Miracle Y won't work on 6 volts. Why?
Tower Hobbies
Logged in as Guest
  Printable Version
JR 12X Transmitter only
Seller:  BAGOSTIX
Details:   $1,300.00   |  11/22/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Miracle Y won't work on 6 volts. Why?
Page: [1]
Login
Miracle Y won't work on 6 volts. Why? - 10/19/2003 4:09:00 PM
CAP232CM
Status: offline
Works fine on 4.8 volts but on 6 volts one servo jitters like crazy. I have three of these Miracle Y's that they claim will work on 6 volts but none of them will. What to do? Thanks!
       Post #: 1
RE: Miracle Y won't work on 6 volts. Why? - 10/19/2003 4:53:51 PM
dirtybird
Status: offline
Send them back
(in reply to CAP232CM)
       Post #: 2
RE: Miracle Y won't work on 6 volts. Why? - 10/20/2003 3:08:28 AM
Gordo-ProBro
Status: offline
Wow, that's weird. I have 2, both on 6v (all I use) and they are fine. I also know of at least 2 others in my area. I'm thinking there is annother problem. But that's just my experience.
Gordo
_____________________________
Gordo
ACCEL hobby Test Pilot..........Talk about "Fly it like you stole it!!!"
       Post #: 3
RE: Miracle Y won't work on 6 volts. Why? - 10/20/2003 6:59:13 AM
mglavin
Status: offline
What type of radio system and servos? Are these Miracles designed for the specific brand equipment your utilizng?
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
       Post #: 4
RE: Miracle Y won't work on 6 volts. Why? - 10/20/2003 10:56:45 PM
CAP232CM
Status: offline
Radio is a Hitec Eclispe7, 3800 reciever, 425BB servos. The Y's say for Hitec/JR 4.8 to 6 volts. The Y's are MPI's. Thanks!
(in reply to mglavin)
       Post #: 5
RE: Miracle Y won't work on 6 volts. Why? - 10/21/2003 2:25:32 AM
mglavin
Status: offline
The connectors maybe Hitec/JR compatible. The Miracle wyes electronics or design parameters must be designed to be used with Futaba/Hitec RX equipment or whatever you specifically use. The brand to brand requirements are different when considering the use of amplified wyes or extensions. Thus your problem on 6V I suspect.
All receivers have a voltage regulator onboard to protect their ICs. The output level of the control signal going to the servo is not the same from JR to Futaba/Hitec. JR receivers output the full battery voltage on the servo signal line. Futaba/Hitec receivers output about 3.3V to the servo on the signal line. All receivers pass the full input voltage to the servo power lead.
Michael Glavin
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.607RCU2
