A fuel experiment
Tower Hobbies
Logged in as Guest
  Printable Version
Used Quadra 35 with Spring Starter and Muffler - RTF
Seller:  gdeezer
Details:   $140.00   |  10/12/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> A fuel experiment
Page: [1]
Login
A fuel experiment - 10/16/2003 11:36:37 PM
Jim Thomerson
Status: offline
Ok, We have a plastic gallon jug of fuel, 80% methanol, 20% oil. It is half full. It is left uncapped for 30 minutes at 80 degrees F, 70% relative humidity, 5 mph breeze. How much water does the fuel absorb? How much of the methanol evaporates? No BS replies please.
Jim
< Message edited by hobbsy -- 10/17/2003 3:45:38 AM >
       Post #: 1
RE: A fuel experiment - 10/17/2003 1:42:38 AM
Hobbsy
Status: offline
Is that calculable?
< Message edited by hobbsy -- 10/17/2003 3:45:56 AM >
_____________________________
"I have gone faster backwards, upside down and on fire than most people have gone at all" Don Garlits
(in reply to Jim Thomerson)
       Post #: 2
RE: A fuel experiment - 10/17/2003 3:08:10 AM
Jim Thomerson
Status: offline
Not by me, who doesn't always spell so well either. However, one can hope that in this modern age of science and technology someone might have a clue; something better than arm waving and urban legend.
Jim
< Message edited by hobbsy -- 10/17/2003 3:46:17 AM >
       Post #: 3
RE: A fuel experiment - 10/17/2003 12:12:22 PM
Ross Kean
Status: offline
It can't be calculated because there is no way to measure the exchange rate of the moisture-laden air above the surface of the fuel. The exchange rate of air, the available surface area, the rate of methanol evaporation and a host of other factors makes this calculation essentially impossible. Having said this, I would seriously doubt that there would be enough absorbed moisture to have any serious effect on the fuel in 30 minutes! Perhaps if you were actively bubbling the air through the fuel at several litres per minute you might have a problem!
Ross
       Post #: 4
RE: A fuel experiment - 10/17/2003 3:33:23 PM
Sport_Pilot
Status: offline
The evaporation rate can be calculated, not sure about the breeze effect, I would think the jug would have to be tilted toward the breeze. I no longer have tables for methyl alcohol but I do recall the boiling point at 14.7 PSI to be only 148 degrees or so. So I suspect the evaporation rate to exceed the effect of the breeze, so that without turbulence their would be no substantial amount of air getting in. Methanol evaporates rather quickly at that temperature so the main problem would be decreasing the amount of methanol causing the percentage of oil and nitro to increase. Now if you left it uncapped for a length of time in a cool area, allowing the vapors to condense and contract with little evaporation then moisture could be a big problem.
       Post #: 5
RE: A fuel experiment - 10/17/2003 3:37:03 PM
David Cutler
Status: offline
I would have thought one click more throttle would have a thousand times the effect on the engine revs than 30 minutes of fuel exposure to the air on your jug.
I really wouldn't worry about it. there are much better things to worry about.
-David C.
       Post #: 6
RE: A fuel experiment - 10/17/2003 6:25:25 PM
Jim_McIntyre
Status: offline
I prefer practical tests to theoretical calculations, too many variables to account for.
I'm no chemist but wouldn't some specific gravity device (hygrometer?) give you the delta in alcohol content?
As for water content, pour the contents in a container with a larger neck, stick it in the freezer for a few hours, scoop out the ice, transfer it to a measuring cup and thaw... of course you would have to know the water content prior to the test... so you could perform this twice (before and after).
< Message edited by Jim_McIntyre -- 10/17/2003 1:26:28 PM >
http://scalebuilder.org
       Post #: 7
RE: A fuel experiment - 10/17/2003 7:36:45 PM
Sport_Pilot
Status: offline
The drag racers use a hygrometer to determine the ratio of nitro to alcohol, but with oil and several differant weights of oils its impossible to tell with a hygrometer.
Not sure I understand your test, but methanol is used as a gas deicer as well as a windshield washer antifreeze. That is it will mix with water and prevent the water from freezing.
(in reply to Jim_McIntyre)
       Post #: 8
RE: A fuel experiment - 10/17/2003 11:12:25 PM
Jim Thomerson
Status: offline
Maybe we just set the jug on a scale, and see if it gains weight from absorbed water or looses weight due to methanol evaporation. Or maybe it will just sit there defying us.
Jim
       Post #: 9
RE: A fuel experiment - 10/18/2003 2:28:12 AM
w8ye
Status: offline
The Methanol would only be 99% pure to begin with and the remainder being mostly water.
Enjoy,
Jim
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
       Post #: 10
RE: A fuel experiment - 10/19/2003 8:30:09 PM
Mr.B
Status: offline
On top of that, aint Nitro about 50% water?
B!
       Post #: 11
RE: A fuel experiment - 10/21/2003 6:54:56 PM
yard-dart
Status: offline
SOLUTION! Don't leave tha cap off of your jug and you won't have to worry about it.
(in reply to Mr.B)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
