It has no motor or electronics.
Heres a Link: http://www.pumilio.fi/eb_main.html
(in reply to NitroWolf)
       Post #: 4
RE: New Era Choppers: Nitro Drag Motorcycle - 10/19/2003 5:00:27 PM
NitroWolf
Status: offline
tuscon, the rear of the bike looks well built. I was more or less speaking of a front-end impact. I'm sure the bike would fly. I'm not knocking the bike for it's price or speed. Just the cost every time someone impacted the front.
       Post #: 5
RE: New Era Choppers: Nitro Drag Motorcycle - 10/22/2003 5:53:47 AM
evanspa
Status: offline
I am still working on mine! Brazed brake tubing(Kragen) and a four stroke. I need info on front end trail and handling....Anyone help?
Click for fullsize
Click for fullsize
       Post #: 6
RE: New Era Choppers: Nitro Drag Motorcycle - 10/22/2003 8:45:08 PM
LtlHdThnkr
Status: offline
Evanspa,
That looks sweet!!! Looks like your going to make it belt driven, cool! Hope you get enough thump outa' that pea shooter to make it sound semi-authentic...lol. At least throw a hot lookin' chick on the back with a "back seat ****" T-shirt!!!
LHT
(in reply to evanspa)
       Post #: 7
RE: New Era Choppers: Nitro Drag Motorcycle - 10/22/2003 11:46:42 PM
NitroWolf
Status: offline
Hey, that's nice. Kind of the same approach I have exept I had planned on using music wire (to stiff to work with). I think an 1/8 inch mild steel rod will be fine though. Two stroke for me! What did you use for the tank and rear fender?
       Post #: 8
RE: New Era Choppers: Nitro Drag Motorcycle - 10/24/2003 5:02:11 PM
evanspa
Status: offline
The Tank and Fenders are fiberglass(no glass cloth) I shaped a piece of Styrofoam and coated it with 5 min Epoxy, mix alcohol with it to slow down the cure and thin it out a bit, apply with paint brush. Then, I go over that with 2 part fiberglass from Home Depot. After you get the shape and sand it smooth, pour lacquer thinner on the foam plug and it will dissolve away!
Don't put the fiberglass directly on the Styrofoam, it will eat it, use 1 coat of 5 min epoxy first.
If you sand and prep well you can get a mirror finish using regular model spray paint
I am looking for info on geometry for the fron end...trail, offset.....
       Post #: 9
RE: New Era Choppers: Nitro Drag Motorcycle - 10/25/2003 2:23:31 AM
NitroWolf
Status: offline
What size brake tubing did you use? The tubing is probably easier to work with, right?
       Post #: 10
RE: New Era Choppers: Nitro Drag Motorcycle - 10/25/2003 2:43:28 AM
Tucson01
Status: offline
I found a site on the geomerty for the front forks.. Let me look around I'm sure i can find it again.
Thanks for the info on the Glassing technique.... It will come in handy for building other items as well.
Your setup is still very nice. From the looks though you wont be able to change the angle
on the head bracket that you have already brazed in.
From the pictures the turning radius wouldnt be too large due to the angle you have.
Think of it this way... Like the chopper the longer the forks or wider the angle the greater the turning radius. The wheel leans more than turning
Of course a smaller angle and a quick servo would flip the bike
end over end at high speed.. which is evident if you look at the wheelie vid. The driver over corrects the steering lets off the throttle and a few good bounces before its
road rash is over.
       Post #: 11
RE: New Era Choppers: Nitro Drag Motorcycle - 10/26/2003 2:44:29 AM
Tucson01
Status: offline
Evenspa
Here is a good article on Steering Head geometry.
Link is below:
http://www.j-pcycles.com/shop/express4/techtalk.asp
       Post #: 12
RE: New Era Choppers: Nitro Drag Motorcycle - 10/26/2003 6:33:42 AM
evanspa
Status: offline
I went with about 30 degrees on the head, but increased that a little with the triple clamps. This gave me about 1/2" of trail. As far as tight turn radius' I don't plan on racing with this bike(prototype) but if it does not turn well at all I will attach wheelie bars and a big ass motor for drag racing!! (or build an airplane lol)
       Post #: 13
RE: New Era Choppers: Nitro Drag Motorcycle - 11/6/2003 4:58:07 AM
Jordan Krupp
Status: offline
OK , well , whats the scoop on how this thing works ? > BALANCE ? or no balance ? Good thing I like road racers or would make a 1/3rd scale PRO-STOCK with a SIX HORSE ENGINE ! Hey ! Thats a good idea ?!! I can see it now ! CMB POWER !
_____________________________
Jordan Krupp
       Post #: 14
RE: New Era Choppers: Nitro Drag Motorcycle - 11/7/2003 12:44:19 PM
cutwag
Status: offline
Evanspa, I saw one time at R/C WRAM show in N.Y. Aguy that makes 1/4 scale Harley Engines. did you ever hear of them? The guy started it up too. It was exactly like a full size Harley. Sounded soooo good! And was like an exact replica.
