RCmob
Joined: 4/21/2002 From: St Joe, IL, USA Status: offline
Most airplanes could be designed to have no roll, yaw or pitch coupling if desired, but sometimes looks or other things are considered more important than the aerodynamic couplings of an airplane. The best way to find out about roll and pitch coupling of your airplane is to fly it into a knife edge. ROLL COUPLING: When you apply rudder to hold the knife edge, if the airplane rolls in the same direction you are applying rudder (proverse or positive roll coupling), your airplane has too much dihedral. If the airplane is rolling in the opposite direction of your rudder input (adverse or negative roll coupling), your airplane's wing does not have enough dihedral. PITCH COUPLING: If in the same knife edge, your airplane pitches up, you have positive pitch coupling. If the airplane pitches down, you have negative pitch coupling. The cure to get rid of positive pitch coupling is to move the canopy of your airplane forward, move the stab up in the tail structure or move your CG back. The cure for negative coupling is to move your canopy aft, lower your stab in the tail structure or move your CG forward. A swept back rudder hinge line also helps reduce a negative pitch coupling. The use of wheel pants an/or slightly dropped/raised ailerons may also slightly change your coupling but at least this last one it is not a recommended solution because your stall performance will also change. Of course, changing any of the things I explained above will also make your airplane fly different. Neutral stability with no coupling comes at a price. You have to fly the airplane now. Oh! and there are still many other little trick that may change your coupling in a way or another (winglets, retracts, cowls, wingtips, etc,,)
