RE: What do you have your conversion in???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Moki 2.10
Seller:  thunderbolt-RCU
Details:   $250.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: What do you have your conversion in???
Page: <<   < prev  1 2 3 4 [5] 6   next >   >>
Login
RE: What do you have your conversion in??? - 1/7/2007 6:12 PM
wiz310
Score: 100
Last Login: 8/10/2009
Status: offline
Beauty. well, put two away for me and another one away for me mate. I'll be bush for a bit as of tomorrow, but will give you ring later next week.
Cheers, Wiz.
Hide Signatures
(in reply to hardtop351)
       Post #: 101
RE: What do you have your conversion in??? - 1/22/2007 8:15 PM
brennan l
Score: 100
Last Login: 7/13/2010
Status: offline
how do you guys think a 21cc roybi conversion would do on this http://raidentech.com/yak542c4652n.html
Hide Signatures
(in reply to Rambo-RCU)
       Post #: 102
RE: What do you have your conversion in??? - 1/22/2007 9:12 PM
cdale03
Score: 100
Last Login: 4/4/2008
Status: offline
quote:
ORIGINAL: brennan l
You mean 31 cc??? That plane is way to small, Its a 46 size glow plane , it could never handle the weight of a ryobi.
_____________________________
http://home.triad.rr.com/cravershomepage/
Hide Signatures
(in reply to brennan l)
       Post #: 103
RE: What do you have your conversion in??? - 1/22/2007 9:29 PM
brennan l
Score: 100
Status: offline
oh dang sorry i put the wrong link up there heres the one i was looking at and yes 31cc http://raidentech.com/aegi20214072.html
Hide Signatures
(in reply to cdale03)
       Post #: 104
RE: What do you have your conversion in??? - 4/27/2007 4:35 PM
onlyifamppowered
Score: 100
Last Login: 9/12/2010
Status: offline
After flying my larger then standard four sate 120 with a 28cc ryobi i wanted more power, the 28 was good but a 31 with a few of Tims tricks added to it should make it really go!!!
So a few hours in Tim's shed (Katanamadman) and this is the result.... A video will follow when I get a chance to mount and fly the beastie...
thanks for your help Tim
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 105
RE: What do you have your conversion in??? - 4/27/2007 7:55 PM
av8tor1977
Score: 665
Last Login: 5/23/2013
Status: offline
I have an Echo 23.6cc engine in this plane and it flys great! (Not 3D however.)
http://www.nitroplanes.com/cmpka14072al.html
Really nice looking and flying airplane, and a super price!!
AV8TOR
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to onlyifamppowered)
       Post #: 106
RE: What do you have your conversion in??? - 4/27/2007 9:29 PM
jtisch
Score: 100
Status: offline
Briggs &Stratton 40cc four-stroke conversion in a 1/4 scale DVII. It's just about ready to go butI have to find a new place to fly it as where I go now has a 20 pound weight limit and this one is @23 pounds.
WWI Aviation T-shirts
Hide Signatures
(in reply to av8tor1977)
       Post #: 107
RE: What do you have your conversion in??? - 4/27/2007 9:42 PM
av8tor1977
Score: 665
Status: offline
Naw... bring your own scales to the field with it "zeroed" to -3 lbs.
Nice looking plane.
AV8TOR
< Message edited by av8tor1977 -- 4/27/2007 9:43 PM >
Hide Signatures
(in reply to jtisch)
       Post #: 108
RE: What do you have your conversion in??? - 4/27/2007 10:54 PM
Ralphbf
Score: 100
Last Login: 7/6/2011
Status: offline
A friend of mine picked one of these up at a swap meet a week ago.
What is your wing span?
Ralph
Hide Signatures
       Post #: 109
RE: What do you have your conversion in??? - 4/28/2007 12:22 AM
jtisch
Score: 100
Status: offline
Av8tor,
Gotta use the on-site scale so no can do . The flying site is kind of small anyway so I'll keep looking.
Ralph,
The wingspan is @88" including the aileron counterbalances.
J
Hide Signatures
(in reply to Ralphbf)
       Post #: 110
RE: What do you have your conversion in??? - 8/22/2007 7:20 PM
jtisch
Score: 100
Status: offline
I finally flew the DVII.
Hide Signatures
       Post #: 111
RE: What do you have your conversion in??? - 8/25/2007 7:34 PM
WMB
Score: 100
Last Login: 1/21/2013
Status: offline
I have a 25cc Stihl trimmer I would like to convert. Bridi makes some big stick kits that look like they could be a good combo. From what I've read here, 10 lbs is about max for 'spirited' performance, not 3-D. Does that sound about right? I will try to get it converted this winter and build when my other projects get finished.
thanks
Hide Signatures
       Post #: 112
RE: What do you have your conversion in??? - 8/26/2007 3:21 AM
flipflop
Score: 100
Last Login: 12/23/2012
Status: offline
In case you missed it in the SPAD forum, I put a Homey 45 in my "Tubester"
Click for fullsize
Hide Signatures
(in reply to WMB)
       Post #: 113
RE: What do you have your conversion in??? - 8/26/2007 11:41 AM
Ralphbf
Score: 100
Status: offline
I'm doing the Birdi Old Timer.
This kit is a tough one. None of the pieces are marked. Most need work before they fit.
It took me 3 weeks to do the wing and longer than that for a friend and me to do the fuse.
I did have to get some wood to make up for missing pieces.
The plans really need to be studyed by a very experenced builder before you start.
There should be 3 sheets of plans and they do it in 2 by overlaying key points on the other set of plans.
I just hope mine will fly good. This will be my last kit for a long time.
By the way were still working on it.
Ralph
Hide Signatures
(in reply to WMB)
       Post #: 114
RE: What do you have your conversion in??? - 8/26/2007 1:26 PM
w8ye
Score: 318
Status: offline
Ralph,
I have a Homelite 30 on mine. It originally had a early type Zenoah 23 (Kalt 22) engine but was under powered. Sure seems to have plenty of power now.
Mine is a little on the heavy wing loading side. On landing, I bring it in with plenty of speed and left the speed bleed off with the plane close to the ground. It stalls at a faster speed than you would think.
On tank off, keep it on the the ground until you have good flying speed. With the big engine it will jump off the ground early before you have full control. For this reason, I would not put the scallops in the control surfaces. Leave them straight.
Up in the air it is like a smaller stick.
The Bridi Stick and the Old Timer are the same plane. The only difference is the name on the box.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by w8ye -- 8/26/2007 2:25 PM >
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 115
RE: What do you have your conversion in??? - 8/27/2007 1:29 AM
Ralphbf
Score: 100
Status: offline
I was hopeing it was goung to be a floater.
I have the picture of you kneeling by yours. I had looked at this for about a year before I made the purchase.
How does yours balance? I noticed the servos in the tail.
I have several engines I could put in it. I understand it was designed for a ST 2500, I have a good one.
I also have a Mac 32cc on Gas-Glow, a ST-3250 I'm converting to Gas-Glow, and a US 35.
I set the tail feathers in the fuse, instead of just putting them on top.
A little more work and I'll be able to mount the wing and check the CG.
Where do you have your CG set? Did you add any weight?
Any suggestions?
Ralph
< Message edited by Ralphbf -- 8/27/2007 1:41 AM >
Ralph
Hide Signatures
(in reply to w8ye)
       Post #: 116
RE: What do you have your conversion in??? - 8/27/2007 7:14 AM
w8ye
Score: 318
Status: offline
The Mac 32 or the US 35 would be ideal. I have a couple Mac 32's and they have the same power as the Homelite 30. The US 35's I've been around are also about the same. These engines all did a 18-8 @ 7500
There's no lead on it anywhere. It balances on the main spar.
The thing is covered with Century 21 fabric which adds a lot of weight.
All standard Futaba 3004 servos but 4-40 hardware on the flying surfaces. I run 4.8V. There are two elevator servos in the rear but the rudder servo is in the radio compartment. The tail wheel which was added later is spring loaded to the bottom of the rudder.
Has a 14oz tank.
Other than what's being mentioned, I've never had any trouble with it.
I initially decided the rudder mounting was a little weak so I used aluminum aero tubing to brace it. That only lasted a couple flights before it cracked. Probably because I didn't use inserts in the ends?
So I used the Dubro tail brace kit and it has held up fine.
The landing gear is as per the print and has held up fine.
I originally had Dave Brown wheels on it but they just couldn't handle the weight. I changed to the Dubro large scale wheels that bolt together. They are perfect.
I also have an extra kit.
< Message edited by w8ye -- 8/27/2007 7:25 AM >
Original AMA #31261
Hide Signatures
       Post #: 117
RE: What do you have your conversion in??? - 8/31/2007 4:39 PM
Joe Butch
Score: 100
Status: offline
Featherlite 21cc, major surgery and throttle coupled spark advance electronic ignition in a .40 size Twist 3D. Unlimited vertical, slows to a crawl to land thanks to thick airfoil, radar gun sez 70 mph flat out. Removed the toy like graphics and applied airplane type trim. Flown hard, this is the third season. Four aonce fuel tank gives 12 minute flights. Redline oil 50:1.
Hide Signatures
(in reply to w8ye)
       Post #: 118
RE: What do you have your conversion in??? - 8/31/2007 4:42 PM
Joe Butch
Score: 100
Status: offline
Here's the Twist pics, Joe Butch
Click for fullsize
Hide Signatures
(in reply to Joe Butch)
       Post #: 119
RE: What do you have your conversion in??? - 8/31/2007 4:43 PM
Joe Butch
Score: 100
Status: offline
Twist with featherlite
Click for fullsize
Hide Signatures
       Post #: 120
RE: What do you have your conversion in??? - 8/31/2007 4:45 PM
Joe Butch
Score: 100
Status: offline
Uno mas, Joe
Click for fullsize
Hide Signatures
       Post #: 121
RE: What do you have your conversion in??? - 8/31/2007 10:15 PM
tom czenthe
Score: 110
Status: offline
My weedwacker conversion......................I'm told I did it wrong ???????
Click for fullsize
Click for fullsize
Tom
Hide Signatures
       Post #: 122
RE: What do you have your conversion in??? - 9/1/2007 7:45 AM
w8ye
Score: 318
Status: offline
That 50cc is a glow engine
Original AMA #31261
Hide Signatures
(in reply to tom czenthe)
       Post #: 123
RE: What do you have your conversion in??? - 9/1/2007 10:37 PM
aero nut
Score: 100
Last Login: 4/1/2013
Status: offline
Brennan!!!
That plane should fly great with the Ryobi 31CC.
Hide Signatures
       Post #: 124
RE: What do you have your conversion in??? - 7/12/2008 11:00 AM
godofcable
Score: 100
Last Login: 4/20/2013
Status: offline
lets ressurrect this badboy. i have a 31cc ryobi, want tout it in this...good fit??
http://www.nitroplanes.com/extra300s140.html
www.rcsoup.com - R/C Reviews, News, and Tips
Hide Signatures
(in reply to aero nut)
       Post #: 125
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: What do you have your conversion in???
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.844RCU1
