Flying qualities.
Tower Hobbies
Logged in as Guest
  Printable Version
World Championship Winning Airworld Hawk - RTF
Seller:  volkan
Details:   $28,000.00   |  8/8/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> The Clubhouse >> Flying qualities.
Page: [1]
Login
Flying qualities. - 10/20/2003 8:17:06 PM
Zpat
Status: offline
If there is a gap ( about 1/8" between the wing root and the fuselage of a 60" wingspan airplane , how would this effect the flying qualities?
       Post #: 1
RE: Flying qualities. - 10/20/2003 8:32:21 PM
HoovDriver
Status: offline
ZPAT, I am not completely sure but I do know that the fuselage usually maintains airflow over the wing as the air has nowhere to go but up and over. now on the other end, the tip, the airflow is to a degree lost as it slips over the tip and does not maintain laminar airflow. This is sometimes fixed by adding wing tip caps or on full scale such as the C-17 or some of the newer airliners you will see the wingtip curves upward almost like a vertical stab but much smaller. Wings are designed by people with much bigger heads than I and I would be very careful about changing the properties of them, remember your wing is thickest at its root thereby creating the most lift. Your plane will probably still fly but I would definately do what I could to close that gap, also if it is only one wing that has the gap you will most likely have one wing longer than the other which will also cause some sort of adverse affect, probably a rolling moment which can be fixed with trim I would think. Wish I had a bigger head to help you with,good luck.
ZK
(in reply to Zpat)
       Post #: 2
RE: Flying qualities. - 10/20/2003 9:03:38 PM
greenboot
Status: offline
The gap is not a problem. Just make sure the wing is securely attached.
Did you build this plane? Next time take it easy with the sandpaper.
Tom
(in reply to Zpat)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.516RCU1
