RE: how do you clean with a crockpot?
Tower Hobbies
Logged in as Guest
  Printable Version
TurboHeader Muffler for Saito's
Seller:  RC Specialties
Details:   $69.95   |  8/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: how do you clean with a crockpot?
Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: how do you clean with a crockpot? - 10/18/2003 9:04:03 PM
Steve Campbell
Status: offline
<<...stick with the green stuff...>>
Yeah, I was leaning in that direction. The pink stuff had all those enviro-nazi stickers everywhere; that's a good bet it is "watered down".
The green stuff it is... undiluted, at low heat.
Thanks again for all the information.
Steve
(in reply to bentgear)
       Post #: 26
RE: how do you clean with a crockpot? - 10/19/2003 1:06:01 PM
Wingdinger Don
Status: offline
Nedyob,
By all means put it back in for another 12 hrs maybe even longer depending on how dirty it is. Let us know how you made out.
Steve,
Have you tried it yet?
Don
(in reply to nedyob)
       Post #: 27
RE: how do you clean with a crockpot? - 10/19/2003 1:31:25 PM
Steve Campbell
Status: offline
Don,
Nope. I acquired that engine for a future project and was just getting the details for when I am ready.
However, I have another project starting soon, and the engine for it has been sitting up for a couple of years, so it probably would benefit from this. I'll pull it later this week and see. If so, I'll just do 'em both. I think there is enough room in that pot for both of them and the mufflers.
Steve
(in reply to Wingdinger Don)
       Post #: 28
RE: how do you clean with a crockpot? - 10/19/2003 8:59:26 PM
Tom Jones
Status: offline
Bentgear, I agree...Everything I've read about to use and the only stuff I've used is the ethlyene glycol(the green stuff). Works great! Don't get it too hot or it can discolor the aluminum a little. Tom
_____________________________
Club Saito#71
AMA 103221
       Post #: 29
RE: how do you clean with a crockpot? - 11/28/2004 5:41:03 PM
artandscience
Status: offline
Has anyone instrumented their crockpot and found out how hot it needs to get to effectively clean a motor?
I've got an old pot that gets to about 155F and I'm fairly sure that that is hot enough but I'm cleaning my first motor
as we speak and don't yet know what the results will be (the crockpot must be 40 years old).
thanks, S.
(in reply to Tom Jones)
       Post #: 30
RE: how do you clean with a crockpot? - 11/28/2004 6:15:37 PM
gcb
Status: offline
S.,
I think you will find that it doesn't NEED heat...it just works a lot faster with it.
If you turn it up high, make sure you have lots of ventilation. Also, as a reminder, never EVER use it for food again and make sure no children or pets can get to the liquid.
George
(in reply to artandscience)
       Post #: 31
RE: how do you clean with a crockpot? - 11/28/2004 6:38:54 PM
darkfa8
Status: offline
anyone every try carb dip? it is for automotive carberators. or, maybe brake cleaner?
- Dan G. -
Avant FX - ys61st2
(in reply to gcb)
       Post #: 32
RE: how do you clean with a crockpot? - 11/28/2004 9:14:53 PM
w8ye
Status: offline
Carb and brake cleaners are used by many modelers on their engines.
Enjoy,
Jim
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to darkfa8)
       Post #: 33
RE: how do you clean with a crockpot? - 11/29/2004 3:28:39 AM
jessiej
Status: offline
[If you turn it up high, make sure you have lots of ventilation. Also, as a reminder, never EVER use it for food again and make sure no children or pets can get to the liquid.]
By all means. Aside from death, other undesireable side effects include blindness and kidney failure.
jess
(in reply to gcb)
       Post #: 34
RE: how do you clean with a crockpot? - 11/29/2004 5:25:53 PM
artandscience
Status: offline
Actually, I found it does need heat. I tried soaking the motor in green antifreeze for over 12 hours with no visible effect.
After some fifteen or so hours in my crockpot probably 90% of the castor residue has come off. I'm going to give it another
seven or eight hours (I want it like new).
Carb cleaner, acetone, lacquer thinner, and kerosene had no effect on the residue.
(in reply to jessiej)
       Post #: 35
RE: how do you clean with a crockpot? - 11/29/2004 6:57:18 PM
BillS
Status: offline
Was it mentioned that crock-pots are available at Big Lots for $8?
       Post #: 36
RE: how do you clean with a crockpot? - 11/30/2004 7:57:55 AM
ArayRC
Status: offline
It it better to use straight 100% Anti-Freeze?
I thought it was best to use a 50-50 mixture with water?
the results I have had in the past with cleaning engines with this method have not always given me good results.
so I was thinking I should try 100% antifreeze this time.
(in reply to BillS)
       Post #: 37
RE: how do you clean with a crockpot? - 11/30/2004 1:55:48 PM
BlackB12
Status: offline
I never heard of this. Will this not harm the bearings?
MIke
       Post #: 38
RE: how do you clean with a crockpot? - 11/30/2004 2:46:45 PM
gcb
Status: offline
quote:
ORIGINAL: ArayRC
Some of the posts on the previous page recommend using 100% antifreeze and low heat.
George
(in reply to ArayRC)
       Post #: 39
RE: how do you clean with a crockpot? - 11/30/2004 3:23:07 PM
bentgear
Status: offline
Use 100% - no water added. Low heat. It will not rust the bearings, thats one of the things antifreeze does, protect metal.
Ed M.
(in reply to gcb)
       Post #: 40
