RE: What do you have your conversion in???
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: What do you have your conversion in???
Page: <<   < prev  1 2 3 4 [5] 6   next >   >>
Login
RE: What do you have your conversion in??? - 1/7/2007 3:12:20 PM
wiz310
Status: offline
Beauty. well, put two away for me and another one away for me mate. I'll be bush for a bit as of tomorrow, but will give you ring later next week.
Cheers, Wiz.
(in reply to hardtop351)
       Post #: 101
RE: What do you have your conversion in??? - 1/22/2007 5:15:14 PM
brennan l
Status: offline
how do you guys think a 21cc roybi conversion would do on this http://raidentech.com/yak542c4652n.html
(in reply to Rambo-RCU)
       Post #: 102
RE: What do you have your conversion in??? - 1/22/2007 6:12:14 PM
cdale03
Status: offline
quote:
ORIGINAL: brennan l
You mean 31 cc??? That plane is way to small, Its a 46 size glow plane , it could never handle the weight of a ryobi.
_____________________________
http://home.triad.rr.com/cravershomepage/
(in reply to brennan l)
       Post #: 103
RE: What do you have your conversion in??? - 1/22/2007 6:29:49 PM
brennan l
Status: offline
oh dang sorry i put the wrong link up there heres the one i was looking at and yes 31cc http://raidentech.com/aegi20214072.html
(in reply to cdale03)
       Post #: 104
RE: What do you have your conversion in??? - 4/27/2007 1:35:42 PM
onlyifamppowered
Status: offline
After flying my larger then standard four sate 120 with a 28cc ryobi i wanted more power, the 28 was good but a 31 with a few of Tims tricks added to it should make it really go!!!
So a few hours in Tim's shed (Katanamadman) and this is the result.... A video will follow when I get a chance to mount and fly the beastie...
thanks for your help Tim
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 105
RE: What do you have your conversion in??? - 4/27/2007 4:55:20 PM
av8tor1977
Status: offline
I have an Echo 23.6cc engine in this plane and it flys great! (Not 3D however.)
http://www.nitroplanes.com/cmpka14072al.html
Really nice looking and flying airplane, and a super price!!
AV8TOR
If it's not scary, it's NOWHERE NEAR powerful enough!!
(in reply to onlyifamppowered)
       Post #: 106
RE: What do you have your conversion in??? - 4/27/2007 6:29:32 PM
jtisch
Status: online
Briggs &Stratton 40cc four-stroke conversion in a 1/4 scale DVII. It's just about ready to go butI have to find a new place to fly it as where I go now has a 20 pound weight limit and this one is @23 pounds.
WWI Aviation T-shirts
(in reply to av8tor1977)
       Post #: 107
RE: What do you have your conversion in??? - 4/27/2007 6:42:44 PM
av8tor1977
Status: offline
Naw... bring your own scales to the field with it "zeroed" to -3 lbs.
Nice looking plane.
AV8TOR
< Message edited by av8tor1977 -- 4/27/2007 6:43:12 PM >
(in reply to jtisch)
       Post #: 108
RE: What do you have your conversion in??? - 4/27/2007 7:54:56 PM
Ralphbf
Status: offline
A friend of mine picked one of these up at a swap meet a week ago.
What is your wing span?
Ralph
       Post #: 109
RE: What do you have your conversion in??? - 4/27/2007 9:22:57 PM
jtisch
Status: online
Av8tor,
Gotta use the on-site scale so no can do . The flying site is kind of small anyway so I'll keep looking.
Ralph,
The wingspan is @88" including the aileron counterbalances.
J
(in reply to Ralphbf)
       Post #: 110
RE: What do you have your conversion in??? - 8/22/2007 4:20:43 PM
jtisch
Status: online
I finally flew the DVII.
       Post #: 111
RE: What do you have your conversion in??? - 8/25/2007 4:34:09 PM
WMB
Status: online
I have a 25cc Stihl trimmer I would like to convert. Bridi makes some big stick kits that look like they could be a good combo. From what I've read here, 10 lbs is about max for 'spirited' performance, not 3-D. Does that sound about right? I will try to get it converted this winter and build when my other projects get finished.
thanks
       Post #: 112
RE: What do you have your conversion in??? - 8/26/2007 12:21:55 AM
flipflop
Status: offline
In case you missed it in the SPAD forum, I put a Homey 45 in my "Tubester"
Click for fullsize
(in reply to WMB)
       Post #: 113
RE: What do you have your conversion in??? - 8/26/2007 8:41:42 AM
Ralphbf
Status: offline
I'm doing the Birdi Old Timer.
This kit is a tough one. None of the pieces are marked. Most need work before they fit.
It took me 3 weeks to do the wing and longer than that for a friend and me to do the fuse.
I did have to get some wood to make up for missing pieces.
The plans really need to be studyed by a very experenced builder before you start.
There should be 3 sheets of plans and they do it in 2 by overlaying key points on the other set of plans.
I just hope mine will fly good. This will be my last kit for a long time.
By the way were still working on it.
Ralph
(in reply to WMB)
       Post #: 114
RE: What do you have your conversion in??? - 8/26/2007 10:26:55 AM
w8ye
Status: online
Ralph,
I have a Homelite 30 on mine. It originally had a early type Zenoah 23 (Kalt 22) engine but was under powered. Sure seems to have plenty of power now.
Mine is a little on the heavy wing loading side. On landing, I bring it in with plenty of speed a
