I need tmaxx help
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> I need tmaxx help
Page: [1]
Login
I need tmaxx help - 10/15/2003 11:09:06 PM
pamaxxposse
Status: offline
I just completely put my engine back together and am sure i tightened everything. After about 10 minutes, I noticed oil on my exhaust pipe again. How did it get there. Is there a small hole in my fuel line or is it coming from my carb?
       Post #: 1
RE: I need tmaxx help - 10/15/2003 11:45:02 PM
jval144
Status: offline
check your fuel lines look for a pin hole
(in reply to pamaxxposse)
       Post #: 2
RE: I need tmaxx help - 10/16/2003 5:21:56 AM
frambo
Status: offline
is it on the pipe or on the header? if it is on the header, check your header gasket for a leak...
_____________________________
[link="http://www.beatyourtruck.com"][b]Beat Your Truck[/b][/link]
       Post #: 3
RE: I need tmaxx help - 10/16/2003 10:18:21 PM
j-maxx
Status: offline
yea check u lines ur header gasket and did u put the copper or brass gasket in between the engine case and the cooling head
       Post #: 4
RE: I need tmaxx help - 10/17/2003 11:39:50 PM
pamaxxposse
Status: offline
I just retightened the header before this. How would i check for a pin hole in my fuel line if i can't see it with my eyes?
       Post #: 5
RE: I need tmaxx help - 10/17/2003 11:58:04 PM
Tigger N. Bennie
Status: offline
Blow through it like you would a straw or just replace it. While you are at it you might as well check the fuel tank and fuel cap for air leaks. The cap has an o-ring under it that can be tightened. Some of the older fuel tanks also have a primer which is known for air leaks--I guess that is probably one reason Traxxas replaced it on the latter T-Maxx 2.5s.
Lots of RCs, two cats, and a Nikon.
       Post #: 6
RE: I need tmaxx help - 10/18/2003 12:25:10 AM
Mr. RCGuy
Status: offline
Just a suggestion clip off the zip ties on rubber coupler and install new zipties and cinch them down very tight
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.500RCU1
