Steve Campbell
LA, USA Status: offline
quote:
ORIGINAL: BillS If the engine is not taken apart more care is required to flush and oil the bearings. An easy method for this is to flush the engine with hot water immediately upon removing it from the antifreeze bath. Have standing ready a #10 coffee can (or other appropriately-sized container) full of oil. Automatic transmission fluid is cheap and works well. Once all the antifreeze is rinsed away, drop the engine (sans backplate) in the oil, turn it over a few times, and let it sit. The hot metal will "absorb" a certain amount of oil, displace any remaining water, and will ensure that oil gets into every nook and cranny. You can leave the engine "pickled" like this forever. I got the idea from watching some hard-core pylon racers do an engine change, and drop the replaced engine in a can of oil. Its a bit messy when you're ready to use the engine, but by keeping the back plate off and letting the engine drain on a towel for a few hours, most of the oil will run out.
