2 stoke ringed engine break-in.
Tower Hobbies
Logged in as Guest
  Printable Version
90 Degree Muffler Adapter
Seller:  RC Specialties
Details:   $17.95   |  9/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> 2 stoke ringed engine break-in.
Page: [1]
Login
2 stoke ringed engine break-in. - 10/16/2003 1:10:42 AM
azseattle
Status: offline
Hello,
I got an old engine from a friend. Got new ring and bearings installed on it. It's smooth and seems to have plenty of compression, although i havent tried turning it many times by hand as it might ruin it. It is a two stroke engine. I am not familier at all with the terminology ( rich, lean, four stroke break-in etc). I dont have a manual to follow the instructions. I want someone to clearly explain how to break-in this "rebuilt" ringed engine. I need to know the initial setting of needle valve, throttle, number of tanks required to break in etc. It's a 40 size OS sr max engine.
Thanks alot
       Post #: 1
RE: 2 stoke ringed engine break-in. - 10/16/2003 7:01:19 AM
Flyboy Dave
Status: online
azseattle ....
...you will get a lot of opinions on how to run an engine....
....I'd run it on 15% PowerMaster fuel (a castor blend),
a Fox Miracle Plug, and a 10-8 Master Airscrew prop.
Start and run the motor for a minute or two at half throttle,
let it warm up....then open it up, and run it for 10 mins. at
full throttle....wind it all the way up, and open the main needle
till you hear the motor audibly slow down. (rich) Let it cool
down for about 15 mins., and your ready to fly. Keep the
same rich setting always.....don't lean the motor out for
the last rpm....till after at least 5 tank-fulls.
You're gonna love that engine....
Dave.
_____________________________
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
(in reply to azseattle)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU1
