Craig-RCU
Joined: 1/10/2002 From: minneapolis, MN, USA Status: offline
[QUOTE]Originally posted by bob27s Unless you will be doing long vertical manuvers, you will not really need a pump. The pipe arrangement will provide solid tank pressure. The small header tank is probably worth while, as long as you ensure that the fuel system is leak-free and it stays filled. [/QUOTE] If by "vertical maneuvers" you mean +- 2 degree attitude maneuvers then you don't need a pump. If you want to climb or dive at more than +-2 degrees for any length of time, then you need a pump. I have tested the Jett FIRE 50 without a pump in my CBM F-16N and it can only handle about a 2 degree attitude change operating on pipe pressure alone before the engine quickly either starves or is flooded (pipe pressure cannot stop the weight of the fuel in the 3 ft lines from rushing into the engine in a nose up attitude). The tanks in the CBM F-16N are 3 feet away from the engine. This is the furthest distance between a tank and engine that I have encounterd in a R/C model. If the CBM F-16N doesn't need a pump, then nothing does. Pipe pressure and a header tank will not substitute a pump. It is enticing to think that having a header tank close to the engine will cure any fuel draw problems but, fuel is an incompressable fluid and thus is subject to the laws of hydraulics. This means that, when the fuel tanks and lines are full, no fuel can be drawn from the header tank unless it is also drawn into the header tank from the main tanks three feet away from the engine. The header tank is essentially just a "bulge" in the fuel line and will not help you break the laws of hydraulics. So, the only benefit of a header tank will be to trap air bubbles from the main tanks. A pump is not optional on this plane unless you move the main tanks to within 6" of the engine, then you will have ballance problems instead. Have Jett engineering set up your FIRE 50 with the VP 30 regulating pump and an APC 10x6 pusher prop. They guarantee their setups to work I believe. I did not have them set mine up and am having overheating problems. I did not specifiy that I needed to turn an APC 10x6 pusher and it was set up with a Bolly 10.5x5 tractor prop. The Bolly prop is not as much of a load as the APC and I think the overheating is caused by the pipe being too short for the APC. I am going to try retuning the pipe myself before send it back to Jett for setting up-- just to warn you Bob27.
